Question about D-Link DP 301U (DP-301U) Print Server
Problem with scan from print server
I HAD INSTALLED PRINT SERVER D-LINK DP-301U AND WANT TO GET SCAN FROM PRINT SERVER THE PRINTER ATTACHED TO PS IS SAMSUNG SCX4100 CAN ANY ONE HELP ME.
  • deven1684 Mar 14, 2009
    I HAVE BROTHER MFC-7420 PRINTER WHICH HAVE SCANNER BUT I AM NOT ABLE TO USE SCANNER ON NETWORK
  • Anonymous Apr 27, 2009
    i have SCX-4521F and can't get it to work AT ALL with DP-301U. DLink tech support says the printer is incompatible with DP-301U.
  • 30 Answers
This unit does NOT officially support Samsung printers... but it will allow printing with some. It does NOT support multi-function printers features like scanning for any brand of multi-function printers.
Posted on May 25, 2009
Where can i download the driver for DP-301U
Print Server doesnt require driver. Connect the printer to the computer directly and check if it is printing. The drivers for the printer will be loaded and you will be able to print. Then connect the printer to Print server and you will be able to print. If it is still not printing, you have to create an LPR port for the printer driver
Aug 21, 2010 | D-Link DP 301U (DP-301U) Print Server
What is the difference between d link DPR 1020 and DP-301u
One of the main difference between this tow printer is the DPR1020 is made to work with all printer including those multi function printers , because this old DP301U was a older version of print server that don't support those new multi function printers features like scanning and fax. So if you have a multi function printer I will advice you to get the DPR1020 so all features of that printer will work behind this print server.
Aug 16, 2010 | D-Link DP 301U (DP-301U) Print Server
I have installed the DP-301U print server on my home network to print to an HP Laserjet 4050. When setting up the print server per instruction, I set my computer IP address to a static IP address. The...
Your print server has to have its own IP address. If you have your computer as 198.168.1.1 then your print server would be 198.168.1.2.
You cant have the same IP address on any 2 items on your network.
Oct 20, 2009 | D-Link DP 301U (DP-301U) Print Server
Print server DL-301U setting
I have one of theses D-Link PD-301U. It does NOT support a printer like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1006 is NOT in the list):
Apr 14, 2009 | D-Link DP 301U (DP-301U) Print Server
HP LJ P1008 can be used as network printer ?
I have one of theses D-Link PD-301U. It does NOT support a printer like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1008 is NOT in the list):
LaserJet
  • 1200
  • 1500 (USB 2.0)
  • 2200
  • 2200D
  • http://support.dlink.com/faq/view.asp?prod_id=2135&question=DP-300U%20/%20DP-301P+%20/%20DP-301U%20/%20DP-311U%20/%20DP-G310%20/%20DP-G321
    Feb 10, 2009 | D-Link DP 301U (DP-301U) Print Server
    D-Link DP 301U Print Server not continuous print from vista
    Make sure you have byte counting enabled if you are printing through LPR.
    Dec 11, 2008 | D-Link DP 301U (DP-301U) Print Server
    D-Link DP-301U Problem
    It should be fine as long as it is in the range that the router can recognize and that it doesn't conflict with another IP address used on another device. Usually on the networks I design I keep the printers on higher IP address so that they can be managed on a certain range.
    Is this the wireless print server?
    What specifically do you mean by PJL printer block?
    Aug 04, 2008 | D-Link DP 301U (DP-301U) Print Server
    Scanner
    This is not a solution just a possible fly in the ointment. I have often found that scanners only work when attached directly to a computer. Scanning over the network is not a solution I have found. You can always share out the printer from the attached pc.
    Jan 09, 2008 | D-Link DP 301U (DP-301U) Print Server
    D-Link DP 301U (DP-301U) Print Server Logo
    956 people viewed this question
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
