Question about D-Link AirPlus DI-524 Wireless Router
Why is my modem not recognised by vista ???
Hi i have a d link di 524 and it works great while networking 2 computers ( i dont have internet yet i have just changed providers ) but when i try to install the soft ware ( all steps 1-3 are fine ) when i get to the phisical conectivity test it fails to recognise the modem ( even though i can seee it in network conections at the control panel ??? ) WTF ????? im using vista, is it because i dont have a net conection yet ?????? i thought that had nothing to do with phisical conectivity
HI
Please confirm that your Dlink Di 524 firmware is upgraded. With Vista the firmware update resolves the issue.
http://support.dlink.com/emulators/di524/tools_firmw.html
use this to update teh firmware. its shows instructions on how to to do that.
let me know if you need more help.
thank you
rakesh
Dell Laptop Expert
Posted on Jan 06, 2009
D-link DI 524 Router (Quick Router Setup - error: 103
103 most popular error on DLink Modems and Routers.Error occurs when your computer or router is not able to find the internet connection. Reason behind settings of the modem or router.
Try to use :
  • "https" instead of "http" in the URLs.
  • Check Firewall is not blocking your internet connections.
  • Reset your modem or router.
For setting up and configure your router http://support.dlink.com/index.asp and D-Link Router Support for technical help.
Jan 27, 2014 | D-Link Computers & Internet
Ethernet connection of DI-524 does not work
You have to make the Ip changes on the laptop not on the modem.
You said you have internet acces on one computer. Then use that computer to find out the exact IP address used by the modem.
On the laptop use the exact same numbers, (IP, Sub mask, Gateway, Primary DNS)
and chek if it works.
If you want to have both computers on the Internet, simply change the last number on the IP address ONLY.
Please don't forget to rate this answer if it helps
Sep 22, 2009 | D-Link AirPlus DI-524 Wireless Router
I want internet does not disconect
In order to use 2 modems you need to have two service providers.
If you have 2 service providers then you"ll have two network names(ssid's) for two different modems .
Connect your wireless computer to two different networks . So if one link goes down you can use another.
Feb 28, 2009 | D-Link AirPlus DI-524 Wireless Router
Cannot connect DI-524 to VISTA
There is nothing on DI-524 what is Vista specific. Make sure you installed your dirivers properly. I have the same , works without problems.
Jan 22, 2009 | D-Link DI-624 Air Plus XtremeG Wireless...
D-link wireless internet
It is always a good thing to start the different peripherals in an order. First, you start your modem. Wait 30 seconds. Then, start the router; wait another 30 seconds; then the computer.
Aug 24, 2008 | D-Link Wireless Cable/DSL 802.11G Router...
No internet Connection
this is something simple
2 things you will have to do
the router when a problem like this happens again
unplug router for 1 minute this is packet build up and then plug back in i found this out by service provider that its a build up of packets it relieves packets
now the other thing since you went threw all the little areas of trying to reset modem go in remove your network connection
delete it and build a new network connection threw the network setup wizard then your done restart comp everything should be back to normal and you wont have to ever reset network settings again
just unplug the router let sit for minute and plug back in
Jun 01, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524 wireless router as wireless switch
You need to disable the DHCP server on your "slave" wireless router ( the di-524 ). In D-link routers this might be called configuring it to be an "Access point".
When this happens, connecting to the second wireless router should cause your computer to obtain an IP address which is in the range of the first router (that is to say, it will use the first router's dhcp server).
You should be able have your laptop connect with an automatic IP address and have it work.
Jan 24, 2008 | D-Link AirPlus DI-524 Wireless Router
Disabled dhcp, cant access router with browser
the default ipaddress for that is 192.168.0.1 you will need to set your computer with a ip address like 192.168.0.2 then you should be able to access it. be sure to change your computer back to DHCP after you reset the router
Dec 26, 2007 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
197 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
