Question about XO Vision MD068 6.8 in. Car Monitor
Car stereo tv tuner
Proper installation for xod1730 car stereo tv antenna
  • mmsood Jan 09, 2008
    We are missing the installation manual for our new XO Vision XOD1730 car stereo. Are there any available on-line instructions for installing this device? All help is really appreciated.
  • Anonymous Dec 29, 2008
    anyone know how the antenna for a car tv gets wired?
Go to xovision.com download product manual... that is what i had to do.
Posted on Jan 17, 2008
How do ihook up a digital antenna to my tv
Dominic, you do not state whether you want large outdoor antenna or simple indoor.
If you bought your HDTV anytime during the past 8 years or so, it should have a built-in tuner for receiving digital over-the-air broadcasts. If you have an older "HDTV-ready" TV that only receives analog signals, you'll need to connect it to a separate HDTV tuner.
link below tells how to install outdoor digital TV antenna.
press the helpful button.
How to Install Digital TV Antenna Digital TV Help
Jan 19, 2016 | Televison & Video
Part nos of Harnesses needed for Analogue Tuner Part No.: A211 820 14 97
I do not think there is a specific part number for cables and connectors, You need car stereo connector and RCA cables, if you tell me where you are located I can find seller shipping connectors and cables to your area.
Aug 23, 2008 | 2007 Mercedes-Benz E-Class
Can I hook tr 2920 theather research speakers to a stereo
It really depends upon your TV. If your TV is newer and has an ATSC tuner in it, then no - you'll just need the antenna. However, if your TV is older and doesn't have an ATSC tuner, you'll need an external tuner, what you're calling digital convertor, and an antenna to get the local channels. Use Google or another search engine to find the specifications for your TV to see if it has an ATSC tuner. Or, connect an antenna to your TV, run the channel scan (off-air antenna mode) to see if you get any local channels. If you don't, you'll need the external tuner.
Sep 29, 2014 | Audio Players & Recorders
How to properly connect the channel Master antenna tuner to my TV so that I can connect an antenna to the tuner. I have the CM-7001. I'm connecting through the HDMI port on the tuner to the HDMI port
Confusing question! The CM-7001 is meant to be used for displays or monitors that have no means of connecting an antenna and don't have a built-in tuner. HDMI to HDMI would be the correct way and make sure you select the proper HDMI port. Or use the other video and audio cable connections.
Sep 03, 2014 | Channel Master CM-7001 ATSC Antenna and...
Do i need a tv tuner to receive an internet tv signal?
No need,you must have only the antenna for internet,like smart broadband to watch online channel all you want to do is look only for the website that has an available online channel. It is also possible to installed a TV tuner to your computer but the antenna you will used is the antenna for TV(coaxial cable). The Antenna for internet and the TV tuner is separated, it is not the same antenna.
Hope this simple information could help you to solve your problem. Mam/Sir don't forget me to rate me up I really appreciate what grade will you given to me. Thanks a lot and God Bless.
Jul 14, 2011 | Computers & Internet
My sony xplod stereo is running weird.i installed an amp and ran a remote wire but when i play CD,s the stereo turns the amp off but turns on with tuner and aux.can u help
kinda sounds like you may have used your motorized antenna trigger wire as your remote wire to your amp. if you switch out of AM/FM, it is designed to lower the power antenna, when AM/FM is switched on, it raises the antenna.
May 07, 2011 | BMW 318 Cars & Trucks
Sony KV- 20FV12 get no signal on screen. Same cable outlet works on other TV as a test. Cable ON in menu. Auto Set search produces search but still no signal.
Hello
If auto search is going on smoothly, and there is no stations on air is memorized, and display no signal, there are tow possibilities. The first one is antenna is not connected properly. Check the antenna connection for firm. The second one is tuner fault. If the tuner inside the tV is faulty, or it does not gets proper voltage to work, this type of fault land display will see on screen. Check if proper voltages are comming to the tuner section in circuit board. If voltages are ok, and still there is no signal display, just check it with external video input. That is, connect it to any dvd or cd with AV connector, and set the TV to AV mode and play a disc. If there is picture, the video side of your TV is OK. If not, Video-chroma-RF jungle IC is faulty, and not the tuner. OK.
Feb 03, 2011 | Sony KV-20FV12 20" TV
Where in the hell does the antenna wire plug into on a 1990 chevy k1500 with factory radio, did not see a place on equalizer or radio itself.
In most cases the antenna plug directly into the back of the radio. But GM came up with this crazy 3 piece stereo system. You have the display/selector, the tape deck/EQ, and the tuner. The antenna will be pluged into the tuner which is buried deep into the dash above the acceleator slightly to the right. I have installed close to 100 stereos and this threw me for a loop. Follow the tape deck/eq wiring harness to find it. Happy hunting.
