Question about Canon CLC 1150 Color Copier
In CLC 1150 When power on the paper jam error show who to solve the problem in copier jam the error code shows 00-0360 0-367596
    Scholar:
  • 160 Answers
There are rollers that cling on to the paper and move it through the machine. When the rollers are worn down they do not grip the paper. For a short fix you can get something rough like sandpaper, brillo pad, etc, and gently scratch the rollers to give them some traction. This will temporarily solve your problem until you can get the rollers replaced.
Posted on Jan 06, 2009
Canon error jam
for this case you must call technician for chek it.
because the technician have to detail to chek it.
- position of paper.
- condition of paper.
Feb 27, 2013 | Canon CLC 1180 Copier
It shows that there is a paper jam, but there isn't.
grab a flash light... pull out each tray... look up in the machine... put trays back in... open every cover... every door... find that paper... it may be hidden in a crevice somewhere... find it...
Dec 19, 2009 | Canon CLC 1150 Color Copier
Clc 1120 show code E0008
hello,this is caused by a faulty relay contacts rear lower right corner sand with fine sand paper will probably new ac relay
Nov 06, 2009 | Canon CLC 1150 Color Copier
Canon clc 1180 error code 073-0003
this is an error for the transfer unit or its cleaning section not in proper place slide out the unit as far as it will go.. look inside to the lower left rear frame. there are 2 halfmoon gears sticking out reach in and turn both of those clockwise till they stop . slide unit back in close doors see if it resets good luck
Dec 28, 2008 | Canon CLC 1150 Color Copier
CLC 1110 E71?0007, E071?0002, E072 error codes.
On my CLC 1150 copier machine, I have an error code E071 – 0002.
Sir plz send soluation this error
Dec 12, 2008 | Canon CLC 1110 Copier
Paper Jammed
your sensor is detach or bad where it says paper jam
Oct 08, 2008 | Canon CLC 1120 Color Copier
Canon CLC 1150 - E804
it may be the fuse board or the relay near the fuse board that is arcing
May 19, 2008 | Canon CLC 1150 Color Copier
CLC 700
remove the lamp and check the continuity, the lamp may be burnt out, also check the lamp thermal fuse. Failing that, check the continuity of the lamp cable, it may be broken inside the sheathing. And failing that, replace the lamp regulator.
May 15, 2008 | Canon CLC-700 Copier
E072 - 0002
most of the time if you replace the transport cleaning unit it fixes the fault. on one machine i had a break in the wire lume that caused the problem. also make sure you don't have a piece of paper jammed in the unit.
Apr 09, 2008 | Canon CLC 1120 Color Copier
Canon CLC 1150 Color Copier Logo
98 people viewed this question
old marine
old marine
