Question about RCA DRC8005N DVD Recorder
RCA DVD Recorder dcr8005n ..Disk Error
Hello, I am getting disk errors and dirty disk messages when I try to watch a dvd. I know the dvd is good so I know it is a problem with my machine. I have used an electronic lens cleaner on the player/recorder and that has not helped at all. So I took it apart and cleaned the lens with a cotton swab and rubbing alchohol and that did not help. As a matter of fact, it just goes immediately to a disc error shortly after reading the disc. I can see a little red light shinning on the disc. One bad thing I have noticed since I opened it up and worked on it, is that when I first put a disc in, and it closes, the player brings up that little piece that the lens sits on and trys to push it against the spinning wheel and it continues to make a little noise as it pushes that piece against the wheel. I would appreciate any help and also wonder if maybe I should just look at buying a new part or player/recorder? Thank you. Dan
  • 1 more comment
  • Anonymous Feb 27, 2008
    will not read any disk
  • Anonymous Aug 30, 2008
    I have been getting a disc error message on my dcr8005n dvd recorder when I try to play 80% of dvds since I purchased it. It has progressively gotten worse. Now it won't play any. I've used disc cleaning dvd's and also canned air to blow off the lens to no avail.
  • Anonymous Sep 25, 2008
    will not read disc, play disc; am getting playback thru front AV fine; have lost owners manual (? download )
    sara
2 Suggested Answers
SOURCE: rca dvd/vcr dual recorder, wont play dvd
My VCR/DVD Model # DRC6200N is not working. I can hear the DVD but no picture, do you have any suggestion what is wrong?
Posted on Jul 17, 2008
Can't get rid of dirty disc error message at 1 min
Ok you might need to have it cleaned professionaly worse comes to worse have the lens replaced, something ether got on the lens or the laser is not reading or writing correctly. Can it be fixed? Sure depning on the problem inside I could not tall you 100 p[ercent as I have not looked at the unit.
You might want to take a gander inside and see if the lends is not dirty.
Thanks an please rember to leave postive ratings and feedback.
Apr 12, 2010 | Sony RDR-GX300 DVD Recorder
Record errors
If your dvd player only supports dvd+r discs then that is the only way it will record. It will only record once onto the dvd-rw and, since it doesn't support the re-writables, it won't be able to use this function. This is the most likely reason for the first error. The second problem is a little confusing. Is it when you are trying to record on dvd-rs or dvd-rws that it says it can't record? I hope this post was helpful (for the first error, anyway). Good luck! I hope everything works out! Sincerely, Der Strom
Apr 06, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
The DVD recorder quit finalizing the disks
try cleaning the lens, if your cd's are ok.
May 27, 2009 | RCA DRC8300N DVD Recorder/VCR
It says "Disk error" on any disk. It won't read disk
turn off and, unplug your DVD recorder remove the six screws holding on the top tilt the back of the top up disengage the front of the top and set it aside look for a small laser tag this will point to a 1/4 inch glass lense this is the laser taking rubbing alcohol on a q-tip gently clean the lense with a twirling circular motion
Apr 28, 2009 | RCA DRC8300N DVD Recorder/VCR
Can't Record, wont read blank DVD
Have the same problem with this piece of junk.
Tried all the solutions. Clean lens etc. Nothing helped.
Tried replacing the drive with another that I had. No go, apparently has some proprietary firmware.
I was about to throw it in the trash when I suddenly realized that it had a TV tuner. Hooked it up to my computer through a Pinnacle Dazzle interface and VOILA I had a hard drive recorder. I either just watch it on my monitor or burn a DVD if it is something I want to keep. Hey that is better than pitching something you paid $300 bucks for in the trash. You can pick up a dazzle or similar on EBAY for a lot less than a new Hard disc recorder will cost you.
Jan 23, 2009 | RCA DRC8005N DVD Recorder
Unable to record,cannot read disk,is message on screen,
May be dust/dirt on the lens, so try blowing gently or using a DVD cleaner disk.
Oct 07, 2008 | Panasonic DMR-ES10 DVD Recorder
Rca dvd/vcr dual recorder, wont play dvd
Jul 17, 2008 | RCA DRC8295N DVD Recorder/VCR
Dvd do not record
The unit is saying that its an "Un-format disc" problem. Is this the only error code you are getting? Also, what types of DVDs are being used? As in, DVD-R DVD-RW DVD+R DVD-RW and what speeds? 1x 2x 4x 8x 16x?
Apr 04, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Rca drc8060n
BTW - I did open the unit up, and my hunch is that it is a power supply issue. Also, the DVD drive appears to be a standard 5.25" IDE drive made by Philips. It might be worth salvaging for use in a PC if drivers and/or firmware exist for it.
Oct 19, 2007 | RCA DRC8060N DVD Recorder
RCA DRC8005N DVD Recorder Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
