Question about Xerox Phaser 7750DN Laser Printer
Xerox Phaser 7750 parts
Trying to get a Inverter Transport assembly (Part No 116180900), not having any joy with xerox, they keep giving me phone numbers which only get to consumables not parts department. Need a UK phone number for parts or a Xerox Engineer.
Hi, I have 2 broken down phaser 7750 machines for spares. 250V. Perhaps I can help but I am in Nairobi, Kenya!
Posted on Jan 06, 2009
    President:
  • 2,072 Answers
Google " the parts drop" . Call Britt and see what he has. He should have one of those.
I don't work there but you will never find anyone better to deal with.
Ahh here is his phone number 201-387-7776. Tell them Rick said Hi.....
I have xerox phaser 7750 by mistake i bought 7760 yellow toner shall install it to 7750
Not yet, check with the supplier and ask if it is compatible with the 7750, if not then exchange the 7760 for a 7750 yellow toner cartridge. Once you open the cartridge the supplier will not exchange.
Apr 22, 2013 | Xerox Phaser 7750DN Laser Printer
Tip
XEROX PHASER 7750 7760 FAN ERROR.
Hey guys this is a Xerox Phaser 7750 and 7760 fan error video tutorial.
In this video you will learn how to fix the error code 48 on the Xerox phaser 7750.
Also you will learn how to fix the error codes 010-391,010-392,010-398 that are related to the Xerox Phaser 7760.
This video shows how to remove covers.
All the wires that you need to disconnect from the machine to fix these errors.
There is also another video part two that shows you how to reinstall everything back
in it’s place. Step by step tutorial hope you enjoy.
http://www.youtube.com/watch?v=yMud-Md2xpc
on Dec 30, 2009 | Office Equipment & Supplies
We just replaced the Belt Cleaner Assembly on our Xerox Phaser 7750 printer and still get the message 'replace belt cleaner assembly. Do we have to push a reset button or something? Phil Biebl,...
Yes, you have to reset this. From the main menu scroll to "Supplies Info" and hit OK. Now scroll down to "Reset belt cleaner Assembly Life" and press OK. Good luck, and thanks for using Fixya!
Sep 01, 2011 | Xerox Phaser 7750GX Laser Printer
I am looking for parts list for a XEROX Phaser 7760 we got a service manual but no parts list need to find feed rollers and one way bearings for # 4 &5 trays ASAP any one able to help
600K78460 Roll Kit (3 Rolls/Kit) but they are the same as a 7750
the bearings don't have no number on the 7760 service manuel.
but you can check this manuel for the 7750 they should be the same.
http://www.office.xerox.com/userdoc/P7750/7750_Web/partslist/index.html
Nov 05, 2009 | Xerox Phaser 7760DN Laser Printer
I have a xerox 7750, error code 9-913
This problem occurs when you buy the wrong image unit.
The contact chip that is located at the bottom of the orange plastic is not for the machine. Replace it with 7750 image unit and that should fix your problem. Black is fault 9-910 cyan fault : 9-911 magenta fault: 9-912 yellor 9-913.
Sep 24, 2009 | Xerox Phaser 7750DN Laser Printer
Grainy image quality on my Phaser 7750
Try something, Send a job with 5 pages to it.
Shut the machine off as a page it halfway out of the exit area.. Open the machine and look at the jammed copies. Are they clear in the imaging unit areas but not upon exiting the machine?
If the image is clear around the drums and imaging unit, then the problem would be in the fuser. If the image is grainy and fuzzy in the image area, You could have a bad second BTR roller, the soft black roller on the left side door. One of the developer housings could be bad. You have to remove the imaging units and look in the opening with a flashlight to see if the developer housing brush is thick on the developer roll.
Could have a bad transfer belt or one of the color housings could be bad.
Less likely is a bad laser. But have you taken the wand that is on the front cover and cleaned the laser exposure slots?
May 14, 2009 | Xerox Phaser 7750DN Laser Printer
Xerox phaser 7700 paper feed transparency errors
There is a Transparency sensor (called the OHP) which is part of the Registration Transport 116-1164-00
Clean it first. Or replace the whole assembly
Whit
Item, Inc.
Mar 24, 2009 | Xerox Phaser 7700DN Laser Printer
Phaser 7700 Accumulator Belt Replaced, upon startup there is an error
POSSIBILITIES
Problem:
1st BTR Contact Failure or 1st BTR Retract Failure Message is displayed after replacing the Accumulator Belt Cause:
A Phaser 7700 Accumulator Belt was installed in a Phaser 7750. The Phaser 7700 Accumulator Belt does not have retractable 1st Bias Transfer Rollers; so these errors will be reported if one is installed in a Phaser 7750 printer. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Remove the Phaser 7700 Accumulator Belt and install a Phaser 7750 Accumulator Belt. TRY FIRST (Solutions without parts):
1. Check that all shipping restraits have been removed.
TROUBLESHOOTING TIPS AND HINTS:
1. Test the 1st BTR motor in diagnostics to verify proper operation. 2. Test the 1st BTR sensor in diagnostics, then run the 1st BTR motor test and recheck the 1st BTR sensor. Sensor state should alternate between L and H. The sensor is part of the accumulator belt.
PARTS:Parts are listed in the order of highest probability for repair.
NUMBER QTY DESCRIPTION
116177400 1 *KIT IBT - UNIT
REPAIR/INSPECT/PREVENT PROCEDURE:
1. Clean feed rollers, exit rollers and guides; replace if
necessary.
2. Clean feed rollers and exit rollers only when dust or
debris is visible.
3. Remove and clean all paper trays.
4. Clean the Laser Scanner Unit window.
5. Inspect the image density sensors; clean if necessary.
6. Inspect the accumulator belt home sensor; clean if
necessary.
7. Inspect the fuser assembly; clean if necessary.
8. Print the Error Log, diagnose and repair any problems as
indicated.
9. Print the Usage Profile, diagnose and repair any
problems as indicated.
10. Check version of all installed firmware; as
appropriate, install the latest version of firmware.
11. Check cleanliness of interior and exterior of printer,
including fans; if necessary, clean (dust or vacuum) these
areas.
Problem:
Jan 25, 2008 | Tektronix Phaser 860DP Thermal Printer
Xerox Phaser 8500N front control panel LCD died
Want to resolve your printer issues online then, dial Xerox Printer Support Phone Number1866-877-0191 anytime as you like. For further Info Click:https://goo.gl/Co2Bom
Nov 26, 2007 | Tektronix Phaser 860DP Thermal Printer
Xerox Phaser 7750DN Laser Printer Logo
120 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
