Question about Microsoft Visual FoxPro Professional Edition 7.0 for PC
Convert my database from dpf to mdb
I need simple code in visual foxpro to convert my database from dbf to mdb
  • 68 Answers
Use access to import external data. It can read dbf and create mdb
Posted on Jan 10, 2009
My visual foxpro database file currupted now this is not a table i want solve this problesm i want return to dbf
Posted on Jan 17, 2009
A tool for repairing DBF Visual Fox Pro databases
Try eRepair DBF works with a wide variety of database programs for recovering data from files that have become damaged or corrupt. eRepair DBF can recover the file structure which includes table fields that make up a DBF file, information contained in the memo fields, and a variety of records that are commonly included in DBF files.
For more:
Jun 27, 2015 | Microsoft Visual FoxPro Professional...
How do dbf viewer do?
A linked server is basically just a pointer that lets the code within your database interact with external data sources as if they were also within your database/instance. There are some examples here for creating linked servers to DBF Viewer Tool:
So for example if you had a linked server to a FoxPro database called MyFoxProDB you could run a query within SQL Server like this:
FROM dbo.LocalTable AS t
INNER JOIN MyFoxProDB...TableName AS x
ON t.key = x.key;
You could also consider using OPENROWSET as described in this question:
Mar 29, 2015 | Microsoft Outlook Express
How to recover a database on known *.bak file?
Completely - in any way. If you find also tbk the file - then is possible. bak is
backup copy of the dbf file, tbk - a backup copy of fpt (there a memo of a field are).
However you were perhaps lucky, and actually fpt the file wasn't cleared.
And it is possible "to restore" of course simple renaming of bak file into dbf file. Of course then have to be reindexed the table, and if the structure changed, in general, to recreate the indexes from scratch. and perhaps "to treat"
the container Database dbc/dct (if you use it of course).
If so it doesn't turn out, then try to restore through DBF Viewer Tool. It well restores.
Come here on a forum and look at councils for this subject is there.
Feb 10, 2015 | Microsoft Visual Fox Pro 9.0 - 34001231
At times, you may view that your MS Visual FoxPro 9.0 database is behaving abnormally. Some of the abnormal symptoms could be an error message while opening any database table, invalid characters in place of pre-defined values, and and more. The main reason for abnormal behavior of the database is its corruption due some logical crash. Few common reasons for corruption of MS Visual FoxPro 9.0 database are abnormal termination, faulty network devices, simultaneous modifications, conflicting third-party software, and incompatible service packs.
To overcome such database corruption scenarios, the user can use an up-to-date backup and perform restoration. However, restoration fails in cases where the user either forgets to create a database or the database backup itself gets damaged. In such cases, the database users can use a third-party DBF File Repair application to repair his/her corrupted database.
To illustrate the above case, consider a real-time scenario wherein you execute a query to modify your MS Visual FoxPro 9.0 database. While the query was performing the modification, the system shutdown due to power failure. However, the next time you tried to mount the database, you encountered an error message that did not allow you to access the database records. Moreover, the same error message appears every time you try to access the database.
The root cause for the error message is MS Visual FoxPro 9.0 database corruption due to improper system shutdown.
The database corruption error message can be surmounted by following the below steps:
Use a complete database backup and perform restoration. However, in case of database backup unavailability, you will need to search for a commercial DBF File Repair utility.
A third-party DBF Repair application uses effective repair techniques to repair logically damaged MS Visual FoxPro 9.0 database and restore it at a new and safe location. The original database during the repair process remains intact. The tool is easy-to-understand and allows even a non-technical person to perform repair.
DBF Recovery Software is a comprehensive solution to repair databases created in MS Visual FoxPro 9.0, MS Visual FoxPro 8.0, and MS Visual FoxPro 7.0. The tool also repairs databases built in dBase III, dBase IV, and dBase V. Supported by Windows 7, Vista, 2003, XP, and 2000, the DBF Repair tool creates a new repaired file that can be attached to existing database.
Tanvi Sharma is a self employed Internet entrepreneur and product reviewer. This DBF Repair utility is extremely useful when the dBase and Foxpro database gets corrupted due to internal program errors, hardware malfunctioning, accidental deletion of data and more. This DBF Repair software repairs all types of database components including table name, column name, column data type, indexes and primary keys.
May 31, 2010 | Microsoft Visual FoxPro Professional...
Import .dbf file format to tally 7.2 file format
Exist some tools for solving like issues, and to my mind one of them might be able to help in like situation. I found out one of them on an one soft forum - dbf recovery.
Mar 01, 2009 | Tally T2245 Matrix Printer
Visual foxpro to access
you need to use a ODBC conexion to trasport your tables into table .dbf in fox
you need to copy tur tables to excel documents an then import in vfp
Jan 05, 2009 | Microsoft Visual FoxPro Professional...
Microsoft Visual FoxPro Professional Edition 7.0 for PC Logo
221 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
