Question about KitchenAid KHMS155LSS 1000 Watts Microwave Oven
Microwave no power
I HAVE A KHMS 155LBTO KITCHENAID MICROWAVE HOOD THAT DOES NOT INDICATE POWER EVEN THOUGH IT IS PLUGGED INTO A LIVE RECEPTICALE. I TESTED THE WALL PLUG IN, THERE IS POWER. THE MICROWAVE IS 2 YRS OLD AND IT WAS OFF DUE TO A SNOW STORM AND OUT POWER WAS OUT FOR A LONG TIME. WHERE IS THE RESET BUTTON ?
U CAN CONTACT ME AT ALBANYFX@GMAIL.COM
THANK YOU FOR YOUR TIME
  • Anonymous Apr 13, 2009
    I have a similar model. Same problem. The power just went out. No lights, panels, or anything. Probably a power supply problem but I have not found a fix.
How can you take the fuse out on this model KHMS 155LSS-4 of kitchenaid
Posted on Jan 15, 2009
No power, even when plugged in to a live outlet.
The main fuse in the microwave oven has blown, the cause is usually a defective door switch.
Feb 09, 2011 | Sanyo EMG5595S 900 Watts Microwave Oven
KitchenAid KHMS 2050 SSS, doesn't heat up and indicates "Error Code F7, VH SMPS feedback, call for service"
Hi asoleyma,
This error code F7 from a Ktchenaid oven means that the function key is stuck on ERC. This can be fixed by having the control board (also called ERC or clock) be replaced.You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model number ready when you call.
Hope this helps.
Thank you for using FixYa.
Jan 30, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Everything is working, but no heat. lights come on, turntable turns, fans run, but no heat
Normally this would indicate that the diode in the power supply for the Magnetron (microwave radiation emitter) has failed. I would recommend that the unit be serviced by a professional in this area, or disposed of because of the following:
1 The power supply for Magnetron Tube the produces thousands of volts and can produce a lethal shock even though the machine is turned off and unplugged. Really, I'm not kidding.
2 Working on a Microwave Oven can expose you to high levels of Radiation which can immediately
Damage internal organs.
That said, there is another even better reason.
3 Microwave Ovens are now very inexpensive to replace.
Even though I personally know how to fix them, I can't be bothered.
I hope I have been of help
Happy New Year,
Best, Mark
Jan 01, 2011 | Samsung SMH9187 Microwave Oven
My kitchenaid microwave
I have the same model in my home only mine is black rather than stainless. The problem you are encountering is most likely due to a fuse that has blown internally in the unit. Before having it looked at be sure you have power to the wall outlet that the microwave is plugged into. The outlet is usually in the cabinet above the microwave, simply unplug the microwave and plug a lamp or other appliance to verify it is 'live'. If the outlet is live the repair for the fuse may be a done from the front if you have a bit of patients and basic knowledge of electricity. I would recomment calling a service company to make all repairs on this paticular unit as it can be very tricky. Let me know I can help further.
Apr 18, 2010 | KitchenAid KHMS2050SSS Microwave Oven
Lightbulb burned out for microwave model # KHMS 1850SSS-0 Kitchen Aid Where can I purchase a replacement? Thank you, Carrie
Most home improvement stores and even some Walmarts/Chain grocery stores/Ace Hardware carry replacements. You will need to remove the cover from the microwave oven on most models unless your bulb is inside a protective cover inside the actual oven. Take the bulb with you when you go to make certain of a proper match. Be certain to unplug the oven if you need to remove the cover in any case.
Oct 13, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
Oven dont warm food
Kitchenaid KHMS 147 HBL-1 unit does not heat. All other functions are working and it worked this morning but as of this evening it will not heat. I was thinking the fuse but would like some advice
Oct 09, 2008 | GE Microwave Ovens
NO POWER
I have answered this is via e-mail.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 23, 2008 | KitchenAid KHMS155L Microwave Oven
KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
326 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
