Question about Epson Aculaser C1100 Printer
Inability to online printer
We are using this printer on a Windows network (win server 2003 + Win XP clients). The printer has been in use for some years quite successfully but has recently off-lined itself. I have tried switching the device off, rebooting the server and switching the device back on again but nothing I try is bringing the printer back online.
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
Polaroid PMP 120-4 driver
THere are drivers for Windows Server 2008, Windows Home Server, Win 64-bit, Windows Server 2003, Windows Vista, Win Server 2003, Win Me, Windows XP, Win Server 2008 R2, Windows 98, Windows 98 SE
I'm not sure if theres is a drivers for Win 7 or Win 8 so if you don't have one you should install Windows Vista or XP driver using compatibility mode
Dec 06, 2013 | Polaroid Pmp120-4 4gb Usb 2.0 Mp3 Digital...
Tip
I need Postscript drivers for Lexmark printer T630.
Hi.
This printer supports Postscript, PPDS, and PDF emulation only on systems up to Windows 2000, on Mac OS X up to 10.6, and on Solaris.
Windows 7and Vista are not fully compatible with this printer, and the printer will not have full functionalities on this systems.
If you have Win XP, Win dows Server 2003, Win 98, Win 2000 or Mac OS, then all you have got to do is installing full factory driver software.
If you have Windows 7 or Vista, then you should upgrade the printer to get full features. Lexmark has opted for not updating this printer software. Full software release for Windows Vista and Windows 7 does not exist.
The drivers and software for this printer can be downloaded from Lexmark website, using the links below:
Lexmark_AAG_WinXP_PS_Driver- Post script driver.
System PCL Driver for Microsoft Windows XP and Server 2003
System PCL Driver for Microsoft Windows 2000.
PCL6 driver for Microsoft Windows 95, 98 and Me.
Printing solution for Mac OS X v.10.6.
Print driver for Sun Solaris 10 x86 systems.
Network print support for Linux.
Here the full driver installation procedure : How to install a Lexmark printer without the driver and software disk.
The printer may still work on Vista and Windows 7 using the built in drivers, but it will have limited functionality. See: Windows 7 Information.
Regards.
on Mar 24, 2010 | Lexmark T630 Laser Printer
We Are Using Windows 2003 Server,But We Are Not Able To Access Server From Win XP & Win 98 Clients & Also We Are Not Able To Access Clients From Win 2003 Server. Please Help.
You must be on same domain/workgroup to see it and the computers should have an account on the server.
If not you MUST have a user account you are using on the server.
You can try to connect using the IP address of the server as such:
Go to start.run then type \\Serverip\c$ it should then ask for credentials
If not then your server is not on the network properly and you should contact a consultant in your area to configure the server
Mar 16, 2010 | Microsoft Windows Server 2003 Enterprise...
Cant configre printer sharing via web on win server 2003
Yes is possible. Use Routing and Remote Access facility from Windows 2003 server to create a VPN Server. Create a VPN connection to Windows server, and thus you get an IP address from windows 2003 server and you can use printer.
Jul 07, 2009 | Microsoft Windows Server 2003 R2...
Dhcp in server 2003 in domain not working
Windows 2003 server supports DHCP. If you don't see in Administrative tool DHCP maybe the DHCP role is not enabled. You can add this role in "Manage your server". You don't need to reinstall win 2003 server.
Another way to access DHCP management tool is: in command prompt type mmc and then File> "Add remove snap-in" then "Add" and select DHCP.
Jan 06, 2009 | Microsoft Windows Server Standard 2003 for...
Tm-t88iv epson made prnter driver for win 2003 server r2 std
Epson POS driver will not install on a Win2K3 machine due to the InstallShield Wizard w/c checks if your running XP/2K or not.
Download the driver from EPSON POS site & extract the contents first on an XP machine.(Installing the driver will create a C:\Epson folder where ACTUAL driver is extracted).
Dec 24, 2008 | Epson TM-T88IV Label Printer
Win server 2003's drive c: is access to all client computer
Kindly revert for further analysis - for the points below
1.as said above - have you shared c:\ for clients ?
2.Are you using Terminal server - without security policy ?
3.is Your client directing logging in the server ?
if not any of the above please explain - ur problems in point specification.
Regards,
Sushil
sushil.mudaliar@gmail.com
(mail me across in case of emergency)
May 27, 2008 | Microsoft Windows Server Standard 2003 for...
Problem with Remote Desktop
On an XP client you can only have one person logged at a time.  This is different on M$ Sever 2000 and up where you can have multiple log ons.  There no way to do this this with M$ RD - However you can achive what you are after by using  third party RD software such as Real VNC There is a free client (which i use to access mac's & win machines) or if you prefer ssh etc it is quite cheap for the full version.
Oct 18, 2007 | Microsoft Windows Server Standard 2003 for...
Win server 2003 enterprise
You need to ensure your DNS server is the first in the workstation's DNS list.
Does this help?
Sep 27, 2007 | Microsoft Windows Server Standard 2003 for...
Epson Aculaser C1100 Printer Logo
56 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
