Question about Dishwashers
My one month old dishwasher keeps flashing the red light that indicates inlet/drain problems. I have tried what they suggest in the manual and I have rung miele and was told to reset the machine, but I am about to pull it out and leave it on the side of the road. Please help!!!
    Sergeant:
  • 183 Answers
You have not mentioned Model of mechine. by the way,
you can visit following website which helps you to find out exact problem.
http://74.125.95.132/search?q=cache:X834qfw1xWsJ:www.serviceforce.co.uk/pdfs/U26261.pdf+dishwasher+keeps+flashing+the+red+light+that+indicates+inlet/drain+problems.&hl=en&ct=clnk&cd=3&gl=us
Start going through from Page 17.
http://74.125.95.132/search?q=cache:aL1owCxLszYJ:www.serviceforce.co.uk/pdfs/U27086.pdf+dishwasher+keeps+flashing+the+red+light+that+indicates+inlet/drain+problems.&hl=en&ct=clnk&cd=4&gl=us
from Page 15.
You can try once as instructed on website before you pull ou on road side.
and its very hard to say exact solution for Dishwaser mechine without looking on it once.
Thank you,
Posted on Jan 06, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls postback the model number. Additionally, since th machine is only a month old, why not contact seller or store where you bought.
If you are attempting a quick user fix, normally, there would be a techsheet with wiring diagram at the bottom/kickpanel for a list of errors/faults and the easy user action corrective to them. Alternately, you can check by/if:
  • unplug from the mains for a longer period of time;
  • water is getting inside;
  • drain is clean/working including filter, bowl/sump, impeller, pump, motor, drain hose;
  • in some instances, it may be necessary to force air dry the bottom area using a can of compressed air, an air compressor, a fan/ventilator or even a hair dryer. The idea is to dryout the flood sensors.
Good luck and Thank you for using FixYa.
    Sergeant:
    Scholar:
  • 199 Answers
  1. Check for hose kinks or food plugging drain hose. Start at the drain port exit (there are others, this is just an example)
  2. Check the check valve and drain hose for debris.
  3. Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
  4. Check timer for not letting the dishwasher pause. ( not all dishwashers )
  5. Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
  6. If you have recently installed a new garbage disposal, check knock-out plugat connection.
  7. Check pump impeller for damage.
  8. Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
    President:
  • 2,110 Answers
We have the same dishwasher with the exact same problem. I just pulled it about one or two feet out of its little cupboard thing and the error goes away and it works again, i think that it must extend the hose and free it up a little bit.
  • Sibananda Jena
    Sibananda Jena Jan 06, 2009
    This caused it to lock out on alarm I removed the drain hose from the S
    trap,removed the non return valve from the filter, check the drain pump
    impellar is free, then blow down the drain hose back into the
    dishwasher to make sure it was not blocked then found the drain pipe on
    the S trap under the sink was restricted causing the machine not to
    empty in time for the cycle to continue causing it to lockout on
    inlet/drain alarm. Have a go , good luck.
  • 19,396 Answers
If the machine does not drain start checking the drain hose.
Ifthe drain lines are not clogged, then you will need to access to thedrain pump, and clean it , or replace it if it is not working.
Machine not draining can also be caused by a defective timer control, but this is rather unfrequent.
See also : It won't drain
This seller also have replacements and delivers worldwide.
LKEt me know the exact model for more troubleshooting.
  • Ginko
    Ginko Jan 06, 2009
    To start try resetting the machine.
    On your model turn the knob
    to Stop/End or hold Start/ Stop button for . 5 seconds or longer. Then
    switch the machine off and back on again. If the fault message
    reappears, please contact customer service, as you have a faulty drain pump, and you need a technician.
    Check also the drain filter and drain hose as instructed on the user manual.
Machine is not washing, spinning or draining
has someone interfered with the inlet tap. The buzzing is normally a sign that the appliance is trying to take water but tap is off.
