Question about Linksys Wireless-N WRT150N Router
How can i configure the router WRT150-N - Linksys Wireless-N WRT150N Router
  • Tyler G May 11, 2010
    what do u wana configure it to do?
  • 88 Answers
Access the router setup page by opening a browser and visiting http://192.168.1.1/. The default login and password for my new router was admin/admin. If that doesn’t work try logging in as admin without a password.
This will take you into the router to set it up.
Posted on Feb 13, 2009
WRT150 router will not connect to isp
CALL THE COMPANY OF THE MODEM OR THE PERSON OF YOUR ISP OR LOOK UP THE NAME OF THE BRAND ON THE INTERNET
Feb 04, 2014 | Linksys Computers & Internet
Wrt 150 router windows install
CALL THE PEOPLE OF THE MODEM OR THE INTERNET SERVICE PROVIDER OR LOOK UP THE NAME OF THE MODEM ON THE INTERNET
What is the default password for cisco
There are two main methods to return a Cisco router to its original factory defaults. These two methods are described below.
Method 1
1. uses the config-register 0x2102 command in global configuration mode.
2. Check the configuration register on the router by issuing the show version command.
3. The configuration register setting is displayed in the last line of the show version command output and should be set to 0x2102. If this is not the case, enter the config-register 0x2102 command once in global configuration mode.
router#configure terminal
router(config)#config-register 0x2102
router(config)#end
router#
4. If the show version command is issued again, the same line in the command output will have '(will be 0x2102 at next reload)' appended to the current register setting.
5. Erase the current start-up configuration on the router with the write erase command.
Reload the router with the reload command. When prompted to save the configuration, DO NOT save.
router#reload
System configuration has been modified. Save? [yes/no]: n
Proceed with reload? [confirm]
Once the router reloads, the System Configuration Dialog appears.
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]:
The router is now reset to the original factory defaults.
Method 2
1. uses the config-register 0x2142 command in global configuration mode.
2. Enter the config-register 0x2142 command in global configuration mode.
router(config)#config-register 0x2142
This causes the router to ignore the start-up configuration on the next reload. If a show version is issued, the last line in the command output will have '(will be 0x2142 at next reload)' appended to the current configuration register setting.
3. Reload the router using the reload command in enable mode. It is not necessary to save when prompted to save the system configuration.
router#reload
After the router has reloaded, the System Configuration Dialog appears.
4. Enter no to the question "Would you like to enter initial configuration dialog?"
5. Change the configuration register setting to 0x2102 by entering the config-register 0x2102 command once in global configuration mode.
6. Issue the write memory command in enable mode to overwrite the existing start-up configuration with the current running configuration.
7. Reload the router with the reload command in enable mode.
Once the router reloads, the System configuration Dialog appears.
Note: The configurations below are stored in ROMMON, and cannot be reset to Factory Default Settings by the write erase or config-register 0x2142 commands.
warm-reboot
memory-size iomem <not default>
Jun 18, 2013 | Computers & Internet
Cannot connect to 192.168.0.1
How you connect to the router configuration page is depended upon how you have your router management configured. I believe by default belkin routers allow for remote configuration so if you didn't configure any security on your router someone may have altered your configuration.
The default method for configuring your router requires.
  • An ethernet cable plugged from your computer to a LAN port on the router
  • The correct Gateway address (Start > Run > Type "CMD" at the command prompt type "ipconfig" look at your gateway address
  • In a web browser type in http://192.168.0.1 in this example
If you still can't access it I'd suggest pressing the reset button on the back of the router and re-configure the router in case of tampering.
Comment if you need any further assistance
Oct 27, 2011 | Gateway Belkin 54g Wireless DSL/Cable...
How do I password protect my linksys wireless n router? I have the wrt150-n and there are way too many menus to choose from when it comes to security settings and I'm not a techy. I just don't want to...
HI ,
1)Access the router’s web-based setup page.
2)When the router’s web-based setup page appears, click Wireless then Wireless Security.
3)Under Security Mode select WEP.
4)Under WEP Encryption select 64 bits 10 hex digits.
5)Type a wireless network password of your choice such as “MySecretKey,” then click Generate.
6)The result will be a string of random characters. Copy the resulting string since this will be the key to your wireless network
7) Click ``Save Settings``
Oct 22, 2009 | Linksys Wireless-N WRT150N Router
Just purchase a Linksys WRT150-N Wireless Router. I can't connect to the internet using the connections suggested
First, check if the devices that you're trying to connect this router supports wireless encryption protocol-N (802.11N). If the devices do support then enable WLAN-N standard by following the manufacturers recommendations.
Then try connecting.
Oct 17, 2009 | Linksys Wireless-N WRT150N Router
Connect wirelessly to wrt150 without a cd on a mac
Try this Link
http://www3.nohold.net/noHoldCust56/Prod_6/KnowledgePortal/KPScripts/amsviewer.asp?docid=bea8c897d15545479bce1c15b83f586d_KB3688_EN_070328_v1.xml&amsstatsid=6864192
Jul 11, 2009 | Linksys Wireless-N WRT150N Router
I cannot setup my WRT150-N router to work with my Wildblue Satellite Internet.
Jan 05, 2009 | Linksys Wireless-N WRT150N Router
Making linksys wireless router as access point
I searched the web for 45 mins. and cannot find info for you. I even downloaded and read the manual.
Call Linksys @ 1-866-870-5819 level 2 support.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 17, 2008 | Linksys Wireless-N WRT150N Router
Router configuration
i sujject you learn CCNA - cisco certified network associate course ware .. then you can configure most of the routers with slight syntax changes
good luck
Jan 15, 2008 | Actiontec GT704WG Wireless Router...
Linksys Wireless-N WRT150N Router Logo
130 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
