Question about Philips VR330 VHS VCR
VHS cassettes won't play
When I put cassettes into my Philips VR330/07 VCR, it won't play the majority of them. (Although, weirdly, one or two play fine.) Instead, I get '2' symbol flashing up on the display, alongside the usual 'video cassette symbol'. If I press 'Standby/On', the number switches to a '4', but the cassette still doesn't play. Any idea why this might be? Could it be caused by dirty tape heads?
SOURCE: Flashing '2' or '1' or '4' when I try and play a tape
The idler on your machine needs to be changed and also the drum head of your machine needs to be clean.tape head cleaners can be bought from any electronic shop.the idler must be changed by qualified techn
Posted on Jan 27, 2007
  • 3 Answers
SOURCE: philips vr630 vhs
I get the same problem with one tape (it's about 20 minutes long) .. it also shows a '4' ... when you press the power button it ejects the tape... some tapes are fine ...
Posted on Jun 23, 2007
Shuttle83
  • 1139 Answers
SOURCE: Tape won't stay in and play
The carriage might be misaligned because the tape is not even loading, in addition it may be one of the tape position sensors are going bad. These are the common reasons for this problem happening.
I hope this helps,
Thank you,
Shuttle83
Posted on Jul 17, 2008
simplemitch
  • 752 Answers
SOURCE: External Tuner Device for VCR/DVD player
Just pick up an old used VCR that has a tuner built in. Only the very new ones don't have them (due to the DTV switch coming up in February).
Posted on Sep 09, 2008
  • 458 Answers
SOURCE: My vcr does not play the tape
Take the cover off & have a look at the cassette carriage, it may have came out of alignment, ie it is taking the tape at an angle or there maybe a fault with the carriage motor switch. when you put the tape in so far the carraige activates a switch which starts the loading motor to draw the tape in. It could be there is no supply voltage to this switch or the loading motor might be faulty, this is why the VCR says there is no tape as the tape has not been able to load into the machine. A repair centre should be able to fix this fault quite easily.
Posted on Jul 08, 2009
mybradley7
  • 242 Answers
SOURCE: philips vcr vrb664at won't take cassette. Has 3
try to retime the gears.
Posted on Jul 16, 2010
8mm JVC tapes put into a VHS tape that will play on a combined TV and VCR. Please, please, I need your help! Found tapes from 15 years ago.
You need an 8mm player or the camera that recorded the tapes. Connect the video and audio from the 8mm player/camera to a VHS recorder. Put the 8mm on play and the VHS on record.
Jan 08, 2015 | JVC P-6120JDU Video Cassette, 8mm 120...
Our Sony Video cassette recorder model SLV_N750 won't play??? The tape is going into play, but the reels are not turning. The VCR starts with a snowy picture and guickly stops and won't play?
The problem is the idler assembly or the black square belt that drives it, this will cause the vcr to shutdown preventing tape transport. The vcr will need to be dismantled for repair, I recommend a tv technician to check your machine with an estimate.
Jan 08, 2011 | Sony SLV-N750 VHS/S-VHS playback VCR
Many years ago some one told me that you could put your canon video camera 8 mm tapes into a video cassete case and play them on vhs tape machine is this true cause i have many but can not get whats on...
Hello, try matelectronics.com, they have the following product, I think it's what you're looking for: VHS-C CASSETTE ADAPTER(Reference #V-0730)
VHS-C CASSETTE ADAPTER BY PHILIPS PH61300
Jul 20, 2010 | Sony VCRs
The vhs cassettes keep being ejected when put in the vhs player
Well the vcr might be broken for the part that allows the tape to sit in there or something is stuck inside of the vcr so it will need to be fixed.
Jun 17, 2010 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Blank VHS tapes work; Movie VHS tapes don't
Hello statman_4
I have an important question; Are you watching a VHS tape you recorded of another VHS movie? In other words did You rent Ben Hur and record it and then tried to watch the recording? If you did that's your problem. VCRs in the late 1990's (1997-1999) began to employ MacroVision circuitry in all VCRs, and DTR. MacroVision Circuitry makes the VCR record tapes with MacroVision in such a way that the horizontal and vertical sync pulses are not at the proper amplitude, and the AGC (Automatic Gain Control) is tricked into over compensating thus creating the scrambled picture. There is a way around this. You need to buy a video stabilizer SIMA makes such devices and some other companies do to. You feed the signal from your VCR into the unit and it corrects the video image by readjusting the video signal.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc
Mar 25, 2009 | RCA VCRs
VCR
Hi dennis176,
Unfortunately, I am not aware of this kind of setup. This kind of solution would not be very efficient. For this to work there would need to be an insert to the VCR (similar to that which is used in a cassette player to convert CD audio) attached to a DVD player. Because you would require a device to play the DVD and send the video/audio to the insert (if it existed) it would actually be more efficient to simply connect the DVD player to the television. The reason inserts exist for cassette players is primarily that it prevents replacement of an entire car stereo system. This is not the case with a VCR. You may consider purchasing a DVD/VCR combo if you wish to maintain the ability to play VHS tapes. If you own a TV/VCR combo, your least expensive option would likely be to purchase a separate DVD player.
Thank you,
Jason,
Go Ahead. Use Us.
Jul 10, 2008 | Emerson EWV603 VHS VCR
Used a wet VHS cleaner and now my VCR doesn't work right. Help!!
The VHS cleaning cassette possibly deposited fiber in the heads in the drum. You may need to open the cabin and examine the heads and the mechanism for foreign matterial.
Feb 02, 2007 | Proscan PSVR72 VHS VCR
Philips VR330 VHS VCR Logo
Top Philips VCRs Experts
Robert McClure
 Grubhead
Grubhead
Are you a Philips VCR Expert? Answer questions, earn points and help others
