Question about RCA P56812BL 56" Rear Projection Television
Rear projection tv issue
How much did it cost you to hav a tech fix your tv the second time??
As I recall, it was about $300. I knew what the problem was (power supply IC), but I felt it was worth the $300 to have someone else carry the tension of ordering and installing it and if I was wrong, correcting the problem.
It has worked well since. It has been good fortune that I was able to get it fixed twice. Better TVs are coming out all the time and I think we are at a point now where you can get the new HD wide screen units for a pretty good price. If you are able to wait a year or so longer, we might be into OLED TVs and LCDs with LED backlighting. The future is, apparently, 3D. I am going to CES this Thursday where I hear that may be the big thing.
Posted on Jan 06, 2009
My tv has a blue dots all around the television. Im thinking its the optical block? Maybe time for a new tv?
You are correct in thinking optical block, but here is the good news. For the cost of a service call a tech can come out with a jig and reprogram your optical block and the problem should go away. It may be worth the cost to fix. Unlike throwing away a 900 dollar optical block.
Apr 05, 2011 | Panasonic PT-61LCX65 61" Rear Projection...
My Toshiba 51HX93 51in, will some time do this like 3D look on the screen. What parts will i need to repair this, or How mach would it cost to have fixed?
you will need a luminance ic.if you are not verse with repairing tv have a tech do the repairs the cost will be about 200.00 us.parts and labour.but probably the tv only needs to be programed but that the job of a tech.good luck.
Mar 06, 2011 | Toshiba 51HX93 51" Rear Projection HDTV
Will it be worth to hire a tech to fix the convergence problem on my TV or should I buy a new set?
You can adjust the convergence by press the flash focus button on the TV. If the issue persists, then try resetting the TV to the factory settings. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service. You can contact the service center and check for the cost of repair. It is just a small adjustment.
Jul 24, 2010 | Sony KP-51WS500 51" Rear Projection...
TV does not power up
I have mits 35" CS 3505 will not turn on... just turned off and thats all she wrote,,, what is the estimate cost of the deflection circuit board
thanks
artie
Jul 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Mitsubishi VS-60705, Turns on/Turns off.
Unfortunately you will need an experienced TV tech.
This unit will need 2 ICs STK392-110 for 1 has shorted and caused damage to the 2nd as a result blowing 1 or 2 pico fuses in the power supply.
It is an involved job and may be somewhat costly depending on the pricing in your area.
Hope this helps Normal 0 false false false MicrosoftInternetExplorer4
Jul 07, 2009 | Mitsubishi WS-55511 55" Rear Projection...
GE 52" will not power up - green light flashes 3 times
Replace CP150 and CP114 and CP120/ You can get the caps with instructions at the following link. They do have a minimum order amount of 10.00 so you may need to order an extra capacitor to total 10.00 but shipping is free. The parts are listed under the RCA parts category,
http://servicemanuals.vstore.ca/
Feb 07, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
TV not staying on
I called a tech and it was a convergence issue. It cost $375 to fix.
Jul 05, 2008 | Panasonic PT-51HX42 51" Rear Projection...
Mitsubishi Medallion Big Screen Projection TV
I had the same problem and ended up being a board and cost me about 400 bucks to fix it.
Jun 01, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Toshiba TheaterView
Called Tv tech. He said it was the power supply connectivity. common problem in rear projection Tv's. Cost to replace was anywhere between $300.00 and $400.00 dollars. Time for a new tv :-(
Feb 21, 2008 | Toshiba 50A60 50" Rear Projection...
Panasonic 47" rear projection TV
If your set is still under warranty then get it fixed now other wise it will cost 300.00 or more to fix. replace nte 2973 mosfet transistor [2] capacitors 1200pf 2k volts.these caps are not hard to find look for burnted next to high voltage & convergence plugs ins.
Nov 17, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Televison & Video Logo
90 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
