Question about Sony BRAVIA® DAV-HDX277WC Theater System with Wireless Speakers
My home teather dvd sony dav-hdx277wc dont power on,,
I have a sony dav-hdx277wc home teather..
the product work fine,,
but i change the receiver for other part of my house and
the legend please wait apears but dont hear audio from speakers or
response from the changer..
only the legend please wait,,,
and power off the sony demo apears ands works fine,,but power on only display please wait,,
i need help for solve this problem,,
thanks
welcomejee
  • 10594 Answers
SOURCE: SPEAKER WIRE CONNECTORS
You need 5 Cord (wires) Connection to attache all speakers.
You can have all 5 cords in one package or each cord individually at Sony Accessories.
Please write model number DAV-FR1 in search box to get result on above web page.
Details of wires required.
182724411 1 BAG = 5 CORDS approx $43
179146811 CORD, CONNECTION approx $10.30
Posted on Nov 10, 2008
  • 4 Answers
SOURCE: sony compact AV SYSTEM DAV-S400
Hi Joey - I had exactly the same problem.
In my case, I followed the advice of others and took the thing apart. On the main amp board there is a large brown capacitor. Mine had come completely loose, so I soldered it back in place with a good amount of solder to make sure the contacts were ok. I also dabbed some solder on the headphone connectors on the same board (just follow the wire from the headphone socket to the board). Well, when I put it back together and tried it again everything worked perfectly, and it has so far remained free from the error. Hope that helps !
Posted on Nov 27, 2008
SOURCE: S-Sir Sub Unit won't pair
In order to properly pair the units, verify that the channel switch on the back of the sub units are set to either A, B, or C. Then go into the setup menu and go to setup tab. You can then scroll down to system setup. Verify that the base unit is set to the same channel as your sub units A, B, or C. You then can choose the pairing operation. Have your sub units close to the base and on for this operation. They must be linked to have the pairing operation work. The pairing option will ask if you are ready to pair a sub unit. Select OK. You will then be instructed to begin pairing. Find the pairing button on the back of the sub unit and depress. Depending on the sub unit you may see a red light flash or the front display will say pairing. Once complete the menu screen on the TV will tell you that the pairing is complete and ask if you would like to do another unit. Continue if you have another unit or select OK to complete the process. Once you return to the system setup menu the channel indicator A, B or C will have the work pairing next to it (i.e A (pairing)). If you continue to have trouble you can change the RF channel on the system setup menu from AUTO to ON. Good Luck. CEB
Posted on Mar 22, 2009
I almost went out and bought a Sony HDMI cable but I tried something first and it worked me. I wrapped tightly the transceiver on the back of the main unit with aluminum foil and what do you know it fixed the problem. I guess since I was using a cheap HDMI cable the foil helped to shield out the interference. Sony HDMI cable $70.00 or aluminum foil 5 cents.  Let me know if this works for you as well.
Brent mevioradio.com
Posted on Apr 26, 2009
welcomejee
  • 10594 Answers
SOURCE: I have Home Theater Sony DAV- DZ151Kb. Display
Push power protect message appears when home theater got problem in amplifier output section and any output amplifier chip becomes bad, receiver set protection mode and refuse to power up to avoid further damage in circuit board.
It is very hard for novice to troubleshoot what output chip is defective out of six amplifier output ICs in unit, check by professional is needed to solve this issue.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Posted on Jan 14, 2011
Testimonial: "Thanks for the support, it really is a very good recommendation I will check if you are getting voltage to the integrated and review the external components. "
Won't do anything! push power protector keeps coming up, what to do?
One of the speaker outputs are burnt,need power board replacment (audio output board, not power supply) don't replace components on board since is very difficult
Aug 23, 2011 | Sony BRAVIA® DAV-HDX277WC Theater System...
Sony Home Theater System DAV-HDX277WC - I get sound and video when playing a DVD, but no voices. Tried many different movies. Any suggestions would be appreciated.
Verify that all speakers work for test tones first. The center carries most of the dialog. It's in the manual, as is your symptom (page 101).
May 21, 2011 | Sony BRAVIA® DAV-HDX277WC Theater System...
Dav-hdx277wc power protector keeps coming on cant figure out hwy have re-connect the system at least 6 times still saying power protector please help
Why don't you try it without any speakers connected. That would prove if the problem is internal or external. Then either isolate the external speaker path that's causing it or get the unit fixed (internal).
Jan 16, 2011 | Sony BRAVIA® DAV-HDX277WC Theater System...
I want to connect my laptop with HDX277WC sony home theater. I want to get the 5.1 sound. I can get stereo sound; but 5.1 is not there. My laptop has 5.1 sound
Your laptop only has an stereo output so it is not possible. I don't know if there is any gadget that you can connect to the usb, and get a surround output from a computer. You may wana check that out, and if there exist such a device it surely would have a software to go along with it.
Nov 25, 2009 | Sony BRAVIA® DAV-HDX277WC Theater System...
System works great with dvd, radio, and ipod dock. But when listening to the tv through the system, the sound is very low even when the volume is at its max.
It sounds like either the input selected to the receiver is wrong, the wires are not hooked up correctly, or the wires are bad. What type of connection are you using-RCA jacks, DVi connector, etc?
Jul 14, 2009 | Sony BRAVIA® DAV-HDX277WC Theater System...
Hook up Sony Bravia Home Theater DAV-HDX277WC
Hi....I haven't hooked mine to the TV yet.....building my cabinet now....but I did hook up the components to make sure they worked and just didnt include a TV on it. My S-Air wireless linked up the first time I tried it....I will say this though, the little wireless transceivers blocks you have to plug into the DVD player and the S-Air do not go in like you would think. They actually look like they are upside down when you get them in, and the must snap in very securely. Make sure they dont just LOOK like they are plugged in. Also, dont get em to far away through too many walls, Try linking it sitting right close to the DVD. Also remember the S-Air remote has its own volume control as well as other controls....
I know I wasnt much help but I just got mine and I will be back with more after I try the surround sound on the TV.
May 02, 2009 | Sony BRAVIA® DAV-HDX277WC Theater System...
I just bought a Sony Home Theater DAV seris but there was no remote. Are there buttons on the reciever that work like remote buttons?
most all theater systems come with a remote and it,s odd that your,s did not, usually their are certain functions that you can control from the head unit ,but nowadays you can program a universal remote to your brand that will be able to control the functions of your theater system ,but to make things easier, call the customer service dept of sony and tell them your model# and purchase it direct from the manufactuer, this remote will have set-up functions for your dvd menu,s and will be easier then having to get up off the couch to change settings , thank you ,hope this helped glenn
Mar 03, 2009 | Sony BRAVIA® DAV-HDX277WC Theater System...
Sony BRAVIA® DAV-HDX277WC Theater System with Wireless Speakers Logo
62 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
