Question about Sansui Audio Players & Recorders
I am rebuilding a system left to me by my brother. I have a C77 Amp, a D300M Tape Deck and a B77 Power Amp, all with booklets and connection details. I also have an SE7 Graphic Equaliser, no booklet. I am using non Sansui Turntable and Tuner, all coupled to Sansui S65 Speakers. The speakers cut out at about 4.5 on the dial yet I always recall this system to be LOUD. The Equaliser is not connected as I don't want to guess and blow it all up. The top row of LEDs on the B77 don't fluctuate as they should, yet the very left vertical bank is fully lit. The LEDs on the 45 degree work fine. There is also an SR303 Reverb Amp, with booklet, not yet connected. Any help would be greatly appreciated. Tim
  • 199 Answers
tape monitor loop is not the same as simply having an output to a recording device and another input marked tape. These can be totally separate. This configuration is common in newer receivers.
True tape monitor loops are rare on AV receivers. These require two sets of jacks, one pair to break the internal signal path and send the signal out to the external device. The second pair to receive the output of the external device and reinsert it into the signal path.
A Tape Monitor is a two position switch that, in one position (usually marked "out), sends the signal from the tape monitor output directly to the tape monitor input. The signal path is all internal so nothing needs be attached for you to hear something in that position..
In the other position (usually marked "in" or some such), the signal path is broken, the signal is sent out of the receiver to the external device's input and the external device's output is then fed back into the receiver. If nothing is connected to those tape out/tape in jacks and the switch is in that position, you'll hear nothing.
By flipping that switch you can hear the effect of he eq. as opposed to no eq instantly.
One way to tell that you've got a "real" tape monitor loop as opposed to just inputs and outputs is to connect an interconnect between the outputs and the inputs. When you press the "tape monitor" button, you should hear the selected input in both positions. If it's not a tape monitor loop, you'll hear nothing in at least one position.
If you do have a tape monitor, the tape monitor jacks on the eq would replace the ones it used on the receiver. That's where you would hook up a tape recorder.
Posted on Jan 06, 2009
I asked 3 times now!!! How do I hook up together a Pioneer tuner, power amplifier, and dual cassette deck, together then hook it up to a speaker!!!
Are we a little impatient?
It's pretty straightforward. Use one cable to connect the tape deck to the amp. Use another cable to connect the tuner to the amp. Use speaker wire to connect the amp to the speaker.
Jul 26, 2014 | Audio Players & Recorders
How do you connect tape deck to pmp 4000
Hi, use the RCA/Phono connections for the Tape In & Out. The level will be set by the Master/Main fader. If that is not so convenient (& assuming it's a PMP4000?) there should be a "Main 2" output & connections with the level controlled separately to Main 1 via a Knob / Rotary control over to the right above the "Mono" fader... Hope that helps... Good Luck!
Jul 11, 2014 | Behringer Pmp3000 16 Channel Audio Mixer
Technics amp to tape deck connections.
Red for Right channel (play). White for Left Channel (play). Yellow for right (Record) Black left (record). The leads should run from tape (out) play to amp in play. Same for the left channel.
Record from tape (in) to Amp (out).
Jan 29, 2014 | Audio Players & Recorders
I have Bush MTT1 mini turntable and power, but no speakers. It says it has a built in equalized amplifier so can be connected to a music system. I have no music system. There is a split ead with red and...
You are mistaking the built in amp for a power amp. The built in amp only makes the deck loud enough when connected to a power amp. The Red and White cable are the Right (RED) and Left (WHITE) channels. There should also be some earth connections too. You need to get a power amp or system that has tape or aux connections. You can then get two phono plugs from your local dealer (only cheap) and solder the wires to the plugs. Main wire, to the main part of the plug and one of the earths to the body of the plug.
You can then plug them into the amp or system and that will then play.
Nov 10, 2017 | Audio Players & Recorders
I have an old kenwood stereo system I forgot how to hook up it is a ka-87 amplifier a kt-57 tuner and a double deck cassette player kx-57w .Can anyone help?
Connect the RCA Outputs of the Tuner to the RCA inputs for Tuner on the amp.
Connect the output of the Tape Deck to the Tape Input on the amp.
Connect the input of the Tape Deck to the Tape Output on the amp.
Select Tuner on the amp to listen to the tuner.
Select tape Monitor to hear the Tape Deck(s).
Dec 30, 2010 | Audio Players & Recorders
What is the funtion of tape out, tel, pre amp out , power out, vox, alc... & what is aux dfrs???
Tape out and tape in are to connect the record and playback leads of a tape deck. Pre-amp out is to connect a Power Amp to the unit. The pre-amp will only take the signals from the various sources and amplify them, but only to a weak level. The main reason people would use this is to connect a more powerful amp to the unit.
The Power out could be either the mains power for a turntable or for connecting a pre-amp or maybe to another to amp.
Haven't got a clue to the others sorry!
Sep 04, 2010 | Bogen Communication GS100 Amplifier
Sony tape decks model tc-355
Follow the left channel lead to where it joins with the PCB. Use a pointed tool and prod connections if you get a buzz then that stage in the amp is working. I suspect you will find it leads to a IC that might cause the fault. If you find it buzzers on the right but not left, then it's gone. PS don't short pins. If you can get hold of a signal injector it will make things easy.
Be careful and good luck.
Jan 08, 2009 | Sony TC-WE305 Single Cassette Deck
Connection between CD, EQ, SP technics
Each unit (the EQ and the Processor) should have left/right in/out rca jacks as well as L/R tape in/outs. The EQ or processor use the receiver's tape loop and then provide a tape loop to replace the one they've used on the receiver.
You plug the first unit (let's say the Sound Processor into your receiver/amp as if it were a tape deck (Processor's outs connect to reciever's tape ins (play) while the Processor's ins connect to the receiver's tape outs (record).
Then you chain the EQ off the Processor in the same way (EQ outs connect to Processor's tape ins (play) and EQ ins connect to the Processor's tape outs (record).
Last you connect the tape deck to the EQ as follows. Tape deck outs connect to EQ's tape ins (play) and the tape deck ins connect to the EQ's outs (record).
This will put both the Sound Processor and the EQ in the receiver's tape loop. In order to have all the receiver's source signals routed through them you may have to engage a Tape Monitor switch or button somwhere on your amp which will route the tape loop to your speakers.
Jan 09, 2008 | Technics RS-TR272 Single Cassette Deck
64 people viewed this question
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
Colin Stickland
Colin Stickland
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
