Question about Sony KLV-27HR3 27 in. LCD Television
RE-adjusting new TV
HI. Just purchased LG lcd. Colors were great in store. How can i adjust picture to my liking? Thanks Kindly
  • 716 Answers
Turn On The T.v And Hit Menu Or Options On The Remote Then Select Picture And Adjust.
Posted on Jan 06, 2009
FIX THE COLOR, IT HAS A GREEN TINT THAT DOESN'T GO AWAY WHEN TRYING TO ADJUST COLORS FOR DISPLAY DON'T KNOW WHAT CAUSED IT
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Jan 19, 2015 | Sony BRAVIA KDL-40EX523 40" LED TV...
I purchased 42" LG Plasma TV and i need to know
There is quite a lot you can do. Go to menu, picture settings and select user 1. From here you can adjust everything from colour to contrast to warmth to sharpness. The best thing to do is to switch to XD manual adjustment and make sure the mpeg noise reduction is set to max. This removes artifacts and gives a better picture. Oddly, connecting via SCART rather than HDMI will give a more watchable picture if the HD broadcast is't at a very high bit-rate.
Dec 29, 2010 | LG 42LC2D 42 in. LCD HDTV
Adjusting color/ user mode??
The TV will not let you set brightness, contrast, color or tint in the preset modes like Vivid, Movie, Standard etc. Look for a mode that says custom, user etc..
Nov 11, 2009 | Olevia LT42HVi 42 in. LCD Television
HSL4229HDIP 42 inch LCD intermittent lip sync problem
Hi
Try Buying a aerial with a booster, u can purchase a inline booster at dicksmith or most large electrical stores.
kinds regards Kyle
u can reach me at
kyle-stelzer@hotmail.com
Apr 20, 2009 | Hisense Televison & Video
TV PICTURE SETTINGS REVERT BACK TO DEFAULT LG 32PG6000
hi it sounds like when tunned in tv it was tunned in shop mode.
do a factory reset and choose home when installing
Feb 25, 2009 | LG 32LG30 32 in. LCD HDTV
Hi!
I have a user manual in norwegian, and I have just solved this problem. Go to page 107 in the user manual, and it will guide you. :)
Feb 04, 2009 | Philips Magnavox 51MP392H Rear Projection...
Thanks!
Adjust backlight respectively asin the brighter the room the higher the backlight setting the darker the room the lower if you go below 16(if the room is totally dark, turn backlight to 0 and bump up brightness 3 or 4.
Good luck
c
p.s. the cinema setting is pretty darn good for out of box calibrations just turn off high contrast, colors, tru motion for normal non 100% computer generated movies for example, finding nemo and the rest of the animated movies look excellent with tru motion regular film is too video like it looks like soaps to me but hey you may like it so whatever floats ur boat do you have blu ray player, well if ur going to get one get the bdps350 as it does 24fps excellent and well so does your tv it actually uses 5:5 pulldown which is great. (leave tru motion off when feeding 24fps/ real cinema!)Great tv pick dont follow the hype lg is a good brand. lol no i dont work for lg just sick of the sony, samsung, sharp fans. As far as lcd goes lg70 is it right now. I didnt calibrate for sd but i would say they should be pretty close honestly. ill check when i get time.
Oct 25, 2008 | Televison & Video
Color adjustment
Hello friend,
First try go to TV mode setting, menu, setup, you should get what you wanted to program the colors, If still doesn't work please contact me by calling # 323-767-6030 and I will go through with you.
Aug 14, 2008 | Astar LTV-3201 32 in. LCD Television
Toshiba TZ55V61
Hi, I`m assuming your saying the letters on the screen have different colors (red, blue, or green) shifted to the left or right?
If so try going into the menu and adjusting your "convergence"
adjustments, basically, move the red onto the green then move the blue onto the green and the bar turns white, if one or more of the colors doesn`t adjust either up/down or left/right then the convergence IC`s have failed, this will require removal of the board and unsoldering the old IC`s and installing and soldering in the new IC`s, questions? e-mail me back, BMW Rider
Jan 04, 2008 | Televison & Video
Sony KLV-27HR3 27 in. LCD Television Logo
124 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
