Hi Rolando,
You can download the manual copy of Printer at
http://downloads.dell.com/Manuals/all-products/esuprt_printers_main/esuprt_printers_color_laser/dell-1320c_user%27s%20guide_en-us.pdf
I am copied information for you. Here is the information for reset of printer.
Using the Reset button
Your printer is supplied with an electric leakage detector, which prevents electric shock or fire due to electric leakage by automatically cutting circuits inside the
printer.
When electric leakage is detected, the
Reset
button is tripped. In this case, press the
Reset
button to turn the printer back on. If the
Reset
button is tripped
again after you press the
Reset
button, contact Dell.
Check whether or not the electric leakage detector is functioning at least once a month by following the steps below:
1.
Turn on the printer, and then press the
Test
button.
l
If the
Reset
button is tripped and the printer is turned off, the electric leakage detector functions
correctly. Press the
Reset
button to turn the
printer back on.
l
If the
Reset
button is not tripped, contact Dell. Do not continue to use the printer if the electric
leakage detector is not functioning.
Let me know if issue is fixed.
Regards
VIkram
