I have a toshiba. system will not booth
When I push the power button, the plug signal will be flashing orange. It will not stop, even if I push the off button. I have to remove the battery before it will go off. If I on it without the battery while the plug is in it, it does the same thing. Please help me. thank you very much. this is the specs (C950 14TX 128M CD L,
  • 366 Answers
Assuming you are using XP.
In Control Panel in Power Option
In Advanced tab set your options for when you press the power button and the other events (lid close .....)
Posted on Jan 06, 2009
Toshiba L655s5065RD wont start , only sign of life is blinking orange light
Okay, what does that light indicate? (hard drive activity, power plugged in, battery, etc). It most likely indicates a faulty power supply or damaged battery unit.
Dec 10, 2012 | Toshiba Satellite L655S5065RD 156 Notebook...
I just bought a 2003 road king classic and can not set the alarm. Can you tell the procedure?
Arming: Hold Fob button down until signals flash twice. The 'key' lamp on
the speedo will Blink to indicate the system is armed. If auto arming is
enabled, the key lamp will Stay continuously lit for 30 seconds after the ignition is turned off, then the system Will arm itself.
Disarming: 'Double-click' the Fob, the signals will flash once and the key lamp will stop flashing. If the Fob is lost or not working, the system can be disabled by entering the passcode. Without setting off the alarm, get the ignition switch to accessory, hold down both left and Right signal switches until the key lamp flashes rapidly, enter the first digit on the left And use the right as an 'enter' key, enter all five digits of the passcode and the system will Disarm, if you screw up, the alarm will activate and you will have to wait ten minutes.
Transport Mode: Allows the system to be armed with the motion sensors disabled for service, Trailering, etc. Turn the ignition switch on, arm with the Fob, turn the ignition off and Arm once again with the Fob. Signals will flash 3 times to confirm
arming, All other functions of the alarm system require entering the configuration mode. This is done by Disarming the system, run/stop switch in stop, flip the ignition switch on/off/on/off/on Then push the left signal button
twice. If power was disturbed to the alarm module, The sequence may have to be repeated to get into configuration mode. The system will respond by flashing out the module type code.
(1-TSM, 2-TSSM dom, 3-TSSM hdi)
Now that you are in the config mode, you can do the following.....
- To assign the Fobs, push the right once (one flash) then the left once (two flashes)
Then hold down the Fob button until the system recognizes it. Hold down the second
Fob until the system recognizes it. Both Fobs must be assigned at the same time.
- To assign a passcode, use the fob to send a disarm command, signal will flash once
To indicate the first digit, push the left signal button and the key light will flash out the Value of the first digit. Pushing the left button will advance the value up through 9 and Will start over at 1. When done setting the first digit, double click the fob again and The signals will flash twice to indicate the second digit, continue on through all five digits. Turn ignition off to exit.
- To adjust the sensitivity, use the fob to send an arm command (one flash) then push the Left signal button once. The signals will flash out the current setting, 1-4, push the left Button to advance the setting, turn ignition off to exit.
- To extract system trouble codes, press the right signal button three times,
pausing between Each press for the system to flash once, twice, and three times
respectively. Press the left signal button once and they signals will flash out two digit
codes. Press and hold the left button to clear all codes from memory, otherwise
turn ign off to exit.
- To enable auto arming, use the fob to arm the system twice, and press the
left button once. The system will flash the setting code, 1-disabled, 2-enabled. Press the left button to change The setting, turn ignition off to exit.
- To adjust between Sidecar mode and normal mode, push the right button
twice quickly, Then the left button once and the signal will flash out the current setting, 1-normal, 2-sidecar. Press the left button to change the setting, then turn the
- To adjust the length of time delay before going into storage mode, use the fob to send an Arm command three times, then push the left button, the signal will flash out the current setting. 1-30 days, 2-60 days, 3-90 days, 4-disabled. Use the left
button to advance the setting and turn the ignition off to exit.
Aug 31, 2011 | 2003 Harley Davidson FLHRCI Road King...
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
The monitor will not turn on. When power button
First--was it working?
Did it suddenly stop?
When you see the LG logo, then it goes away, does the power light turn from green to amber? Sounds like that doesn't happen.
So--if you are getting a signal, you should see something.
If there is no signal, then the power light should change from green to orange.
With no lights at all, I suspect a faulty monitor.
Feb 22, 2010 | Computers & Internet
I accidently unplugged my tv and now I plug back in and it wont turn on. I waited for 30sec and then plugged it back in but it didnt work. I then tried another outlet but still didnt work. All I see is a...
Often you have to press a particular button on the TV. The remote may not work until this is done. Sometimes these buttons are on the front or under the front.
OFTEN the orange flashing light can ALSO mean no video signal is being received. This COULD be the case if you killed the power to the TV and it has lost the channel settings so it is not receiving a signal form ANY source.
Dec 22, 2009 | Toshiba 32AV500U 32 in. LCD HDTV
No power at all even if i press the power button
Most likely the only thing wrong is the power button. Try to either replace the power button board or use a wire to short circuit the two points under the push button to turn the machine on.
Jan 31, 2009 | Toshiba Satellite A135-S2266 Notebook
Lap top wont work
You may need a new battery. I would download software to check the battery.
Does the computer start with the AC plugged in and the battery removed?
What type of Laptop Do You Have?
May 19, 2008 | Toshiba Satellite A105 Notebook
The power cable light on my Toshiba Portege 2010 flashes yellow/orange when the plug is inserted. Computer will not turn on (green light on power button doesn't even come up). Have tried: 1) starting up...
One thing could be that your A/C adapter has failed resulting in your battery not being charged. This would explain why you're experiencing the same symptoms w/ or w/out the A/C adapter.
Apr 04, 2008 | Toshiba Portege 2010 Notebook
Computers & Internet Logo
263 people viewed this question
David Payne
David Payne