Nov 15, 2009 | 1993 Chevrolet K1500
I have just bought a car with an overhead tv i dont know how to get power to it
    Headrest TV
  1. Step 1 Disconnect the headrest from the car seat and remove its upholstery. Trace the outline of the TV's mounting frame onto the foam cushioning with a permanent marker.
  2. Step 2 Cut a hole into the foam using a razor knife for the frame to fit into. Using the frame as a guide, whittle into the hole until it is deep enough for the frame to fit into. Glue the frame into the hole with contact cement and poke another hole into the foam with a screwdriver where the frame's cable hole is.
  3. Step 3 Place the headrest's upholstery cover back on and cut the fabric away where it is over the frame.
  4. Step 4 Place the TV into the frame once the contact cement is dry and hard and run its cable through the other hole. Connect the TV to its tuner console with audio/video cables and store the tuner under the seat.
  5. Step 5 Connect the TV's power adapter cable and route it so it can plug into a cigarette lighter adapter. If it doesn't use one of these, it will have a three-way cable where one connects to the car starter, another to a constant 12-volt source and the last one to a good ground. Disconnect the negative battery cable before connecting any wires
  6. Overhead TV
  7. Step 1 Make sure there is a metal sheet installed in the ceiling below the headboard. This is needed to mount the overhead player onto.
  8. Step 2 Pull away the upholstery on the ceiling. This might require a solvent that will remove the upholstery's adhesive. Insert a plywood or metal sheet between the headboard and upholstery and glue it to the upholstery.
  9. Step 3 Mount the TV set to the ceiling, making sure the screws for the TV's mount are securely screwed into the sheet within the ceiling.
  10. Step 4 Route the wires to the engine compartment if the TV doesn't use an adapter plug for the cigarette lighter. With the negative battery cable unplugged, connect the TV's red wire to the starter's electrical connector, the yellow to the battery or other 12-volt source and the black to a metal ground like on the chassis.
  11. Dash TV
  12. Step 1 Unplug both battery cables from the car's battery, starting with the negative terminal.
  13. Step 2 Remove the stereo from the car. Pry away and remove any trim panels on the dash, then unscrew the mounting screws on the stereo and disconnect the electrical connectors. Some stereo units have an anti-theft mounting system requiring special tools that fit into holes on the stereo front to release its mounting clips.
  14. Step 3 Place the TV within an installation kit designed for your model carmag-glass_10x10.gif. Connect the antenna's cable to the TV and mount the antenna on the outside of the car; the trunk or the roof near the door frame are two possible locations. Route the cable along the weatherstripping or secure it to the side with cable ties.
  15. Step 4 Connect the TV to its tuner box with RCA video (composite) cables and store the tuner somewhere secure, like the glove box. Wire the TV to the radio antenna and stereo connectors with a wiring harness designed for your car, which can be purchased at a car audio supply store.
  16. Step 5 Mount the TV into the stereo's old spot within the dash, fasten all the mounting screws and replace the trim panels. Reconnect the battery cables once the set is mounted, starting with the positive terminal.
i hope this will help.you can send a message if you not satisfied
Sep 10, 2009 | Necvox Car Audio & Video
Problem no sound
If your KENWOOD unit is experiencing audio problems (NO Audio), but do have audio when TUNER is selected as the source, you may have problems with your installation.
NOTE: If using an external amplifier or the unit was installed using a separately purchased wiring harness for your specific vehicle, please check the following
If Using an External Amplifier
The P.CONT or REMOTE terminal on the external amplifier requires a “turn on” signal from the stereo. This terminal should be connected to the BLUE/WHITE P.CONT wire on the Kenwood harness and not the solid BLUE ANT.CONT wire.
If Using a Vehicle Specific Harness
The vehicle has a factory installed amplifier and requires a “turn on” signal from the stereo. Make sure that the BLUE/WHITE P.CONT wire is connected to the vehicle specific harness and NOT the sold BLUE ANT.CONT wire.
The solid BLUE ANT. CONT wire is used to trigger a power antenna ONLY when the tuner is selected as the source. Using this wire to “turn on” an external amplifier or factory installed amplifier will only allow it to work when TUNER is selected. Please refer to your instruction manual for proper installation. If you are not completely comfortable with installing the unit yourself, we recommend that you seek assistance from a professional installer.
Apr 10, 2008 | Kenwood KDC-MP438U Car CD/ MP3 Player
XO Vision MD068 6.8 in. Car Monitor Logo
593 people viewed this question
Top XO Vision Car Audio & Video Experts
jason
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
