Back to:
Tags:
Velbon Ultra MAXi Tripod
One Leg has loss it's grip. (by 2 users)
posted by Punk Dolphin on May 26, 2007
I really love this tripod because it's super compact and portable, but has great height when fully extended. So I'm trying to salvage the one I have now.
The problem is the legs lock into place by turning the legs clockwise and unlock by turning counterclockwise. One of the legs seems to have lost some piece that keeps the segments together. When I extend that particular leg, it will slide all the way out of the tripod leg cylinder. There are three segments to the leg, so each segment, except for the last segment closest to the tripod, can slide directly off the tripod when loose.
Any solutions besides buy a new one?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by cinegirlsc, posted on Mar 27, 2008
One leg slides out completely - won't tighten, and, yes, the band that should hold it in place is split. How do I repair this? It is a set of G1349 legs.
Best Solution
posted on Jun 07, 2007
Helpful (85)
sblood
Rank:Master Master
Rating: 83%, 30 votes
take it apart, there is a rubber ring like a belt or rubber band, either broken or missing. you will have to find a relacement for that, may have to take apart another leg to have one to compare, course I don't honestly know where you will find that piece. too take it apart just keep spinning the lock counterclockwise until it comes off. good luck.
Rating Locked! (?) Punk Dolphin has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on One Leg has loss it's grip.:
I don't want to Accept this solution
Can you Help with these Tripods problems?
Tripods
This is the handle that lossens and tighten the mounting...
Tripods
Where can I send my bad Gitzo tripod? One of its legs...
Tripods
Where can I get a replacement for the quick relase plate...
Tripods
should not support SD card
Tripods
Hi, I have a Focal (K-Mart) model# 20-08-87 that has...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
