Question about Krups Orchestro 889 Espresso Machine
Krups Orchestro Leaking
Hi There,
I have a small leak which drips under the unit and in the drip tray from somewhere internally whenever the unit is operated. I suspect this is something to do with a seal around the pump or somewhere but I don't know how to dismantle the unit correctly to get inside.
Is there any guidelines on how to do this and any advice on what the problem might be?
Thanks very much,
Chris
    Problem Solver:
  • 5 Answers
This is a common fault on these machines i have replaced every seal on mine and it still leaks,unless it is really bad i would advise that it be left alone.p.s they are a bit of cuckoo clock inside a proper strip and clean takes about two hours and the parts are hard to come by.
Posted on Mar 17, 2009
    Problem Solver:
  • 14 Answers
The water is clean or its coffee? if is clean, then replace the seal from the water tank. if is coffee, then replace the valve under the mecanic group.
Posted on Jul 07, 2009
It's leaking water from underneath the unit
Hi there, I know that most units have a drip tray at the back or under the unit itself. well the older ones anyway, not sure with really new ones, but they shoukd. these trays hod water condensation and any drainage from the fridge itself. These trays sometimes have a coil in them which heats and help to evaporate the waterso that it does not overfill and spill out. these trays can become overfilled, the heating elemet can stopworking or
Jun 01, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Hi, Franke Saphira. 'Empty Drip Tray' message doesn't shift when in descale mode - not in any other mode though, only when trying to descale. Any ideas? Cheers
If you keep the empty drip tray message, especially after making a drink or cleaning operation this points to a leak internally on to the drip tray contacts. or from the thermoblock leaking onto the wiring loom behind the front door panel. An engineer will be required to fix this as the correct seals will be needed. I have been a Franke Service Engineer for 15 Years.
Sep 29, 2010 | Franke Saphira Espresso & Coffee Maker
Krups orchestro art889 water is coming down into drip tray and coffee grout holder instead of the coffee dispenser
Most likely the main O-rings have to be replaced. There is an excellent step-by-step instruction available on http://www.kaffeemaschinendoctor.de/Downloads:_:30.html under Jura, Aeg, Krups - It's in German, but Google can translate it. This repair is not for the faint at heart, but it can be done. The O-Rings can be found in any decent hardware store.
Mar 26, 2010 | Krups Orchestro 889 Espresso Machine
Water is leaking internally onto the countertop and none going into the cup on solis master 5000
Hi
You boiler is leaking and needs to be replaced. Check partsguru.com or ebay for replacements.
Dec 11, 2009 | Solis Master 5000 Espresso Machine
Descaling?
With the selector buttons find Descaling and press OK
This process takes about 35 minutes
1. Empty the water tank, drip tray and grounds container.
2. Insert tray and grounds container, refill tank with with 0.5 Lt. of water and add descaling agent (not the pill or powder used for clean cycle) to tank. Make sure its completely dissolved.
3. Place a container or cup under the steam wand large enough to hold 0.5 lt.
Display says Descaling and press OK
4. Press the water button
Display says Descaling in Progress
after the descaling agent is exhausted
Display says Empty Drip Tray and Spent Grounds
5 Also remove rinse and refill the water tank to Max line
6. Press the water button again
after the machine stops
7. Empty the drip tray and spent. ground container and replace
Display says Rinse Press OK
Display says Appliance Ready
In essence go to Descaling Press OK and follow the directions as they are displayed.
Sep 07, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Descale
Aug 02, 2008 | Krups Orchestro Dialog FNF2 Espresso...
The krups coffee machine is letting out hot water but not coffee ?
If you find water in the spend grounds drawer or with the cup grid out you see water being dispensed into the drip tray your brew unit needs repair or replacement. If none of that is happening the tube that brings hot water to the brew unit is clogged.
May 24, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Cleaning and descaling Krups Orchestro 889
take a descaler solution never mind vinegar not strong enought 1part solution 1part water put that in our water container start the machine open valve let it drip for a few second untill you see the solution leave it like that for 10 minute after open the valve and do it again untill emty after you emty the solution clean water container very good fill it with water open the valve rinse very good because that solution is very corosif enjoy cheers
Jan 19, 2008 | Krups Orchestro 889 Espresso Machine
Krups Orchestro 889 Espresso Machine Logo
563 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
