Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
Cant connect router & dsl modem, cant aquire ip address
When i connect thruogh router it works on my laptop but cannot get online on desktop, so to go online on desktop i hve to unplug router & connect directly to DSL modem, the dsl people tell me its not modem bcse i can get online when connected to it, the d-link people say its not router bcse my laptop is able to connect online when connected, thn chkd wt dell manufacture to check interface card & that is also ok, But when i use them together my desktop still cant connect, & when i try configuring network settings on ''automatically obtain ip address'' it keeps saying ''aquiring ip address'' , ut never does? tech people dont knw why this is happening!, does anyone else know wht i can try? thanks
  • 49 Answers
Try typing another website on the address bar.
Try checking on your router advaced setting make sure that Mac filtering is off under network filter.
Make sure all other settting on the advaced setting are also in default setting.
Posted on Jan 10, 2009
Speedstream 4100 cant connect
plug the computer into the modem testing dhcp
if it gets internet the modem is the dhcp server
the plug into router by itself disconnected it from modem testing dhcp if gets ip address and no internet it's the dhcp server
dhcp can be done by the modem or router. I bridged mode the modem and let the router do dhcp. of course the router must be pppoe for dsl. been years since I had DSL, hope it helps
Jul 07, 2017 | Siemens SpeedStream Modem (4100) (SS4100)
Tip
Limited Connectivity & WiFi issue
make sure there is only 1 pc connected.....
reset the line PPPoA/remove the dsl jack (if PPPoE) for 30 secs > delete all wifi profiles > clear the TCP/IP cache by using "netsh winsock reset" at the command prompt (if vista then from accessories right click on the command prompt and run as administrator) > switch off the router > restart the laptop/PC > remove the ETH cable > restart the router > after all LEDs are back ON > connect the ETH cable (and Enable the LAN connection if disabled) > NIC aquires the IP address > the same goes for the wifi adapter > aquires the IP address.
Hopefully the connections should work now.
on Mar 11, 2010 | Computers & Internet
Can't access modem from desktop
If your DSL works on PPPOE then you need to setup PPPOE on the 2wire router with the Complete Username and the PAssword for the PPPOW connection, if your DSL works on a Local IP address like 192.168.1.254 or 192.168.1.1 then first check the gateway address of the 2wire Router, if it's in the same IP address range like the DSL Modem like 192.168.1.x the you need to change the Local IP address of the router from 192.168.1.x to 192.168.2.x that should get you up and running with the DSL Modem.
Mar 25, 2010 | 2wire 2700HG-B Router (2700HGB)
I cant configure my mbr624gu router with usb 598 mobile 3g internet
Router set up is very easy. You will need to access the router set up interface to make changes on the router.
If you are not able to go online using the router then you will need to check the settings of the router.
First make sure that your computer is able to go online when connected directly to the modem without the router.
If your computer is able to go online through the modem only then your modem is working properly, we will need to check the settings of the router.ind network key.
Router set up for Cable Internet service provider :
This connection type uses the MAC address of the main computer to identify your connection. They generally register the MAC address of the main computer. So the MAC address is everything in this connection type. Now we set up router using the MAC address of the main computer. Main computer is the computer which was able to go online through the modem. Use only the main computer to set uo the router.
Connect the modem and the computer to the router . Check the IP address on the computer.
According to the Default gateway value open the set up interface of the router. Once you open the set up interface, you will need to clone the MAC address of the computer. Then change the wireless settings on the router and your router is ready to go.
Router set up for DSL Internet service provider.
What is DSL connection?
DSL (Digital Subscriber Line) is a high-speed Internet service that competes with cable Internet to provide online access to local customers. DSL operates over standard copper telephone lines like dial-up service, but is many times faster than dial-up. In addition to being faster than dial-up, DSL does not tie up the phone line. Coexisting with telephone service in this way allows users to surf the Net and use the phone at the same time.
There are two types of DSL connection
1 ) PPPOE : In this connection type you will get user name and password from the Internet service provider. Your computer will not be able to go online when connected to the modem only. You can open the router set up and change the Internet connection type to pppoe and type the user name and password for the ISP. After that change the wireless settings of the router and it will be ready to go.
2) DHCP : In this connection type your computer will be able to go online when you connect it directly to the modem.
you don't require the user anme and password for the ISP.
In this connection your computer will get a private IP address from the router. According to this the IP address of your router will change. Change the wireless settings of the router and it will be ready to go online.
Click here for step by step instructions
Dec 03, 2009 | Computers & Internet
Upgraded dsl modem to westell G-90-610015-20 and my linksys WRT54G router cant get an IP address. I just upgraded the modem from and older westell model, didn't change any of the settings and it can't get...
if you connect the computer directly to the modem, without any router , does it work?
Make sure that your computer will be online when connected to the modem.
If you are not online through the modem, then you should have the correct user name and password for the ISP.
Click Here for step by step solution
Oct 30, 2009 | Linksys Wireless-G WRT54G Router
Desktop wont connect to internet but laptop will!
repair the conection and also try a diffrent ethernet wire sometimes it could be bad
Jun 05, 2009 | Actiontec GT701C DSL Modem
Cannot aquire IP address through my Desktop using Lynksis Wireless Router
sounds like you need to reenter the password/key
go to network connections and disconnect from it. then try to reconnect after the refreshes.
is it asking for a password/key?
Dec 26, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
what you do is to reboot your desktop and everything will be fine or either unplug or disable and enable the status of the connestion. But the best way is to reboot the system. Good luck
Jun 29, 2008 | D-Link (DI-784) Wireless Router
My computer keeps telling me I do not have an internet connection when I connect my router. I can unplugg the router and plug it back into my dsl modem and the internet again works. why won't my router...
More info would be helpful, but I am assuming that you have a router device that is not the DSL Modem, maybe a linksys, or something? Most likely what is happening is that the DSL modem is assigning private IP addresses, like 192.168.1.x, and the router is obtaining that IP address on its WAN interface, but is also configured for the LAN at 192.168.1.x, which is the same subnet, so it cannot route packets to the internet properly, as both interfaces have the same network range. Can you give me more info? I can try to walk you thru step by step.
Step 1. Verify current IP address when internet connection is working. (Go to a command prompt and type ipconfig, press enter, and document what your IP address is, also document the gateway address and subnet mask)
Step 2. Connect to the router instead of the DSL modem, do the same thing, document your IP address, gateway, and subnet mask
Step 3. Compare the two, your IP may be different, and the gateway may even be different, but see if both are trying to use the same IP range.
If they are the same, or close (the first 3 octets(set of numbers) are the same) then you will need to configure the lan side of either your DSL modem, or the router to be on a different IP address.
To do this will vary depending on the model of your router, so if you respond in the next few hours, I will still be online, and will try to assist.
Apr 23, 2008 | Computers & Internet
Setting up a wireless router
first you have to check the ip address of the dsl modem you used and see to it that it is not the same ip address of the router to avoid conflict. the default ip address of dlink router is 192.168.0.1.if in case your dsl modem has the same ip address with the router, you have to change firs the ip address of the router before connecting the router to your dsl modem.
next you need to know your internet connection whether it is DYNAMIC or PPPOE, depending on how your internet provider configured your modem. for PPPOE connection, you have to know the USERNAME and PASSWORD that your provider provides you.
good luck.
carlmali007@yahoo.com
Nov 30, 2007 | D-Link DI-624M Router (DI624MRE)
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
1,201 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