Mar 29, 2010 | Zanussi ZWF14070 Front Load Washer
Outlet/inlet light flashing on miele dishwasher G674SC
Usually indicates a intake or drain fault - could be a plugged drain line at the garbage disposal or insufficient water coming into the unit
Sep 22, 2009 | Miele Dishwashers
Hello , The inlet/drain light on my dishwasher is flashing , I have mislaid the manual can you explain how I can rectify the problem please , I am assuming something is blocked. Regards Georgina Cooke
My G892SC is almost 10 years old and recently had the same problem. The machine seemed to be stuck in the drain cycle and the intake/drain light flashed. I called Miele and ran through a few diagnostic tests but nothing worked. I had a Miele certified technician come out to look at the problem and he told me the drain pump needed to be replaced and that it would cost about $500 for the part and labor. While researching the cost of a new dishwasher, I stumbled on some online discussions about this problem and someone suggested pressing all 4 lower buttons on the control panel at the same time. I tried it last night and it worked! I only ran the wash & hold cycle but will try a full cycle tonight.
Jun 24, 2009 | Miele G892SC SS Dishwasher
Miele dishwasher red inlet light flashes
This is most probably a software glitch. I had the same issue a week ago and my dishwasher is only about 2 yrs old and only gets used on average once a fortnight.
At first I did everything as the manual shows in the troubleshooting section. The whole process takes only about 5 to 15 minutes depending on how good of a handyman you are.
When I cleaned all the parts involved (all pretty clean to start with anyway) and connect them all back, sadly the red light wouldn't go.
It looked like I was stuck with the most hated option I had left: call the dreaded technician and be prepared to depart with some hard-earned cash.
Before doing that and out of desperation, I decided to surf the net for clues, blogs, forums, etc... and on one of them I found my answer.
One blogger suggested that "if anything else fails, try the 'reset' step" which means pressing at the same time the On/Off button and the Start/Stop button. That operation put a big smile on my face (and my wife's face too) as the red light magically disappeared.
My suggestion is "first try the reset trick and if that fails try and clean the parts as the manual shows". It'll save you headaches because the reset would do the trick in 90% of cases.
I work in IT and I can understand the fact that a software malfunction would trigger the red light and not reset it.
Good luck.
Mar 28, 2009 | Miele 24 in. G645SC Plus Free-standing...
Hotpoint FDW60 flashing eco light
if the eco light is flashing, this indicates that saftey float switch has activated in the base of the dishwasher usually caused by a leak, a polystyrene float activates a microswitch which cuts of the water inlet supply
Mar 28, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Wash motor does not run: Inlet/Drain error
Wordhog: Does sound like a siezed wash pump to me. Wash motor needs to run to get the correct level of water.
To drain a Miele dishwasher, start the machine on a cycle. All the Miele range of dishwashers drain before filling. Then hold in the start button until the end/finish light is lit. Keep doing this until all the water has gone. You could just get a jug and bail it out. Once the jug does not do the job anymore, switch to a cup, I use a very large syringe for the remaining half a litre.
Oct 28, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Inlet/Drain light keeps flashing
Kenyanjoe, I have had the same problem with a G638 . the inlet/drain light flashed 30 sec after start up, (the machine must empty on start up, this did not happen), This caused it to lock out on alarm I removed the drain hose from the S trap,removed the non return valve from the filter, check the drain pump impellar is free, then blow down the drain hose back into the dishwasher to make sure it was not blocked then found the drain pipe on the S trap under the sink was restricted causing the machine not to empty in time for the cycle to continue causing it to lockout on inlet/drain alarm. Have a go , good luck. GUNNO
Aug 14, 2007 | Miele 24 in. G693 Free-Standing Dishwasher
Dishwasher error codes please help
I too had this problen today. Printed off a manual from the Hotpoint website. Very helpful troubleshoot section. Anyway, flashing eco and fast lights and beeping sound indicates 'water feed pipe blocked' You need to check the water inlet connections on your tap.However, when we pulled it out we noticed the blue water inlet pipe was slightly kinked. Straightened this out and hey presto! It works fine again. How this happens when its worked ok for 18 months will never know but still. Try it! hope this was helpful...shewoo
Apr 26, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
26 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
