Question about Viking Refrigerators
Viking Ice Maker Leak
My viking ref ddbb363l-ss has a leaking ice maker that is dipping into the ice bucket and creating a gaint frozen lump of ice cudes. Does anyon know what is causing it? Do I need a new ice maker? Any help would be greatly appriciated. Thanks.
  • discola Jan 06, 2009
    I didn't buy the unit it was installe when I bought the house...How do I get instructions to clean the float? Thanks
  • 700 Answers
Have you cleaned the machine lately? the float may be dirty and getting stuck and not shutting down the water as it should.
Posted on Jan 06, 2009
  • Todd Born
    Todd Born Jan 07, 2009
    theree should be a sump wherer the pump pumps oout the water from. look there and that is where the float is usually to clecn all you need is white vinigar and let it cicrculate through the system for a coule of miniutes and then rinse it resak good.
Where is the ice maker control on the Viking 2005 regrigerator
I've maker arm above bucket . 2005, thr bucket can overfill that unless the shelf is in place. There is a new ice maker and arm assy which will help that in the future . Hope this helps
May 24, 2014 | Viking VCSB423 Side by Side Refrigerator
1. Not making ice 2. Freezer temperature not cold enough
Turn ice off for 12 hr's. You will prob. have to call a service man. Buy ex. warranty on all ref. with ice maker
May 07, 2014 | Viking Refrigerators
Still leaks
it is condensate from the auto defrost bin/drain pipe,locate and clean with clorine bleach(stops nasties growing....)
Jun 02, 2010 | Viking 42 in Built In Professional...
Ice maker on a viking side by side not working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
ghd65
Mar 21, 2010 | Viking VCSB423 Side by Side Refrigerator
Just moved into a new how with a Viking DDSB423D. The icemaker was turned off. When I turned the ice maker back on, I started getting a slow leak under the front of the freezer side. When I turn ice...
Hello there again:
if you can also remove the kick plateat the bottom of the refrigerator and inspect under there too
and also if you are done in the chat room could you please do me a favor and press the end session box and rate the session for me
Jan 01, 2010 | Viking DDSB423D Side by Side Refrigerator
How do i turn my ice maker off? i have a viking side by side and the ice maker is just pouring water in my freezer...its a mess!
Turn the water off under the sink where the small line starts that goes to the fridge or there may be a cut off directly behind the fridge in the supply line.
Your water inlet valve may be stuck open. It's where the water supply connects to the fridge.
Dec 11, 2009 | Viking VCSB423 Side by Side Refrigerator
Viking freezer leaking
you have a clogged drain, it is either clogged with ice or some kind of debris, thaw the freezer out and push a length of weed trimmer line down the drain. The drain is accessible by removing the back wall of the inside of the freezer. If there is no clog then the drain may be freezing up, if that is the case, take a piece of 14 gauge romex wire and loop it several times around the heating element at the bottom of the evaporator and push a few inches of it into the drain, this will get hot and transfer heat when it goes into a defrost cycle which is where the water is coming from in the first place
Jan 01, 2009 | Viking 42 in Built In Professional...
Viking VCSB423 side by side icemaker
You could empty the bucket when full for the days leading up to a party and save the ice somehwere......or buy an Ice machine
Sep 12, 2008 | Viking VGSC306-4B Gas Kitchen Range
Freezer ice maker not making hardly any ice
if the temperature of the freezer is above normal (0-5 degrees) the icemaker will not function properly -- you've probably got sealed system issues -- listen to see if the compressor is running -- if so, more than likely have either a leak or a restriction in the sealed system -- if less than 5 yrs old -- call the manufacturer, it might be covered.
Dec 13, 2007 | Viking DDBB363 Bottom Freezer Refrigerator
Refrigerators Logo
914 people viewed this question
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
