Question about Brother MFC-8460N Laser Printer
Brother HL-5270DN PF Kit Problem
Hi Guys,
I am having problems with a Brother HL-5270DN PF Kit error, does any one know how to reset the counter?
Please help me. . .
Thanks
  • 2 more comments
  • nathanb717 Jan 06, 2009
    leroyal,
    I think the above is to clear the drum count not the 'PF KIT ERROR'
    Thanks any way. .
  • Anonymous Mar 17, 2014
    resetting pf kit 1 8890dw
  • Anonymous Mar 24, 2014
    How to reset the P/f kit message on a brother MFC 9325 CW
  • Anonymous Mar 25, 2014
    how to reset pf kit message
I found the answer in another group, from Sunshine3240:
Open the front cover and leave open while completing the following steps:
Turn the printer off.
Hold the 'go' button while turning the printer on. All panel lights should be on.
Release the 'go' button.
Press the 'go' button 2 times.
Pause.
Press the 'go' button 5 times.
The toner light should be off.
The paper light should be on.
Close cover. The ready light should be the only light on.
Posted on Mar 13, 2009
    Genius:
  • 2,120 Answers
I think you leave the top cover open and hold down CLEAR
Posted on Jan 06, 2009
I need a driver for brother hl 5270DN
Here you go just choose your operating system and Off you go. =)
Downloads HL 5270DN Others Brother
Oct 01, 2014 | Brother HL-5270DN Laser Printer
HL-5250 report shows fuser and laser life at 0% and PF kit 1 at 12%
The fuser is a separate component to the drum and toner in this printer. It has a much longer life than them but will run out eventually. Sadly a fuser unit is not a commercially available consumable for this printer either. I would recommend contatcing a printer technicain or Brother directly for a quote on replacing this part.
Apr 12, 2013 | Brother HL 5250DN Laser Printer
OK, we've got a second-hand brother 6050dn for our computer lab of about 35 computers. I've recently replaced the PF KIT For the MP drawer, but had trouble resetting it. Finally figured it out...
Replace the parts! If it is used you have no idea of how old the parts in it are even if they look good. The counters that turn these messages count sheets of paper not time and the parts may have moisture damage from sitting up.
May 02, 2017 | Brother HL-6050DN Laser Printer
I need to replace "PF
Ah the Paper Feed Kit 1 on this unit is pretty easy,
If you remove the paper tray and put the printer on it's back you should see the rollers you're going to replace.. unfortunately the service manual doesn't show this procedure so I can't provide a picture.
If memory serves correctly there should be a long light-blue plastic piece that holds the PF Kit roller assembly in place. If you bend this towards the back of the machine the PF Kit should swing down and you just slide it out, replacement is the reverse of this.
Once you're done you'll have to reset the PF Kit counter by:
Press GO and + together,
you should see RESET PARTS LIFE on the LCD
You can then use the + / - to pick the PF Kit and press the SET key to reset the counter.
If you still have problems let me know via this question and I'll try to help further.
Jun 10, 2011 | Brother HL 5250DN Laser Printer
Help me with reset fuser problem on Brother HL-5270DN
HelloTo reset fuser on your HL-5270DN you have to press "Go" and "+" at exactly the same time. You will be given an extended reset menu. Then you will go for fuser reset.
Plz sure the fuser must be OK/replaced before applying this action
Good luck
Do rate the solution if got help
Dec 06, 2010 | Brother HL-5270DN Laser Printer
Brother hl-5270dn is desplaying the error code S01? What does this mean?
S01 = Fatal error EX
1) turn off the printer
2) wait a few seconds
3) turn it on again
H63 = DRAM access error
3) turn it on again
Sep 11, 2009 | Brother HL 5250DN Laser Printer
How to reset the drum counter on a brother printer HL5270 DN
There should be a way to reset the drum setting. Call Brother they will help you are look in your manual.
May 21, 2009 | Brother HL-5270DN Laser Printer
Brother HL5150 D printer. PF Kit 1 shows zero left available, and I need to reset teh counter for PF Kit 1
Go here by copying and pasting this link
 http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000026/faq000026_004.html?reg=us&c=us&lang=en&prod=hl5150d_all&Cat=4
 to see the visual aids for your machine at Brother Printer solutions center.
The website mentions that the use of the wrong type of paper could cause this problem.
Dec 10, 2008 | Brother HL 5150D Laser Printer
RESETTING FUSER LIFE ON BROTHER HL5140 PRINTER
How to reset the pf-kit message on a brother hl-5140.
May 17, 2008 | Brother HL 5140 Laser Printer
Brother MFC-8460N Laser Printer Logo
1,768 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
