Question about Samsung SyncMaster 720N Monitor
Samsung Monitor 720N
The brightness panel constantly appears right in the middle of the screen every few mins. Pressing the menu button temporarily removes it but it comes back about a min later. How do I stop this happening please.
  • 1 more comment
  • Anonymous Jan 22, 2009
    The brightness panel appears all the time right in the middle of the screen every few mins. Pressing the menu button temporarily removes it but it comes back about a min later. How do I stop this happening please.
  • 2DLBNX Jan 28, 2009
  • Anonymous May 10, 2009
    Same Problem here...did you ever find a solution?
    please let me know. bobamy02@aol.com
  • 63 Answers
Check the resolution of the system make it as 600*800.
Posted on May 20, 2009
Press first time to turn on adjustment panel, and press next time and keep your finger fixed on button. Bad solution but works :)
Posted on Jan 21, 2009
Brightness box in the middle of the screen - will not go away
open case remove white header plug from back of switches and voila ..... none of the buttons will work or the power led but display is fine with no annoying menu
Jun 16, 2011 | Samsung SyncMaster 720N Monitor
Brightness bar stays in the center of my screen Samsung SyncMaster 731N
I'm Adam and i'm a computer-technicien!
I should do these 2 things do hide this brightness bar:
-You can click the MENU button again!
-You can simply disconnect the power-cable from the monitor and
let it unplugged for like...10-15 seconds!
-You can remove the button with a screw-driver and take the
little plastic on the second button.
If this all doesn't work...
I can recommend you to send a email to SAMSUNG with this info:
-Name:
-Date when you bought this product:
-When did this start:
-And your CPU information:
If this all doesn't help...
You ned to install a driver called 'Syncmaster 720n/730n driver'!
Thank you,
May 25, 2011 | Samsung SyncMaster 720N/731N
My brightness menu is locked on the screen and my monitor buttons aren't working .. I'm having a silver Samsung Syncmaster 720N.
OSD Lock & Unlock
When pressing the AUTO button after locking the OSD
When pressing the MENU button after locking the OSD
This is the function that locks the OSD in order to keep the current states of settings or prevent others
from adjusting the current settings.
Lock : Hold down the MENU button for more than five (5) seconds to activate the OSD adjustment
lock function.
Unlock : Hold down the MENU button for more than five (5) seconds to deactivate the OSD adjustment
lock function.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
May 10, 2011 | Samsung SyncMaster 720N Monitor
A window saying Brightness is constantly popping up in the middle of the screen (very annoying :-Z) how can i get it to stop??????!?!
this monitor is triky.
try pressing brightness key and try playing with other keys EXCEPT PoWER button
this is only thing you may try.
THats it. bettter is to replace monitor
rate this solution and comment to get further assistance.
Sep 14, 2010 | Samsung SyncMaster 720N Monitor
Basically i've broke my monitor buttons and was wondering if there's a way to remove the 'brightness' settings without having to press the monitor buttons, as it is constantly on my screen. thankss.
unplug remove screws take out the little white plug from by switches ...put case back on leave the white plug OUT fixed but no power light or buttons display works fine
Apr 04, 2010 | Samsung Syncmaster 17" 720N Monitor
Probably not only because I found several forums and the same claim as is my case .. initially function to adjust the brightness automatically .. 100% ... like I keep the button pressed continuously .....
Check out this link below for a PDF manual for your monitor. You can also update your drivers. There is a support here also. Just copy and paste into your browser.
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=05020100&prd_mdl_cd=&prd_mdl_name=720N
Hope this helps. Let me know if I can help you with anything else.
JimmyC
Oct 04, 2009 | Samsung SyncMaster 720N Monitor
Brightness indicator windows does not go away
Dear sir This is common problem observed in many monitors compaq,HP,HCL,IBM this is happens mainly in rainy season due to moisture,by this moisture monitor button circuit get rust inside and button pad remain pressed. so it shows a strip at the middle of monitor like contrast or brightness. So this is minor problem just replace the monitor display control button sensor or circuit.Temporarily you can warm up the monitor by hanging a bulb of 60 watt nearer your monitor to takeoff the moisture.(Dont hang the bulb too near to the monitor). It definitely solves your problem.
Have a Nice Day
Sep 17, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Display problem
the adjustment box for colour, brightness and contrast stays fixed on the screen. i tried pressing the exit button.... after a few times it disappears only to reappear within a few minutes. also the auto adjustment option, for which we are supposed to manually press the i button, keeps auto adjusting the screen whenever it feels like it. the box appears right in middle of the screen and is a real nuisance as it blocks out the main portion.
Jun 28, 2008 | BenQ FP547 - 15" LCD Monitor
Samsung SyncMaster 720N Monitor Logo
1,715 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
