Question about Refrigerators
I have an freezer which is defrosting every six months or so, i wonder what the reason was or fault is with this freezer
    Scholar:
  • 160 Answers
Most/many times this is a clogged up or restricted defrost drain system, but once in a while the drain system has been cleaned and everything appears to be good but you still get ice in the defrost drip tray and such and the drain freezes over.  Sometimes a solid ground wire
wrap around the defrost heater and the other end stuck in drain hole has helped for me. Avoid letting the wire or whatever to touch the plastic side of the hole.
for more detailed help click this link as its not for your brand and model but the system is same in all brands so you can follow the instructions on your model and brand too http://www.applianceaid.com/adaptive_defrost.html
just click the link
Posted on Jan 06, 2009
My model 106.53206202 compressor stops working about every six months. The interior light lights so there is power. I unplug the power cord and when I plug the power back in the compressor works fine. ...
I think the defrost timer/control board is hanging up...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 09, 2011 | Kenmore Refrigerators
I have a kenmore coldspot 106.56666501 and the freezer coils keep freezing up. I have defrosted it with a hair dryer twice in the past six months. My guess is that I have to replace the defrost heater,...
you hit the nail on the head . if heater is ok then the defrost themo is bad or the timer . any of the 3 can cause a defrost problem . but heater is most common . mm
Jul 29, 2010 | Refrigerators
Evry six months to a yr our upright freezer has frost built up inside. What can be the probable cause?
Two things will cause this assuming the defrost timer is working or the frost would be every week. The door seals are not sealing somewhere and a lot of humidity is getting in.
Jun 16, 2010 | Freezers
As of six months ago, my GE fridge starting leaking from where the air blows into the refrigerator part of the machine. I was getting a 16 oz cup of water out of it every 36 hours or so. Now the freezer...
If this is a top freezer model,remove the bottom and back freezer panels. You will find the defrost drain line frozen over.
It must be defrosted manually. A hair dryer will help melt the ice.
May 25, 2010 | GE Refrigerators
I have a side by side that frosts up in the middle back ofthe freezer and the frig part gets warm. I have $200 in it and still no resolution. Bought new in June '04. I defrost for 24 hours, turn it on and...
If you can locate the defrost timer and advance it to the defrost cycle you should be able to see the defrost elements glow behind the rear panel in the freezer. Do this before the freezer gets too frosted up. If you can't see the glow then there is a problem with the defrost heaters or the defrost thermostat. Unplug the frig and remove all the racks in the freezer. Remove the screws holding the rear panel on. Locate the two heaters and check the resistance. IF open, replace heaters. IF ok check resistance of the defrost thermostat. IF open when cold, replace defrost thermostat.
If replacing heaters always replace defrost thermostat at the same time. It will save you doing so at a later date
Dec 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
American fridge freezer keeps freezing up and fouling fan We have switch fridge off and defrost manualy. This fridge is under two years old and we have had to do this at least six times .I have already...
Sounds like either the defrost heater or the defrost timer needs replacement. IF you can get to the heater and check its continuity then you can suspect the timer
Jul 25, 2008 | Samsung Refrigerators
Freezer stops working for no reason
sounds like a defrost issue, see if theres a wire diagram id ck your heater/defrost circuit
Feb 23, 2008 | Refrigerators
FREEZER WORKING - FRIDGE NOT WORKING
Ok, got it sussed! [well here's what I did anyway]...
Quite simply, I turned off the fridge-freezer at the mains overnight and in the morning, broke and chucked out the ice chunks that had lined up in the bottom of the freezer section and then turned it back on. I returned that night to see that it was working fine again! Hallelujah, I got my fridge back!!
So it seems that all it needed was a good long defrost, so far so good! I hope this solves your problem.
Jan 07, 2008 | Bosch Classixx KGV28323 Bottom Freezer...
LEC Fridge Freezer
clean up your condenser it's gotta be dirty and check your thermostat put it on the coldest setting and check your freezer fan.
if t ain't running check to see if wired with defrost thermostat if it is suspect it defective.
Dec 17, 2007 | Freezers
Icicles in the freezer
Are you able to check if the drain tube is not clogged in some way? If you defrost it and run water through it, does it appear to run freely, or might you have some debris in the tube? Might the tube have been changed to one with smaller diameter, or might there even be a fold orn it to obstruct the water flow?
Jun 15, 2007 | GE Monogram ZISS480DRSS Stainless Steel
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
