My washing machine wont empty - Washing Machines
  • j_peck Jan 07, 2009
    ive checked the house pipes no blockages in any of them pump seems to be working it will now empty on one cycle but not on others
  • Washing Mach... Master
  • 19,396 Answers
If the machine does not drain start checking the drain hose.
If the drain lines are not clogged, then you will need to access to the drain pump, and clean it , or replace it if it is not working.
Machine not draining can also be caused by a defective timer control, but this is rather unfrequent.
See also : It won't drain
This seller also have replacements and delivers worldwide.
Posted on Jan 06, 2009
Drum wont turn or empty water
depending on the model, a broken belt is a good possibility. if you hear the motor going, but the bowl isnt moving, that is a sign of a broken belt, it is also possible the motor has failed.
Nov 11, 2013 | Washing Machines
Zanussi z918 washing machine wont empty or spin although the pump seems to work
if the pump seems to work, check outlet hose for blockage/check pump filter as well
Dec 09, 2011 | Zanussi Washing Machines
Drum does a small turn then stops but wont empty -wont wash either beko 1000 rpm
Hi if your beko 1000 spin washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Aug 23, 2009 | Washing Machines
Hotpoint wma13 wont empty, think pump is blocked
Yes,
The water pump most be clugged and/or defective.
Aug 18, 2009 | Washing Machines
Washing machine wont empty removed screwable filter all water ran out still wont empty
This is a comment problem. The drain pump may be broken or jambed with lint from the clothing. Remove the pump and check its operation. I usually just replace the pump as they dont last.
May 12, 2009 | Washing Machines
Candy 136cn washing machine wont empty
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Feb 01, 2008 | Candy CNW136 Front Load Washer/Dryer
hi there this is a common fault empty the water into a bucket and remove the water pump to check for blockages, the pump is located at the rerar lefthand side of the w/m.
also check your drain hose where it connects under your sink.
hope this helps
Dec 11, 2007 | Washing Machines
Washing Machines Logo
121 people viewed this question
Top Washing Machines Experts
