Question about Onkyo TX-SR606 Receiver
Onkyo tx-sr606b no power - blown fuse?
No lights - no "stand by" - none of the standard "clicks" - absolutely "dark".
Is this a fuse problem? Why would it blow overnight when not in use? It's fairly new - just a few months old.
  • MonikerM Jan 06, 2009
    I will get it fixed, but I don't want it to happen again - what could have coused it?
    Keep in mind: it was in the middle of the night and nobody was using it when it shut completely off.
  • davemcm Apr 15, 2009
    Hey, i have the same problem. My onkyo gets power but when i replace the fuse it blows immediately after being plugged in. I think it is the transformer.
    I have about 60 feet of outdoor speaker wire with one connection about 20 feet into it where the speakers used to be mounted to the outside of the house and then a outdoor volume control knob about 40 into. From the knob out to the speakers.
    Could a faulty connection where the red is touching the black cause this problem? I just don't want this to happen again.
  • 56 Answers
It either a bad fuse or your transformer that is blown
Posted on Jan 06, 2009
Where are the fuses located in onkyontx-sv525- only found 1 at power in
If you pulled the cover and only see one fuse, and if it is not blown, then you need to search deeper for the problem. All replaceable fuses on the main board are viewable.
May 08, 2015 | Onkyo TX-SV525 Receiver
Reciever will not come on
May be a blown fuse inside the unit. Disconnect from power, let stand 20 minutes to make sure the high voltage caps are drained. Open and look for a fuse near where the electrical cord goes in. Remove and test, replace if bad.
Aug 10, 2014 | Onkyo TX-V940 Receiver
My stand by light flashes on my onkyo tx-sr501
Check output transistors for short, change emitter resistors
Mar 30, 2014 | Onkyo TX-SR501 Receiver
Onkyo tx-ds656 stand by power light comes on volume control knob rotates to max but display or unit wont start
Try factory reset: while holding the(CD) button on front panel,press (POWER) button.
After "Clear" is displayed the unit should be back to its factory default. :) If this dont work for you take the unit to be checked by service . :)
Jan 24, 2014 | Onkyo TX-DS656 Receiver
My Onkyo TX-SR606 won't turn on
The reference to Zone 2 means that your Onkyo receiver is set to be remotely controlled from another location. Normally, this arrangement would be initiated at the time of set up but could be done later. You may have to repeat the initial set up routine to get things back to normal
Feb 22, 2013 | Onkyo TX-SR605 Receiver
Onkyo AVR TX-SR444 not powering up LCD not lit.Stand by LED lit only,on stand by mode. Thanks, Sorin
if STBY red light blind after power button pressed, AMP blown. you have to find large shorted transistors
Mar 22, 2011 | Onkyo Audio Players & Recorders
Onkyo TX8211
The most likely problem is shorted output transistors. This is a straightfoward repair for any shop that works on audio gear. Expect a parts cost in the $40-$50 range.
Aug 12, 2009 | Onkyo TX-8211 Receiver
Will not power up but stand by light is powerd up
I have onkyo tx-ds575 and i need to conect it to my tv and have audio from a LCD flat panel.
Oct 05, 2008 | Onkyo TX-DS575 Receiver
Unit no longer powers up after shorting the switched plug in back of unti
you most likely fried a circuit board trace on the power supply
Dec 25, 2007 | Onkyo TX-SR500 Receiver
Onkyo tx-ds676 dead no power up
power down the amp totally to reset processor, then try again. If still no go, may have blown internal fuses- replace and try again
.... or failed thermal fuse in mains transformer. this is a workshop repair as it involves mains voltage that can kill :)
Nov 24, 2007 | Onkyo TX-DS676 Receiver
Onkyo TX-SR606 Receiver Logo
561 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
