Fit tanks in a container
I need to know how many tanks size is 1.10m diameter and 1.30m in height can I fit in a container with sizes 5.80m lenght, 2.30m height and 2.30m in width
  • Anonymous Mar 18, 2014
    A aquariaum measures 15 L, 9 W, volume 1350..what is the height?
I contact an export department for the solution
Posted on Jan 07, 2009
Bolt size for starter 92 tracker
mount starter mount
lost both?
they are both the same diameter.
the length is super easy, measure it.
the leaves, diameter, metric, 8 or 10mm and pitch
so using a box of random bolts with starter off
find one that fits, m8 or m10, or m12.
now you know the sizes, and with starter off the holes are right there. in front of you to test.
to get length, use drinking straw, and your thumb, nail
to find lenght fitted up by and then move straw to ruler, metric
ahhhhhh there is the lenght in 5min work.
if no bolts in the scrap box, at all, metric, buy some.
Oct 30, 2016 | 1992 Geo Tracker
Can I put full size spare in spare compartment on my highlander 2015
if it came with a space saver tire chances are the compartment was designed for a smaller diameter wheel. measure the spare compartment hole diameter and height and then measure a full size tire the same way for your car, to see if it will fit. not likely though.
Sep 06, 2015 | Cars & Trucks
Starter bolts
same as old (joking)
oh a trooper, those are rare here.
if you lost them ,
i measure the hole, in the starter, 8.5mm? a wild guess.
could be 10 or 12mm and is easy as heck to measure, that.
Id have gone to the store and got (my measured size)
both pitch sizes, in 8mm(guess) , and tried them. 1 will fit.
if you have the nuts still (you never said)
then use a pitch guage. $1 tool.
then the diameter ,yes, use a $1 mm rule. and read it.
now you have pitch and diameter, that leaves lenght
and id bet you can do that easy now. (the ruler)
Oct 20, 2013 | 1999 Isuzu Trooper
Recommended tire size is 2352/70/R15 can I change sizes?
I don't believe there would be a problem due to fit but this is difference in measurements.
The 75 diameter (across tire) is 28.88 in.
The 70 diameter is 27.95 in
The 75 width of tire is 9.25
The 70 width is also 9.25
The 75 circumference 90.72
The 70 circumference 87.82
The 75 sidewall height 6.94
The 70 sidewall height 6.48
The 75 revolution per mile 698
The 70 revolution per mile 721
The 75 speed at 50 and the 70 is 48.4
I can't see why it would not work.
Aug 03, 2017 | 2001 GMC Jimmy
I replaced the fuel tank on my 2007 hyosung 250. now i dont know where the hoses go. i need a diagram.
The hoses are all different diameters and only fit on the nipples that are the same size. Don't need a diagram for them. they only fit one way.
Aug 27, 2011 | Hyosung GT 250 Motorcycles
What is the difference between tire size 255/70 and 265/70
Hello Projocs03,
Tires are typically measured tire width (sidewall)/tire ride height/wheel size. The differences of the two tire sizes you published are .4 of an inch difference in width/sidewall. And about .55 in over all diameter which would impact you revs per rotation. Depending on your wheel size.
Attached is a comparison of the two given the variable of 17" rim.
Stock Tire >Search Tires Tire 1 - 255/70R17 >Search Tires Tire 2 - 265/70R17 >Search Tires Section Width: - - Section Width: 10.03 in 255 mm Section Width: 10.43 in 265 mm Rim Diameter: - - Rim Diameter: 17 in 431.8 mm Rim Diameter: 17 in 431.8 mm Rim Width Range:
Rim Width Range: 6.5 - 8.5 in Rim Width Range: 7 - 9 in Overall Diameter: - - Overall Diameter: 31.05 in 788.67 mm Overall Diameter: 31.60 in 802.64 mm Sidewall Height: - - Sidewall Height: 7.02 in 178.30 mm Sidewall Height: 7.30 in 185.42 mm Radius: - - Radius: 15.52 in 394.20 mm Radius: 15.80 in 401.32 mm Circumference: - - Circumference: 97.54 in 2477.5 mm Circumference: 99.27 in 2521.4 mm Revs per Mile: - Revs per Mile: 669.8 Revs per Mile: 658.2* Source http://www.1010tires.com/TireSizeCalculator.asp?action=submit
I added the above link so you can research further or change any variables you need to know. However, the most important thing to understand is the impact of your speedometer. Different sizes will have different impacts. For example going to a bigger tire will show a slower speed on your spedo that your traveling.
Good luck
May 25, 2011 | 1997 Ford Expedition
My calculator uses cr1616 or cr1620 coin battery. i was wondering if i could use a cr2016 or cr2025 instead.
The CR1616 and the CR1620 is a different size then the 2016 or 2025 The CR1616 is 1.6 mm diameter by 1.6 mm height the 1620 is 1.6 mm wide by 2.0 deep either of these will fit the TI-83 plus calculator and since the CR1620 is slightly larger it lasts about 20% longer. The diameter or the 2 batteries you mention is 2.0mm as that is what the first two numbers on the battery represent so it will be too wide to fit your calculator... The second set of numbers on the battery is the depth or height of the replacement battery... Best of luck
Feb 21, 2011 | Panasonic CR2016 Lithium Coin Battery
What size tires are on 2001 buick century
20021 Buick Century Sedan - Tire Size
If you have the standard factory 15 inch (diameter) x 6.0 inch (wide) wheels then the tires fitted were size: 205/70R15 (205 is the tyre width in mm and the 15 denotes the tyre bead diameter in inches for fitting to 15 inch wheels. The R denotes the speed rating of the tire).
The tires currently fitted to the car have the size moulded into the sidewall of the tire.
However I do not know if aftermarket wheels have been put on the car and if so a different size tire from the standard factory fitment may have been fitted to the wheels.
I hope this helps.
Dec 13, 2010 | 2001 Buick Century
What engines will fit craftsman dyt 4000 (18.5 blew w/ 290 hours)
Hi there
The only thing you have to do is have the size (diameter) and lenght (from cranckcase to end of shaft) of the shaft you have on your b&s and just go to your local Honda dealer , give them your shaft size and they should be able to give you all the options for a brand new motor . I really believe you can get a Honda 20hp model GXV620 or a 24hp model GXV670 that will replace your B & S motor .
Hope this help .
Sep 01, 2009 | Garden
Setting correct paper size
By trial and error I found that the paper is specified with the width then the lenght of the paper.
Even though the graphics show you that you are printing the image either vertical or horizontal I still wanted to know when I set up my non standard paper size of 24x 6 which was first the width of the paper or the length. I didn't see that in the manual. All our problems should be so small.
Thanx for the reply though
Apr 10, 2009 | Epson FX 1170 Matrix Printer
k24674
jasbo
jasbo
