Question about Onkyo TX-SR602 Receiver
Echo when connecting Samsung Plasma to Onkyo TX-SR602
I have recently purchased a Samsung series 7 plasma TV. All connections to DVD and Satelite appear to be fine, however when connecting the Optical Out from the either the TV and/or the DVD into the Optical IN on the Onkyo TX-SR602 receiver, it results in an echo. The echo also occurs when using the standard Left/Right red and white jacks.
All settings, sound and cables were perfect when set up with the previous TV.
  • 151 Answers
Make sure you have the tv volume turned right down as this will cause an echo,also set amp to prologic 2, and set up xover to suit your speakers or go for the THX standard of 80 hrtz and as a rule of thumb set front L,C,R speakers to zero rears to about +4or5 and your sub to -5[ dont know which speakers you have but try setting the subs on board volume to the 10,o,cloak position],also make sure the speakers -,+ are wired the same at the amp and speakers.
Hope this helps.
Posted on Jan 06, 2009
Onkyo tx-sr604 help
You said you tried hooking the HDMI up directly from the TV to each component, and that worked. How is it usually hooked up - through some kind of switch? I'm not completely understanding your setup here.
Aug 10, 2007 | Onkyo TX-SR604 Receiver
Connecting a wii to an Onkyo TX-SR607 7.2
I am experiencing issues like this although with a VCR connected with analog video. I added a BluRay DVD player and all of a sudden I lost my video upconversion from my VCR. I am going to try to reset the receiver to see if this fixes the problem. If not, I don't think it is the receiver issue, I think it may be the fact that enorder for video to pass through HDMI, allot of criteria needs to be met. Certain Handshakes need to happen, especially with the HDCP issues. Most likely I will connect a separate video cable to my Plasma and use a secondary input on the Plasma for the VCR signal. You may want to purchase the Component Video adapter for the wii system as this will provide you with at least 480p and your receiver should not have an issue passing the signal over the HDMI output. Good luck and give me an update.
Jun 06, 2009 | Onkyo TX-SR606 Receiver
1080P video via HDMI generates awful interference
Your Plasma's native resolution is 720P. Go into the Blu Ray's output setup. you can choose 480p 480i 720p 1080i and 1080p. Set it for 720p that should clear up the issue.You may have to run Component directly to the TV since you only have 1 HDMI input and you can run Digital coax or optical to your AV receiver for audio. On a 50" TV the difference between 720p and 1080p using "GOOD" cables cannot be seen by the human eye. Above 50, yes it is noticeable.
Hope this helps.
May 22, 2009 | Onkyo TX-SR705 Receiver
Don't want to use receiver to turn Plasma on via Verizon DVR
You can not have a signal from cable/satelite TV when reciever is OFF.The only way is reconnect by using defferent setup configuration to illiminate the receiver.In that case you well see just regular Tv program but you should connect antena to your TV.
Apr 17, 2009 | Onkyo TX-SR705 Receiver
Remote Control Not Communicating with TX-DS787
Hello, I am sorry about your issue. Your hook up should have nothing to do with the remote. You should get some functions like on/off, volume control. Thank you, Onkyo, USA
Apr 25, 2017 | Onkyo TX-DS787 Receiver
Onkyo TX-SV727
did you press the enter button on the remote to display the menu? Make sure that monitor out is connected to the TV.
Sep 29, 2008 | Onkyo TX-SV727 Receiver
Onkyo TX-SR702 keeps going into speaker setup mode
Los amplificadores de audio del aparato estan a punto de danarse,checa las bocinas una por una a ver si no hay alguna mala.
Apr 14, 2008 | Onkyo TX-SR602 Receiver
Re: ONKYO with New LCD HI Def Television
Hi Lucylu
I don't have a solution to your problem -- but I do have the receiver and want to hook up my Plasma TV through the ONKYO TX-DS474 receiver. Its a great receiver but am not sure it will "do the job" being so old in the tooth.
Hope you found a solution!!
Nov 18, 2007 | Onkyo TX-DS474 Receiver
Installed surround sound, no picture on tv
I could not get my TV to recognize an S-video signal from my reciever either. I ended up just bypassing the reciever and running the video straight from the cable box to the TV. It might be a better option anyways as some quality is lost if you run it through the reciever.
Mar 20, 2007 | Onkyo TX-SR602 Receiver
Onkyo TX-SR602 Receiver Logo
551 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
