Question about Microwave Ovens
I found few cockraches have entered the micro overn
  • Ashi Gani Jan 09, 2009
    Hi Rylee
    Thanks a lot for your quick support.
    Brigadier General:
  • 8,619 Answers
Hi
You need to tighten the screws of your oven's bottom lid and back lid . And also check for any cracks in the caseing .
Thanks
Rylee
Posted on Jan 06, 2009
MODEL R-8476
You may need to find a service person to check this for you, but it sounds like you may have a micro-switch for the door that has gone bad. I have run into this a few times and found that to be the cause. What happens is the bad switch causes a direct short when you turn it on and that blows the fuse to protect the rest of the microwave. Hope this helps.
Mar 25, 2014 | Sharp Microwave Ovens
Ge eterna m#em03000hbb01 micro wave runs for a few seconds,then all symbols in display light up,press clear,it resets then have to enter time,am or pm and date. will acircut board fix this?
Hi, we get microwaves all the time at my shop, look usually they cost more to fix than a new one. They usually have a limited life, I advise you to ask for a 'Quote" and go from there at least that way you know to repair or replace.
Apr 08, 2010 | GE Microwave Ovens
V ent on inside right of the overn
Hi the part you are refering to is called a wave guide cover. If it has developed a hole it will need to be replaced. this part can be obtained very easily at little cost from Sanyo or any reputable parts supplier
Jan 07, 2010 | Sanyo EM-Z2100GS Microwave Oven
One of the interior latches, or hooks,(rear) which hold the metal rack in place has melted and has begun sparking while the oven runs. Im wondering where to find a replacement and how to access the latch...
Ken, I have the same problem . . . I was told by the company that I need to replace the overn as the inside wall is burnt so it will happen all the time. . . have you found a soultion or heard any differently/?
Dec 07, 2009 | Whirlpool Microwave Ovens
Flashing inside micro when turned on after a few
Make sure the inside is clean of all grease and the paper like screen needs to be removed and cleaned also. If the screen is burned it needs to be replaced. You can find one at an appliance parts store.
Sep 03, 2009 | Microwave Ovens
My Model MH7140XFB-1 over the overn Whirlpool
There is an internal fuse. The cause for it blowing will have to be determined.
eric
Aug 06, 2009 | Whirlpool Microwave Ovens
Can't remove the vent grill
Two problems found. The electrician that installed the micro. installed it incorrectly. The fan was supposed to be turned so that the exhaust would go through the pre-installed duct in the wall. To remove the grill, there is two screws on top of the micro. which have to be removed. The builder put in a deeper cabinet that covers the screws because it looks better. To fix it I have to drop the micro, take off the grill, clean it and all the grease off the micro., replace the charcoal filter, turn the fan so it will exhaust through the duct and reinstall the micro.
May 27, 2009 | Kenmore 80412 Microwave Oven
Heat doesn't come on in microwave
If you have the experience with discharging a capacitor and you have a (VOM) Volt Olm Meter. Unplug microwave, discharge capacitor, and check the resistance of the two thermal cut-off discs by removing the lead and set VOM to RX1. If you don't get a reading of zero, replace the discs. For part go to www.partselect.com and enter your model number. If you found any of these suggestions helpful, please rate my solution. D. Lange
May 01, 2009 | Microwave Ovens
Egg cookers
I found the instructions
Sprinkle a few grains of salt on bottom of egg cooker. (Salt attracts microwaves and is necessary to help cook bottom of egg)
Break egg into egg cooker.
One egg in micro at a time.
Will fork piece yolk and white to bottom of cooker, three times. _ This is very important.
Line up notches on egg cooker lid and cup then twist until locked
Micro on High for 30 seconds
Let stand 10 seconds
If bottom of egg is not cooked turn egg over with a spoon and microwave on high for another 10 to 20 second or until cooked.
Dec 16, 2008 | Microwave Ovens
Water leaks into microwave oven
ok really if someone dareing enough to open the panel for microwave the shell i mean take to the porch let sun heat it for at least 2 days then go threw lightly wipe down insides of micro with water clothe to get water residue out of micro then place shell back on and screw down
once water gets into micro. its hard to tell how there performance will be after wards and putting a fan directly on a fan to airout wont help this will create other little problems like mold build up
the best thing is what i suggested at top you need a heat source to cook and evaporate the water inside which is the sun
Jun 02, 2008 | GE Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
