Question about Gateway FPD1810 18.1" LCD Monitor
I am thinking that I just need to give up my paper weight
I tried the connector that you have told me about. The one I had the connector for my portable cd player and I was using it for a power supply so I tried fitting the 12volt connector in the hole in the monitor but the plug in piece was too big it's wierd I think it a problem that I am just stuck with because the thrift store let it go cheap because the didn't get the cord that came with it. Thanks for trying to help me out. I'll be back
  • Jerry Sexton May 27, 2007
    I have tried Gateway. They told me since it's not under warrenty that I am out of luck. I tried looking at where Gateway liqidates thier spare parts through and no luck. I have treid google and now I found you nice people who are giving me great adavice on how I may try to fix it. I have looked into having it bulit but it's gonna cost me more than I really want to spend but it seems like it's the only option that I have. And $35 just to find out is more than I really want to spend on a paper weight. It looks great stiiting in my corner but it might have to find a new place to collect dust.
    Genius:
  • 2,985 Answers
Try the Gateway Tech support team or look on their site for accessories - they may well sell the power supply you need.
Posted on May 26, 2007
  • john ash
    john ash May 27, 2007
    I still think a universal stabilzed power supply as sold in places like Walmart will do the job.
    The units come with a strip of connectors
    each connector is a different diameter and has a colored tip.
    On the unit there is a slide switch which runs through from 1.5v through to 12v in 1.5 v increments.with a color patch to match the connectors
    Take the old power supply along to see if one of the various sizes match your existing[bust]one.
    Also somewhere on the monitor on the spec plate
    there be an indication of the operating voltage.
    It could be 18 v but I doubt it.
    Just look a little deeper into this.
    Here [in the UK] we have specialist component suppliers that sell everything that goes to make up electronic equipment- one is called Maplins
    www.maplins.com or www.maplins.co.uk
    It would be worthwhile just looking into the web catalogue to see what is on offer ,I am sure there are US equivalents from which you can sort out a power supply.
Paper keeps jamming in my fs2100 kyocera
One possibility regarding paper jamming is the weight of the paper you're using. For example some printers have difficulty feeding 20 lb. paper. I suggest that you first try loading your printer with a lighter weight paper, starting with 12 lb. paper. If that works, then move up to 16 lb. paper. If that fails, then consider cleaning the rubber rollers that control the paper feed.
Nov 02, 2017 | Kyocera Office Equipment & Supplies
I am having trouble trying to print card stock paper
110lbs?
that may be too heavy, try a few first then check if the printer will initiate printing.
Jun 26, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I HAVE A "CHECK ENGINE
If you follow the web link below it will give you instructions on the pins (there is a diagram of the connector) you short to get the Ck Engine light to blink out codes, the list of code is at the link as well.
http://www.extreme-check-engine-light-codes.com/GM%20OBD1%20Decoder.htm
May 31, 2011 | Buick Century Cars & Trucks
The best paper for the Lexmark X1270 printer
Hello. Your first consideration is paper weight. All printer paper, inkjet included, is measured in gsm or grammes per square meter. A very lightweight paper for your inkjet printer would be 60gsm. When you walk into any store and buy a **** (500 sheets) of inkjet paper you'll find that the stock on display is 80gsm. This is a general purpose weight paper suitable for photocopiers, inkjet and laser printers.
What if you need a heavier weight paper? This shoulnd't pose a problem in any well stocked office supply or computer store. Inkjet paper also comes in 90gsm, 100gsm and higher grades. You'll find that heavier papers give you crisper text and less ink bleed also. Do bear in mind that every inkjet printer has a maximum paper thickness it can handle. If you're buying paper in weights of 110gsm - 125gsm consult your printer documentation before you feed very heavy paper through it - otherwise you risk seriously damaging your printer.
Apart from the weights you also have a wide variety of styles. Paper for your inkjet printer can also be purchased in bright white variants. These are designed for single sided printing of important documents or presentation pages. This type of paper is more expensive but if your goal is to impress then it's money well spent as ther results are truly impressive.
Apr 19, 2010 | Lexmark X1270 All-In-One InkJet Printer
My printer will not feed the paper from the tray.
Have you told the printer what type of paper you are using? If,for example, you were using a heavy weight paper, like a 67 bond paper, and now you want to use a regular 20 pound paper, but have not told the printer about the change in paper weight, then the printer will not feed your paper properly. It is expecting to have to move 67 pound paper through the rollers which move the paper, but is encountering a 20 pound paper. That difference in paper weight will cause your printer to spin uselessly, trying to move a very light paper into the mechanism.
Try to set the paper properties to match the weight of the paper you are actually using, such that the paper and the mechanism, are equal and see if that makes a difference.
Dec 06, 2009 | Samsung CLP 300 Laser Printer
Canon super g3 fax machine ....
Paper should be of correct weight an fanned before installing into cassette.
Canon offers a very good and an American support center located in Virginia.
Call them.
Aug 13, 2009 | Office Equipment & Supplies
5300 won't load 8 1/2x 11 photo-weight paper.
''grabber'' roller out of work sometimes, you may try
1) there is a input paper sensor around roller, the roller out of runing if the sensor is not senitive enough or sensor switch dirty,
clean the sensor as you can find it,
2) Lighter-weight paper feeds and prints fine, which means this paper input sensor works ok, but you need to make sure they are same paper input sensor,.
3) the paper surface bright and the roller worn could be cause paper feed fail, you need clean the roller anyway. still not fixed, you need to adjust the roller pressure by increase the spring force.`
Feb 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Sony Cyber-Shot DSC-T5 "C:13:01 Format Error"
I had the same problem, you can solve this by:
1. Push the card multiple times in/out the slot or
2. Use a little bit of contact spray on a small piece of tissue, rap this in the length around the memory card just 1 time. Be carefull not to make it to thick that it get stuck in the slot. Then push the card multiple times in/out the slot or
3. Cut a small strip of waterproof sanding paper (grain: 400 or more - the surface feels just like paper, and is just a thin as paper) just as wide as the card or slot. Cut a strip of plastic (eg.old credit card) also just as wide as the card or slot. Rap the sanding paper in the length of the strip and insert this in and out the slot. But!! ... make sure you stay at the upper side of the contacts, don't worry just do it carefully, don't use force and sand the contacts a couple of times. This way work for me, finally!!
Oct 31, 2008 | Sony Cyber-Shot DSC-T5 Digital Camera
Printing on heavy cardstock
HP recommends papers with ratings of at least 90 for brightness and 75 g/m2 (20 pound) weight. before u proceed....remove the rear access door to reveal the rollers.Take a slightly wet cotton cloth and wipe the rollers in the upward direction 4 times.Close the rear access door. now do as said - START -PRINTERS & FAXES -CHOOSE THE PRINTER ICON THAT HAS BEEN HIGHLIGHTED WITH A CORRECT MARK. - RIGHT CLICK - PRINTING PREFERANCES - PAPER/QUALITY TAB - CUSTOM -Create a new custom paper size that is dependable on the paper you are using - type a name & SAVE -ok -ok -try printing if the problem still insists the report back and do mention which tool you are using for the printout. if its heavy pearlized paper then i do not think th eprinter would accept it . it maintains its own standard weight to detect the paper.
Sep 23, 2007 | HP Photosmart 3310 Printer
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
