Question about Tag Heuer 6000 WH1312.BA0677 Wrist Watch
Had a new battery fitted to my tag 6000 and now 2 of the dials dont reset to zero
    Problem Solver:
  • 13 Answers
To reset the chronograph dials back to zero do the following:
1) Pull the crown out to the position where the date can be adjusted and push the buttons.
2) Pull the crown out to the position where the time can be adjusted and push the buttons.
Posted on Jan 20, 2009
    New Friend:
    Problem Solver:
  • 5 Answers
It's easy to fix yourself! Unscrew the crown all the way and pull out until it reaches the stop position. Then hold both buttons down until the second hand does a full rotation around the clock face. Now yu can use the top button to adjust it forward a second and the bottom button to adjust it back. Mine sometimes doesn't respond but if you keep trying it will work and you can reset it without sending it off to get it fixed... hope this helps - from www.zigzag.digital!
Posted on May 12, 2016
My tag heuer carrera stop watch doesnt reset properly, when u reset the stopwatch it goes one minute behind and doesnt reset to zero. how do i fix this. it never resets to zero and the red hands on the sub...
Try this.
Pull the winder out fully. Then press the top right chronograph button to move the centre seconds hand on. Then push the winder back in.
on some models you should only pull the winder half way out.
good luck
Sep 23, 2010 | Tag Heuer Carrera Tachymetre CV2013.FC6206...
I have a Victorinox ST1500. Since fitting a new battery when I reset the dials they no longer go back to the zero/12oclock position.
I can find no manual for this watch, so can only offer a general solution. With this type of watch there is usually a means of setting the dials to 'home' position. Reset the dials, then pull out the crown (this may have 1 or 2 different positions) and try pressing each of the top and bottom buttons and see if the 'dials' move. Sometimes, some are set with the crown in one position and others when it is in another position. Trial and error should allow you to set the dials to home position. Once you've done that, press the crown back in and retry the stopwatch.
Jul 12, 2010 | Watches
The outer ring with minute graduation
This watch is no longer made but you could contact them by going to http://www.swisswatches.co.uk/watch/1195/tag-heuer-6000-series/ and contacting them about this.
Jun 25, 2010 | Tag Heuer 6000 Quartz WH1111BA0675 Wrist...
The chronograph hand of my TAG Formula1 starts at 2 seconds to 12 not at 12 o clock also after reset it stops at this point. What could be the problem?
If you pull out the crown to the first stop, then press the start/stop button that should move the second had on one second per press. The reset button moves one of the other dials. If you pull the crown out to the second stop, the start/stop moves the minute hand on, and the reset button moves the other small dial round.
Feb 19, 2010 | Tag Heuer Formula One
Stop Watch not resetting
pulling the crown out to position 2 and pressing button to zero it out one increment at a time is the way to do it do touch the watch hands. Works on fossil watches as well as tag watches
Aug 27, 2008 | Tag Heuer Kirium Ti5 CL1181.FT6000 Wrist...
Replacement bracelet for Tag Heur 6000 series, model #WH1151.BD0678
I have two tag 6000. one of the watch bands broke and I found a great fix. look on ebay for a rubber band called for rolex presidents. it fits the tag and the ribbing goes perfectly with the watch style. a easy and inexpensive fix, although you loose the stainless band...good luck
Aug 02, 2008 | Tag Heuer Link Automatic Chronometer...
Re-set quartz chronograph sweeping second hand
Easy Soultion worked for me. Believe Me I was worried only had the Seiko Sportura for a week now. My second dial for the stopwatch was re-setting to 5 seconds instead of zero. The Solution is
1. pull the Crown all the way out ( In the position you take the crown to set the time , second click ).
2. To set the minute face of stop watch , keep pressing the top button untill it is zero. To set the second needle to zero keep pressing the bottom button untill it reaches zero or where you like it to re-set each time. Depend on you.
3. Once all neddles of stopwatch are at resting postions ( usually zero) secure the crown back to its normal postion. Test your stop watch , hopefully it will go back to zero when you press the reset button. C
Glad to help. ashfaque.r@googlemail.com
May 18, 2008 | Seiko SNA553 Alarm Chronograph
Tag Timer Resets to Wrong Time
Unscrew the crown and press the lower button, this should advance the minute counting hand one press ata time. Pull ot the crown a further stop to advance the seconds hand and again to advance the tenths counter.
Nov 04, 2007 | Tag Heuer Watches
Reset Stopwatch Hands on CL1111 ?
Try setting the crown to position 2 - i.e. the position normally used to adjust the date.  Then use the top and bottom stopwatch buttons to adjust the minute hand and 1/10th hand respectively.
Oct 18, 2007 | Tag Heuer Aquaracer Quartz Chronograph...
Tag Heuer 6000 WH1312.BA0677 Wrist Watch Logo
373 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
