Echnical Information PCI Drivers and Utilities PCI Express Drivers and Utilities Problem caused by Realtek 8101/8168/8169 PCI/PCIe Adapter Driver (RTLH86.SYS) This problem was caused by Realtek 8101/8168/8169 PCI/PCIe Adapter Driver (RTLH86.SYS), which was created by Realtek Semiconductor Corp.. There is no solution for this problem at this time. Recommendation A problem has been detected and windows has been shut down to prevent damage to your computer. DRIVER_IRQL_NOT_LESS_OR_EQUAL Technical information: *** STOP: 0x000000D1 ( 0x00000008, 0x00000002, 0x00000001, 0x827215B2 ) *** ndis.sys - address 827215B2 base at 826FC000, Datestamp 4549b2fd
    Brigadier General:
  • 8,619 Answers
Hi! Think you have installed adriver not recommended to be used with your pc. Try installing a diffrent version. You can download it from the link--
http://www.realtek.com.tw/downloads/
If it doesn't work go to bios settings when your PC boots by pressing F2 key. Then go to Advanced options and change the value of
Onboard Serial Port 1 : Option should be set to 3F8/IRQ4 .
Onboard Serial Port 2 : Set this to 2F8/IRQ3
Onboard AC97 Audio Controller: Enabled
Thanks
Rylee
Posted on Jan 06, 2009
What are some of the best PCI-Express PCIe Solid State Drive SSD?
Some of the best PCI-Express (PCIe) Solid State Drive (SSD) are:
1. Intel SSD 750 Series PCI-Express 3.0 MLC
2. Plextor M6e Series PCI Express SSD
3. Kingston Digital HyperX Predator PCI Express SSD
4. OCZ RevoDrive 350 Series PCI Express SSD, etc.
If you want to purcahse these high quality PCIe SSD, you can easily get them on PS4 SSD at a reasonable price.
Jun 07, 2017 | Best Computers & Internet
I have a g5690 shuttle and would like to install a wireless card to connect to our home wireless network. What shoeld I buy?
My suggestion would be a mini-pcie laptop card, N300 or higher (you can buy them on Amazon and Ebay for around 25 dollars, Azureware or Intel are usually good) and a low-profile mini-pcie to pcie adapter which comes with antenna. Azurewave AW CE123H 802 11ac nbg WiFi BT PCI Express Module Broadcom... Mini PCI to PCI Wireless Adapter 3 Antenna WiFi
Dec 26, 2014 | Shuttle Computers & Internet
Update drivers on hp620 laptop
this is zero support PC.
why mess with it at all
go to goodwill and buy a w7 up device.
end this horror now.
BTW, the show stopper here is 2 fold.
1: HP has no support on retired PCs
2: realtek the mofos., block driver downloads..
Jul 13, 2017 | HEWLETT-PACKARD HP 620 ok Intel Core 2 Duo...
What kind of graphic cards work with Pvm900m
http://www.mercury-pc.com/product-detail.php?link=p-mainboards&subtitle=Mainboard&productid=748
Specifications > Expansion Slots > PCI Express x16
http://en.wikipedia.org/wiki/PCI_Express
PCI EXPRESS 2.0
"PCIe 2.0 motherboard slots are fully backward compatible with PCIe v1.x cards. PCIe 2.0 cards are also generally backward compatible with PCIe 1.x motherboards, using the available bandwidth of PCI Express 1.1. Overall, graphic cards or motherboards designed for v2.0 will work with the other being v1.1 or v1.0a."
-> PCIe 2.0 graphics cards are ALSO -> Backward Compatible <- with PCIe 1.0, or 1.1 motherboards.......
-> Using the available bandwidth of PCI Express 1.1
[ PCI Express 2.0 = 500MegaByte per Second, per lane data rate.
PCI Express 1.0 and 1.1 = 250MB/s, per lane data rate.
PCI Express 2.0 = 5.0GigaByte per Second transfer rate
PCI Express 1.0 and 1.1 = 2.5GB/s transfer rate
Will you notice? NO
Regards,
joecoolvette
Jul 15, 2012 | Mercury Computers & Internet
Got a geforce 8400 gs pci express graphics card and it does not fit in my olc pc. is there an adaptor i could get that would solve the problem as i cant take it back as its been opened?
1. You need to know what type of bus your mobo has. e.g. PCI, AGP
2. The adapter you are looking for is not available, there is something called RISER card. it is only for pcie to pcie used as a replacement for low profile graphics card. if there are such adapter it would be expensive.
3. You have to upgrade or swap it to some one who likes your card for an additional amount of money. it depdends on the market value of the card to be swapped.
Hopefully this information helps.
Thank you for using FixYa.
Aug 03, 2011 | HP NVIDIA GeForce 8400GS - Graphics...
How can i tell the difference between pci slots and pcie slots
The Peripheral Component Interconnect or more commonly known as PCI is a standard for connecting a lot of devices inside your computer to extend its capabilities. Devices like sound cards, modems, NIC, TV Tuners, and some video cards have at some point or another have used the PCI port.
PCI express ( PCI-E ) is a much improved version in terms of speed. PCIe uses a serial interface instead of the old parallel interface used by PCI. It also utilizes individual buses for each of the devices connected to it instead of a shared one like what PCI uses. The difference in speed is quite huge when comparing the standard PCI slot which runs at 133MB/s to a 16 slot PCIe that can send or receive up to 16GB/s.
The most common use for PCIe nowadays is with graphics cards which benefits hugely from the huge bandwidth provided by the interface.
1. PCIe is much faster compared to PCI.
2. PCIe uses a serial interface while PCI uses a parallel interface.
3. PCIe speed is classified into lanes, each capable of delivering up to 1GB/s data transfer.
4. PCI slots are standardized while PCIe slots vary depending on the number of lanes the slot is intended for.
5. Despite PCIe superiority, most manufacturers still use the PCI standard for their devices.
Unlike PCI slots which are the same size for all devices, PCIe slots can differ depending on which form factor it accepts. The longest would be the 16 lane slot and understandably, the shortest is for the x1 devices.
I hope this much information is enough for you to understand the difference between both of them. If you need any more help let me know.. !
May 13, 2010 | Dell Dimension 3000 PC Desktop
Wndows vista
All the drivers for that motherboard can be download from the official site at http://www.asrock.com/mb/download.asp?Model=Wolfdale1333-GLAN/M&s=775
Good luck
Jun 20, 2009 | Computers & Internet
Computer shutdown anytime
coupure plusieurs fois par jour de l'ordinateur, sans raison ! un message apparait, disant que le problème est provoqué par Realtek 8101/8168/8169 PCI/PCIe Adapter Driver (RTLH86.SYS) QUE DOIS-JE FAIRE POUR SOLUTIONNER LE PROBLEME ?
email : michel-gaignard@wanadoo.fr
Oct 05, 2008 | Computers & Internet
Sony VGN-N365E WINDOWSXP-PRO DRIVERS DOWNLODS
Audio Drivers for the Sony VGN-N365E running XP can be found at:
Device is a RealTek High Definition Audio
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=14&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
Wireless LAN drivers can be found at:
Device is an Atheros Lan-Express AS IEEE 802.11g PCI-E Adapter
http://www.atheros.cz/download.php?atheros=AR5006EG&system=1
Modem Drivers can be found at:
Device is a Conexant HDAUDIO Soft V92 Data Fax Modem with SmartCP
http://www.downloadfast.net/download11235.html
let me know if this helps...
Oct 15, 2007 | Creative Labs Sound Blaster Live! 5.1...
Computers & Internet Logo
243 people viewed this question
David Payne
David Payne
