Question about Sony SLV-SE840 VHS VCR
VCR wont start
I have a Sony SLV-EZ77 VCR, Everything is plugged in fine all in the right place but when i turn on the mains power it the display on the screen on the VCR is dark as though it is in standby mode but it shows the numbers '70081'. when i press the standby or eject button it makes a noise and picture comes on but then just shuts off as though in standby mode. No other buttons respond when pressed.
Please help!
  • 473 Answers
SOURCE: Sony TRV-19 Camcorder - Black screen in camera mode
Fixed it, at least temporarily I had the side off my trv250 examining it, especially the CCD connection. I had read the post about soldering a capacitor to pins 1 and 3 (from the left) on the bottom row. I didn't have the specific capacitor on hand, but I started touching some of the small ones I did have to those pins. I found that after I touched a 100uF, 10V cap to pins 1 and 3 the picture suddenly came back to life and stayed that way after removing the cap. I have no idea how long this will last, and I've set up the cam on a tripod in the livingroom with the LCD display facing me so I can monitor it. If you, like me, figure you have nothing else to lose, you might want to give this a try. Note: my camera was suffering from the green smeary horizontal lines problem, and wasn't completely black. I'm not sure if this makes a difference or not.
Posted on Sep 14, 2005
dodgecharger
  • 254 Answers
SOURCE: VCR won't take tape
Is it ejecting the tape when you set up for timed record, or any record mode for that matter? If so, check for the presence of the record lockout tab in the tape. If tab is there, machine should accept it. If machine ejects tape with the tab present, then the sensor which detects tab present or absent is probably afoul. this sensor is often a small switch. This tab, by the way, is on the backside of the tape, on the left, looking at the tape from the back.
Posted on Apr 16, 2007
magic seadog
  • 38 Answers
SOURCE: Sony Handycam CCD-TRV37 8mm Analog... 2 Problems, maybe more unknown at this time:
This does require disassembly to remedy the problem. There are various possible fixes. The most prevelant I have seen is cold solder connections of the board connector for the fpc cable from the top operation switch block ass'y. All you need is someone who can handle this task, like a professional. The controls that you are experiencing problems with are all linked with one cable and connector. One bad solder joint can cause serveral operation faults. Good Luck, magic seadog
Posted on Aug 19, 2007
SOURCE: Sony RCD-W500-c CDR Recorder
Why don't you create some more fake Hurricane CDs, rip off a bunch of people again, and just buy a new one with all the stolen money?? Why not do that fucknuts?
Posted on Oct 13, 2008
IrishDruid
  • 2712 Answers
SOURCE: vcr does not run
Try changing the channels on the VCR itself. If you can do that, then it would indicate a problem with the VCR's remote. If you are still unable to change channels on the VCR manually, it could indicate a circuitry problem, for which you will have to get the VCR serviced.
Posted on Oct 26, 2008
My sony SLV-D300P suddenly would not turn on. The blue ps button/light just flashes, but no attempt to turn the unit on works. It was working fine, without any problems, until this one occurred.
I have the same problem -- tried power reset, tried holding stop button for 5 second reset, nothing works. If I push the power button or the eject button, the blue light flashes momentarily then goes out.
Aug 28, 2010 | Sony SLV-D300P DVD Player/VCR
Sony SLV-350P stopped working
q marca de control puedo usar, porq el original no lo tengo
Oct 11, 2009 | Sony SLV-D350P DVD Player/VCR
Sony SLV-D370P DVD Player / VCR Combo I get the following error -This disc cannot be played. Please check the desk DVD_ERRLOG5 00050106000000000006 01010c00000300020024 Any suggestions....
everyone who bought a sony DVDplayer/video cassette recorder SLV-D370P should contact sony and complain. Then, we should all sue sony for everything they got!!! I'll never waste my money on sony again.
Jul 03, 2009 | Sony SLV-D370P DVD Player/VCR
110 to 220 conversion
a converter plug should be fine
Jun 01, 2009 | Sony SLV-N750 VHS/S-VHS playback VCR
Sony SLV-D100 DVD/VCR unit won't record on a VHS tape.
Check the tab on the VHS tape be sure it is there. If not place a [piece of transparent tape on it to simulate the tab and try again.
Oct 02, 2017 | Sony SLV-D100 DVD Player/VCR
CAN'T SET VCR (SONY SLV N750)TO CH 3 OR USE MENU
This is a link to the owners manual for your unit, click --->here<--- to download.
in brief, connect antenna, plug in vcr, turn on. if ch3 is not auto tuned, it can be manually set from the instructions in the owners manual.
Please take the time to give this solution a fix ya rating.
clarkco
Feb 16, 2009 | Sony SLV-N750 VHS/S-VHS playback VCR
Sony SLV-940HF VCR Problem: clicking noise when tape fully rewinds
It is normal. Sony is trying to get your tapes last longer.
Mar 27, 2008 | Sony SLV-940HF VCR
Sony SLV-940HF VCR Will not accept tape
Dear Rob, There can be two reasons for your problem.Let us consider the simpler and most likely cause.....Belts!!! Unplug the Plug from the Power socket. Open up the top and bottom Panels.Check the belts. Most likely you will find a belt has snapped ( a 80% possibility) or become very very loose. Also check the Tape Loading mechanism,there is a small belt which connects from the Loading motor to the Loading Mechanism. Replace the belts as a entire set. Let me know if this worked out. Good Luck.
Jan 27, 2007 | Sony SLV-940HF VCR
Sony SLV-SE840 VHS VCR Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
