Question about Minolta EP4000/5000 CS/PRO Copier
Code to inter diognostics
I need to get the code so I can change the auto exposure to a lighter setting, where it is now it needs to be set lighter every time you use it.
  • 40 Answers
The code to enter diagnostics on CS/PRO copiers by Minolta is Stop-0-Stop-1.
Posted on May 29, 2007
I have cspro5000, it is probleming when we copy the scanner (lamp) jumping in the side
Posted on May 28, 2007
How do I lighten the pictures?
Check your camera settings:
White balance should be set to auto,
ISO should be set to auto,
flash should be set to auto,
scene should be set to auto,
Exposure Compensation should be set at 0.
If images are still too dark change ISO setting to 200. If that doesn't work change to 400. If that still doesn't work change exposure compensation to +1. If your photos are still too dark your camera is defective.
Nov 10, 2014 | Vivitar ViviCam 7024 Digital Camera
SHARP AR-M455, AUTO-EXPOSURE
Press custom settings, then go to key operator settings. The default log in is 00000. Then go to ccopy settings, default, exposure adjust.
Jul 16, 2012 | Sharp AR-M455N Copier
My camera over exposes everything - the shutter stays open for about 2-3 seconds. except when on video settings. No matter what I set it at nothing changes.
Looking down at the top of the camera, check the left knob. This is the exposure compensation dial. Adjust it to "0". If set one way or the other, it will make pictures darker or lighter. This comes in handy when the image has a lot of dark or bright areas - moving this dial will allow you to make the bright areas darker or the dark areas lighter when you camera's light meter is setting the exposure in a way you do not want.
If still having trouble, make sure the right knob (Mode) is not set to M or Manual. Switch it to Program or Auto and try taking a picture again. You might even want to set the outer knob (ISO) to AUTO as well to reduce the chances of an incorrect setting. If it now works as expected, but you want to shoot in M, you will need to learn how to use the meter to select the correct combination of aperture (f stop), shutter speed and ISO to obtain the desired results.
Oh, experiment with the exposure compensation knob when you have a chance, learn how it can help correct overly dark / bright scenes. Good luck!
Feb 14, 2012 | Canon PowerShot G10 Digital Camera
I waint to know how to inter sim 14 for toshiba photo copy m/c model e-studio 161
Hi Wahdain,
Its so simple enter the formula given below. First press the C button then press the exposure mode change button ( this is what you used to change the exposure from auto to manual or photo modes) then again C button, then again exposure mode change button then 1 and 4 then start button ( this is what you press to take a copy) Try this and put it right.
Best Regards,
Rakshita
Jul 07, 2011 | Toshiba e-Studio 161 Copier Copier
I have a Sharp AL 1642 CS. It prints black copies. It came out of no where so I know it isnt dust on the lens. Even after adjusting brightness settings it prints pitch black pages. The bulb on the scanner...
Problem on three things.
1.OPC drum cleaning blade is very old,so lost her activities.
2. Laser unite very dirty,so you need clean.
3. setup or configure exposure control.
# Press Auto key three second
when exposure light indicate now position,select way lighter side.
Jan 20, 2010 | Sharp AL-1642CS Copier
Need to buy new battery for a 2001 bmw 325. When changing it do I lose all memory settings, radio codes etc
Yes you will. There's a plug you can buy at an auto parts place you will also need a 9 volt battery, that will save your memory, fit's in the cigarette lighter make sure your lighter plug works.just plug in to lighter will save memory while to switch battery out.
Nov 23, 2009 | 2001 BMW 325
Canon NP 7161, auto exposure adjustment
WHAT KIND OF DETAILS?
You can calibrate the lamp under service mode * 28 (together for 3 sec) * i think under No.5.
Whe you open the front door, under instruction hoewto replace toner there must be an table with numbers and standard adj, values.By this table you can figure out which values do You need to change - something by my memory HL5 or similar value for lighter copy decrease value and oposite.
May 16, 2009 | Sharp AR-5316 Advanced Digital Imager...
I have a Nikon Coolpix P5100. I use it to photograph my paintings
There could be a number of reasons.
First, Have you tried it in P mode and are the results the same? Then, have you tried taking images in M mode and set the exposure yourself? Do you have the same result?
Second, If you are shooting in P or normal mode the Exposure compensation might have been incorrectly set. On the Navigation control to the right of the OK button is where you can set Exposure compensation. Press it there and you will see some information appear at the bottom and left side of your LCD. The bar on the left will consist of a series of white graduations with the centre one yellow. If you have yellow bars above the centre one then your image will appear lighter as if over exposed while if you have yellow bars that extend below the centre one your image will appear darker as if under exposed. To reset it use the navigation control to scroll either up or down then press OK once it is where you need it.
Last, if that doesn't work, try checking the ISO. With the camera on in P mode press and hold the Fn button at the top left of the LCD. Scroll to Auto using the command dial next to the shutter release and release the button. If it was already on auto you could try setting it on 2000 and seeing what the result are like then. Don't leave it on 2000 as you will get grainy images but you should get lighter shots as it will allow the camera to cope with poor light conditions. Reset the ISO to Auto and if it still isn't working properly you will probably need to get it serviced.
Mar 10, 2009 | Nikon COOLPIX P5100 Digital Camera
Underexposed image on Auto mode
You can change the ISO setting also to Auto. If you have the advanced guide (see pp 80, 107).
Press the ISO button it will switch from various ISO setting to AUTO.
Do remember in Bright light , a lower ISO number like 80 will give you very fine images, while as the light level goes down, the ISO number will change to a higher number and the image will become more grainer.
I hope I could answer to your query.
Please do rate. Thanks
Jan 14, 2009 | Canon PowerShot S5 IS Digital Camera
400D manual mode
You are exposure compensation in manual mode. If you want the shots lighter, either open up the aperture or slow the shutter. The exposure compensation feature is to override the automatic settings determined by the camera in the auto-exposure modes.
Dec 05, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
79 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
Inky Fingers
Inky Fingers
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
