Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Gaarage Door I'm opening the garage door manually. I disconnected the trolley to do this. When I lift up the garage door is there something to keep the garage door up. After I remove my hand off the handle the door just rolls back down. I dont know what type of mechanism is used to keep the door up. The door works fine using the remote mode.
  • 227 Answers
Have you looked on both sides of the door at the bottom there should be cables. If they are not tight you probably have a damaged spring. Look up between the door and where the roller mounts are, there should be a tightly wound spring. This is what keeps the door up, if tension is lost then it will come back down. If it is broken it needs professional attention.
Posted on Jan 06, 2009
How do i fix garage door that wont open or close?
You have to make sure the trolley on the drive engages with the catch on the door. You may have to lift the door to the point it will engage while you are running the trolley in the close mode. Check that the trolley latch is open and ready to engage the catch. There is usually a rope to pull on to do this.
May 16, 2014 | Chamberlain 950CB Remote Control
Sears garage door opener model 139.53919
The torsion springs might need adjustment.
Pull emergency release, and manually lift door to half-open position.
When you release the door, it should stay in place.
If it almost "slams" down, the springs are not doing their job to "balance" the weight of the door itself.
The opener isn't designed to overcome the weight of the unsupported (no spring assist) door.
Over time, the springs take a "set", and might need a readjustment
The springs are under tremendous pressure loading, and can even kill someone if they do not know what they are doing!
Feb 04, 2014 | Building Materials
1/2 horse garage door opener doesn,t open all the way. I need about a foot more lift. The tried a trolley stops before the stop limit..Therre is no interference. I Tried adjusting the up limit to no...
You said you adjusted the up limit already. Is it adjusted as far as possible? Usually the screw will become harder to turn. You mention a new door and spring but is the opener the same? My guess is you have a new opener as well and it is out of sync with the trolley. Try turning the up limit back and see if the trolley will stop shorter. If it does, loosen the chain or belt so that you can remove if from the opener's drive gear. Bring the trolley to your stop limit and put the chain/belt back on the gear. Adjust the chain/gear tension and try door operation again. If it was a sync problem, the door should close closer to your limit. Adjust up and down travel as necessary to fine tune it. This worked for me so good luck.
Sep 18, 2011 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Lift Master Pro Formula 1 only makes click sound
Is the door stuck in the open position? If so the trolley is probably jammed against the bolt just in front of the motor unit. Loosen the chain enough to free the trolley and then run the opener until the door is closed. While the door is closed locate the 'up limit' on the side of the motor unit and turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Apr 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door can be opened manually when the trolley has
You can adjust the length of the arm between the trolley and door so that it is in a vertical position when the door is closed. This will prevent your problem.
Oct 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opens 1 foot, then stops.
It sure sounds like you have a broken door spring. While you are at it remove the cover and take a good look at the drive gear. It is white nylon and is just in front of the motor. Might be stripped and unable to take the weight of the door.
Jun 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Lift-Master GDO goes up, not down
If the door operates freely without any binding, while operating it manually then It would appear that the obstruction sensor mounted across the doors path is ether out of alignment, lens dirty,or malfunctioning
Feb 21, 2009 | liftmaster Chamberlain Garage Door Opener...
Door will not open with or without motor
It sounds like that missing pin is your problem, the trolley attached to the arm with the pin. Its hard to diagnose, but call in a Door Opener guy and he can probably fix it in a few seconds for free. Otherwise, try and find the pin or something like it to fix the arm in place and see if you can MANUALLY operate the door that way. BTW, Disconnect from power before you try and experiment.
Feb 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Opening theGarage door manually
two problems. why aren't inner and outter trolley connecting. did you leave rope is disconnect position. Second problem is door springs do not seem balanced. you should be able to lift door halve way up and let go. it should pretty much stay there; go up or down slowly ok. fly up or crash down; need to adjust springs/cables or maybe wrong springs.
Jan 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
102 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Are you a Sears Building Material Expert? Answer questions, earn points and help others
