Question about Sony VAIO VGN-N150G/W PC Notebook
MAUSE DRIVE i hava a VAIO VGN-N150G, AND the ext. optik. vaio MAUSE missing Driver, i need usb mause drive update or upgrade!
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
Upgrade sony vaio vgn-fj270
I need motion eye driver for a vaio vgn fj1s. any one can help me? thanks!
Jul 28, 2012 | Sony VAIO VGN-FJ270/B Notebook
Have a Sony Vaio VGN-C21S laptop. I upgraded it from Windows Vista to Windows 7 Ultimate. Now, my AV Mode and other shortcut buttons for volume, camera, etc. are not working. What driver should I download...
Perform a Windows update first to see if there are updates to correct the drivers. Then if any drivers are still missing, go to the Sony website and locate the Windows 7 drivers for your computer model.
Dec 29, 2010 | Sony VAIO VGN-CS215J/W Notebook
I have recently installed windows 7 on my sony vaio VGN-SZ330P. but the webcam driver is missing. how can i get this driver ? please help..
open goole home page download Driver magician instal after update serch all drives click driver opition driver version support relase date
google page open serch driver name version freedownload after instal problem slove its true ............try
Add a comment
Oct 28, 2010 | Sony VAIO VGN-SZ330P/B Notebook
I cannot fine the dvd driver for my sony vaio VGN-FS840W. please help me.
You can find firmware and registry updates for your DVD drive from Sony at the following:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNFS840W
Aug 02, 2010 | Sony VAIO VGN-FS840/W Notebook
Sony Vaio VGN-FE770G windows 7 upgrade problems
hello, try the link below;
ftp://download.sony.com/US/pc/TIDMSC-01424702-US.EXE
the driver above is for vista and should work with windows 7.
I hope this helps.
Kind regards,
Amar Sondhi
Dec 14, 2009 | Sony VAIO VGN-FE770G Notebook
A required cd dvd drive device driver is missing
i think you need a new windows cd that has no errors, your cd might have some files missing
Dec 08, 2009 | Sony VAIO VGN-NR220E/S Notebook PC
Pioneer DVR-K16D driver?
www.findmysoft.com/drivers/Vaio-VGN-BX394VP-Pioneer-DVR-K16-Update-1-10-firmware-driver.html , free download your driver cd in the above website
Jul 25, 2009 | Pioneer (DVR-K16) DVD RW Dual Layer Burner
Webcam problem
see if it is a driver problem or hardware problem first. first try and see if u uninstall the driver and reboot does the system detect it again?
if not goto nearest vaio service center and get it fixed for free if u hav warranty . i did
Feb 18, 2009 | Sony VAIO VGN-CR220E/P Notebook
Sony VAIO  VGN-N150G/W PC Notebook Logo
55 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
