Question about Hotpoint WMA30 Front Load Washer
WMA54 Hotpoint Aquarius drum does not turn during wash or spin
The machine fills with water but the drum does not turn. It does not move on the spin cycle. I can hear the motor working. The drive belt has been checked and this is intact. The drum moves freely when turned by hand but it does seem have an a lot of free movement. Any ideas please before I call an engineer out!? Thanks.
  • Hotpoint Master
  • 19,396 Answers
If the machine pumps water inside but does not start :
Start checking the lid switch, if this is stuck the machine wont start.
If the drum does not move at all, the motor, the motor control unit, the motor coupler, the control board may be faulty.
For more details , see: It doesn't spin
See also a general diagram here: WMA54 Hotpoint Aquarius drum does not turn during  - redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Posted on Jan 06, 2009
Drum is not turning
Could be the brushes, only way to prove it is to remove the motor and check the brushes for wear.
If they are less than 3 or 4 mm long, then they need replacing. If brushes are o/k, then it is probably a control board fault.
Jun 03, 2010 | Hotpoint WMA54 Front Load Washer
WMA54 won't empty water? We've emptied filter but
Could be the pump, but they do not often fail.
I would check the main hose or the pump itself for a blockage.
Try blowing down the hose to see if it is clear.
Mar 03, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius 1100 WM63. fills with water...I dont think it is heating water...rarely rotates and spins (saw it once in early stage of J prog only) seems to fill and empty but no rotate or spin....
if it fill with water then stops it is the ellement the machine first fills turns the drum then heats up the thermostat cuts in and the it emptys rinses and spins so if it does not get to temp it will stop or continue to wash forever
Jun 27, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Drum won't stop filling with water
i think u need a bearing seal to ur washing machine so ur gona need a technician and if its gona coast a lot just change it
May 31, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Loud niose coming from my machine when spinning
  • Hi,
  • Try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
May 18, 2009 | Hotpoint WMA54 Front Load Washer
WMA54 Hotpoint Aquarius flashing lights
My wife had the same problem last night.This morning when I turned the m/c on, there was a lot of noise and when I looked underneath, loads of sparking. Closer investigation shows I need new brushes and I imagine that if the drum on your machine is not turning, you do too.
However you said that you can hear the motor? That may indicate a belt problem instead. get someone to turn the machine on it's side and manually turn the drum. If the motor rotates it isn't a belt problem and someone needs to test/repair your motor.
Hope that helps a little.
Jon
Jan 06, 2009 | Hotpoint WMA54 Front Load Washer
For more details you need to observe if machine is draining and pumping water inside during cycle, see: It doesn't spin
Hotpoint Aquarius WMA54 very noisy during spin
Hi, if your H/P is noisy on the spin cycle, just open the door and turn the drum a few times. If you feel some play, or kind of loud huming noise, then it is the bearings, very, very common on H/P WMA's.
Nov 13, 2008 | Hotpoint WMA54 Front Load Washer
Washing machine WMA54 Hotpoint sticks on prewash
I realised that the washer was not filling properly with water!  So I pulled it out from the wall and noticed the cold water fill pipe had been squashed and had a kink in it so not enough water was getting through.  I remedied this by pulling the pipes through the under sink cupboard and securing them with gaffer tape,  Hey presto the machine now works again!  Hooray :D
Oct 06, 2008 | Hotpoint Aquarius WMA52 Front Load Washer
Hotpoint Aquarius WM 62
Hi, Does the drum turn during the wash cycle? When it comes to the spin cycle does it go through to the end without the drum turning? It sounds like it could be the motor needs new carbon brushes. Regards, Tom.
Apr 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WMA30 Front Load Washer Logo
425 people viewed this question
Top Hotpoint Washing Machines Experts
hungoverrr
Level 1 Expert
puggy666
Level 1 Expert
gbob59
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
