It's set to heat and the fan is blowing cool air but the water from the jets is not warm. Any suggestions?
SOURCE: High Refridgerant Pressure
I was able to find the manual online which had the solution in the troubleshooting guide.
SOURCE: jandy 1.5 hp pump with jandy ae 2500 heat pump low flow
IF FILTER CUP IS NOT FILLING COMPLETLY THERE IS A AIR LEAK CHECK ALL HOSES AND FILTER FITTINGS
SOURCE: Jandy/Stealth Pool Pump motot
Hi .. If ypou are gtetting air in the basket, then ytou have a leak somewhere in the system. start by closing off the skimmer, bottom, cleaner one at a time and see when the air stops gettingt in. Is there enough water level to cover the skimmer? have you checked the seal on the strainer at the pump? you might be able top hear hissing if it is at the pump.
