Question about Radio Communications
Palomar 150watt bi-linear amplifier for c.b. radio-SHORTED
When you check continuity between the red power wire & black ground wire, there is a diffenent short. I've checked several things,but can't locate the SHORT!
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
Turner dm 7800 base mic wires came away from the ciciut board where do they go? black and white can you help.
also wiring for astatic d104-m6b mic to lincoln can you help please
Posted on Aug 04, 2009
  • 55 Answers
OPEN IT UP THE SHORT MAY BE WERE THE 2 POWER WIRES COME TOGETHER AS THEY ENTER THE RADIO THIS HAPPENS ALOT OR DESOLDER ONE OF THE WIRES OFF THE CIRCUIT BOARD AND CHECK FOR A SHORT ON THE WIRES AGAIN THIS WILL TELL YOU ALOT IF IT IS THE WIRES OR IF IT IS ON THE CIRCUIT BOARD GOOD LUCK
Posted on Feb 21, 2009
How to repair a palomar 450 fet. Ld amplifier.
sniff around inside ,see if there is the smell of burnt wire or other componants.If it turns on see if there is a componant that starts to smoke.If it does change it and see what happens.this is called trouble shooting.
May 15, 2014 | Palomar Redman Cb Stop Hd 450-fet Hd 10...
How do i know if my palomar 250 is a high drive or low drive amp
If it is made by Palomar and it is a small amplifier, you can bet it is a low drive. Check those transistors. It could have the new Mosfet 655's in which case definitely low drive 3-6 watts input max.
Mar 30, 2014 | Palomar 250 SSB/AM Linear Amplifier for...
Need to know how to hook a palomar 450 HD to a connex 3300hp
If its in a car or truck use heavy gauge wire to power it. I use a 3ft jumper between the radio and amp. Should use a grounded antenna system. Not a "MAG MOUNT" type. Those can "feed back" rf to your radio and cause problems. If using in the house, a large power supply will be needed.I own a palomar elite 400 hd.It uses every bit of my 30amp power supply. Your hd amp should like the hp radio.
Dec 04, 2012 | Palomar Redman Cb Stop Hd 450-fet Hd 10...
How do i fix a weak cb radio transmission
Before having a fix on your rig, borrow from a buddy
a SWR meter, measure the power rating of your radio.
It should be having at least a power of 4W with a good SWR of 1.1 to 1.5.
That power would be a match for amp like these:
http://www.cbradiomagazine.com/Amplifier%20Reviews/Palomar%20Elite%20250/Palomar%20Elite%20250%20Review.htm
Sep 19, 2012 | Cobra 29 LTD CB Radio
Toyota tacoma 2007 stereo wiring Colors for the following wires: Power-ignition Ground
Radio 12v blue/yellow + radio harness
Radio Ground brown - radio harness
Radio Ignition gray + radio harness
Radio Illumination green + radio harness
Factory Amp Turn-on N/A
Power Antenna N/A
LF Speaker +/- pink - purple +,- radio harness or amplifier
RF Speaker +/- lt. green - blue +,- radio harness or amplifier
LR Speaker +/- black - yellow +,- radio harness or amplifier
RR Speaker +/- red - white +,- radio harness or amplifier
Notes: If equipped, the amplifier is on the passenger side rear cabin wall.
Sep 13, 2009 | 2007 Toyota Tacoma
My palomar 150's relay will key as soon as you turn on the power. Plus, it has 6lq6 tubes in the final?? Aren't they supposed to be 8950's?
Nope, 6LQ6's are the tube used in most all Palomar CB linears. Most tube type linears of that class have one 6LQ6 driving two or three 6LQ6's. As far as the T/R relay keying as power is supplied, you have an electrolytic capacitor shorted in the Carrier Operated Relay. My advice: get a pro to fix it, as there is 800 to 900 volts DC at a quarter of an amp on the B+ circuit, which is more than enough to kill you if you make a mistake. Too many Hams and CBer's have died that way, I do not want you to have the same accident. Find a reputable repair guy, then pay the price. It's safer that way. Good Luck,
Longshorts.
Jul 15, 2009 | Radio Communications
Shorted out amplifier-for c.b.
well for one thing 150 watt is 146 watts higher than the fcc will allow!!!! well all i have to say is goodluck!!
Jan 06, 2009 | Radio Communications
Palomar 150watt bi-linear amplifier for c.b. radio-won't transmit
3W to 150? Now you got 1 W in and 1W out and a snapped resistor. I would look at the driver and or final, either something heated up bad and cooked the resistor or you might have a break in the pcb.
Good Luck, Tom
Jan 02, 2009 | Radio Communications
Ultra linear ul-600hc
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following. I'll assume that you've checked the amplifier's on-board fuses.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp almost certainly has shorted output transistors and will need to be repaired.
Let me know if you have any other questions.
Aug 26, 2008 | Ultra Linear UL-600HC Car Audio Amplifier
Alpine car cd player has no volume
It's possible that you have a shorted speaker wire. If one of the speaker wires is pinched, grounded or shorted it will cause the deck's internal amplifier to shut down. The easiest way to check is with a multimeter's resistance function. Remove the CD player and unplug it. Set your multimeter for "resistance" or "continuity". Attach the black probe to chassis ground; you can use the black ground wire in the deck's harness, clean dash metal, or the outer ring of your cigarette lighter. Use the red probe to test each of the speaker outputs in the harness: white, gray, green and violet. If you find a speaker wire that shows any continuity with chassis ground, then that's the cause of the problem. A speaker with a damaged voice coil may also cause the deck to shut down. To test this, probe the positive and negative leads of each speaker and test the resistance between them. For example, to test the left front speaker you'd put the red probe on the white wire and the black probe on the white/black wire. Each speaker should read a minimum of 3 ohms of resistance. If you get a lower reading then it might be causing your problem. If you don't find a problem with any of the speaker wires, then chances are the deck's internal amplifier has failed.
Jun 08, 2007 | Alpine CDE-9846 CD/MP3 Car Stereo
Radio Communications Logo
2,200 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
