Question about Apple iPhone 3G
Iphone 3g ,
I had to reset my iphone 3g , so i went to reset all data and settings , now when i power on it only shows the apple logo and than resets itself after like an hour , uggggh ,. PLEASE SOMEBODY PLEASE PLEASE PLEASE I NEED HELP ASAP = (
SINCERLY VICTORIA = )
Hold down the power button and home button for 10-60 seconds. Your iPhone will shut down and when the screen is black plug it into your computer like you want to charge. The screen will load good as new(or atleast mine and a few others have.
Posted on Jan 07, 2009
My G3 phone is flashing the apple symbol while powering up but isn't powering up.
Thank for contacting Fixya, I will be glad to assist you.
What you can do, in order to resolve this issue, is start by resetting your iPhone 3G.
(Note: this does not remove any settings, data or media you have installed in your device)
• To perform a hard reset, press and hold your Sleep and Home Menu buttons for approximately 10 seconds.
• Once your screen goes black, release both keys. (If you see a white Apple logo before you release the keys you have held the keys to long and will need to start the reset process once again)
• The next screens you should see after the black screen, is the Apple logo screen followed by the main screen.
• This hard reset process should help bring your iPhone 3G back to normal functionality.
It would also be advisable to connect your iPhone 3G via its docking cable and provided wall socket adapter into a working wall socket in order to try and charge it.
If your iPhone 3G still does not charge, try connecting it with the docking cable to your computer or laptop to observe if it will take a charge then.
Should this process also not affect the way the iPhone charges, then you should look into using or purchasing another iPhone docking cable, as the cable itself may not be functional and needs to be replaced.
Docking cables for iPhones are fairly inexpensive (Under $20) and can be found in most electronics/computer stores that carry Apple products and accessories.
(Link: Apple Dock Connector)
Finally, if a replacement docking cable does not help the iPhone 3G charge, this may be a hardware issue and you would be advised to take the iPhone 3G in to your local Apple retail store or Apple Authorized Service Provider in your area.
Regards,
-The MacTechTrainer
Aug 07, 2012 | Apple iBook G3 Mac Notebook
Unfreeze my iphone
Reset it with the home and power buttons until it shows the apple logo. If not, put it in DFU mode, but it will erase everything you have.
Mar 23, 2012 | Apple iPhone 3G
How to format IPHONE3G.
Formatting an iPhone 3G will erase all the data on your phone, delete all your apps and reset your phone to factory settings. Formatting your phone is a good last resort if you're having software issues with your phone. Keep in mind that the format is permanent and any data irrecoverable.
INSTRUCTIONS:
1.Click the "Settings" icon.
2.Select "General."
3.Scroll to the bottom and select "Reset."
4.Select "Erase All Content and Settings." A warning message will display. Confirm your selection. The iPhone screen will turn off then show a "waiting" sign. After formatting is complete, the Apple logo will display and finally your formatted iPhone will reboot.
Read more: How to Format an iPhone 3G ' eHow.com http://www.ehow.com/how_7640130_format-iphone-3g.html#ixzz1WCkuLtuM
Aug 27, 2011 | Apple iPhone 3G
Iphone 3g stuck in "recovery mode" (black screen
To reset your iPhone settings,
picexporterror From the home screen, Tap Settings > General > Reset > Reset All Settings.
Still having problems?
Try deleting all the existing settings.
Note: The step given below will delete all the data on your iPhone. It will also give a reset to your settings.
From the home screen, Tap Settings > General > Reset > Erase All Contents and Settings.
Or:
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least ten seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
Let me know if this helps or not, there are other resets available :
If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 19, 2011 | Apple iPhone 3G
Iphone 3g frozen apple screen power button broke?
Try a reset. Hold down the power key at the same time as the round home key until phone powers down. Release buttons only when you see the apple logo, then wait a min or two for phone to re-boot. You will not lose any data on the phone.
If this does not work, try an actual system reset. Sync iPhone to computer to back up essential data ie contacts apps etc, then go to settings general and reset. Reset all settings as a last resort. This will give you a fresh start and should sort out the majority of any bugs the phone has. A resync with you computer will restore apps etc.
Hope this helps and if so please vote.
Thanks
Jim
Jul 08, 2010 | Apple iPhone 3G Black Smartphone
Reset iphone 2G it wont come back online
I went to reset my iphone to restore it to factory settings and it never came back on. It's been a week or two and it ran out of battery power a couple of times, but it just shows the apple logo and a spinning circle over it.
Jul 01, 2010 | Apple iPhone Smartphone
My iphone has apple showing and will not do anything
Jim
Thanks
Jim
Feb 08, 2010 | Apple iPhone 3G
My iphone not getting started once it start just appears white apple logo and here it get freeze
Thanks
Jim
Feb 01, 2010 | Apple iPhone 3G
I was installing a program from wifi network i recieved a text msg and after that it was hanged and it is showing only apple logo ...plz help
Thanks
Jim
Sep 03, 2009 | Apple iPhone 3G
APPLE IPHONE 3G JUST WENT BLANK
Thanks
Jim
Nov 20, 2008 | Apple iPhone 3G
Apple iPhone 3G Logo
149 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
