Question about Sony Cyber-shot DSC-W50 Digital Camera
PUlling out the lens because it says access and doesnt show the screen.
Okay. HOw do you pull the lense out of the camera because it says access. And i like dont wanna brake it ... so like i need some like help =D
  • 1 more comment
  • chelsea VATKA May 26, 2007
    ONce you turn it on its black. And all it says in the middle is "access" But i can review pictures. But not take anypictures. THen sometimes it says turn off power then turn on again
  • HoofHearted Dec 29, 2007
    When I turn on the camera, it is a black screen on back, and all its says is "access". After about 15-20 seconds, it tells me to "turn power off-on again". Also, the lens on front extends and retracts, once or twice, before I turn it off. Please, any help would be appreciated.
  • dondouglass May 03, 2008
    same here-
  • 883 Answers
Clarify "it says access"...?
Posted on May 26, 2007
Lens inside dirty
Well... The service manual is here:
http://tsn.pasc.panasonic.com/viewing/ALL/DMC-TZ3P/SVC/DSC0703019CE_PRINTB/DSC0703019CE.pdf
before you do it, can I suggest popping the end of a shop vac over the lense as it is pulled out and seeing if that helps at all? It probably won't but it's a lot easier than pulling this to pieces, especially since the lense is not that accessible.
I wish you luck, it's not a fun task!
Dec 01, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Olympus Stylus 710 Error: D: 5f08 5f0a 5e02 5f08 5e02
this is the most common problem with the olympus cameras the lens has been knocked and by you pulling on the lens it sounds like you have done some damage to the motor that bring the lens in and out thats why its making that noise what you needed to do was move the lens either to the left or the right you will no when its fixed because the lens just pops out and the camera will be fine this works every time i just hope you havnt done to much damage alredy goodluck
Sep 21, 2008 | Olympus Stylus 710 Digital Camera
"access" screen, lens has trouble retracting, lens will not focus
try these two things i cant promise they will work
first turn on take hold of the lense and gently pull and twist you may hear it click dont force it then trun off and on again. this should fix the access and lense problem
then also try
Press Menu button
togle across from REC Mode to setup
togle down thrice from camera to setup 1
togle across into sub menu
togle down from four times to Initialize
togle across again to the sub-menu
togle up from cancel to OK
press center button to accept the OK choice
Screen changes and so press okay again
It should restart the camera
Opening on the 'Clock Set' screen
togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and not a hardware malfunction.
If it is working then don't forget to set your Clock.
Aug 14, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Cyber SHot DSC-W80 lens will not close.
Your lens is jammed. Odds are it's unrepairable, but as a last ditch effort try GENTLY wiggling/twisting the lens as you attempt to power down or on.
Aug 05, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Lens not moving
try switching on and gently pulling and twisting the lense you may hear iot click but dont force it, then turn off and on again this may solve you problem.
Jun 08, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
ACCESS?!?!?!
I had to tap the entire front of the lense on the fat part of my palm. I had to do it 4 times semi-hard. Then the camera just popped on. Thanks for the tip, I did have to do it three times turning it off and on after each 4 strikes. The fifth time was a charm. I now have to do it every time to make my camera work. Crazy but it works.
Sep 11, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Sony n2 camara problem
ok guys, I was getting the same "Access" black screen on my dcsn2. I would turn it on and the lens would pop in and out I would get the black screen with the "Access" on it. What worked for me was the following:
As the lens came out i grabbed and pulled while it was fully extended
The "Access" screen disappeared and my camera was back to normal.
hope this works for u guys! :-)
Sep 09, 2007 | Sony Cyber-shot DSC-N2 Digital Camera
Minolta G500
your lens mechanism is stuck up! try pulling the lens with slight force, if you are lucky the culprit that is blocking the mechanism will get loose. If you are not lucky theres no way you can remove or fix the problem than sending it to the authorized service center. =-(
Aug 24, 2007 | Konica Minolta DiMAGE G500 Digital Camera
Olympus camedia c50
You manualy pull the lense out it is probably jammed. The same thing happened to us but we fixed it by doing that. turn on the camera again and it will work. I'm not kidding
Sep 10, 2006 | Olympus Camedia C-50 Zoom Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
90 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
