Question about Whirlpool Refrigerators
Whirpool frost free-fridge temp is not working
My whirlpool frost free is not working at the right temp.The fridge is warm and now i have to throw the meat away.Any clues of why it is not working ?Also it has been making noises from the past month ?
    Scholar:
  • 160 Answers
The refrigerator/freezer defrost system can be checked by manually initiating a defrost cycle. There
are two methods of initiating the ADC Test Mode.
First Test Method:
1. Turn the thermostat off for 15 seconds.
2. Turn the thermostat on for 5 seconds.
3. Turn the thermostat off for 15 seconds.
4. Turn the thermostat on for 5 seconds.
5. Turn the thermostat off for 15 seconds.
6. Turn the thermostat on for 5 seconds.
7. Turn the thermostat off.
In 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal closed). NOTE: The test mode will terminate when the bimetal opens. If the refrigerator/freezer is already in defrost, Test Mode can be terminated by unplugging the refrigerator/freezer from the wall outlet and waiting 30 seconds before plugging it back in. The refrigerator/freezer should immediately go into cooling mode if the thermostat is closed.
If this first test procedure fails to make the ADC initiate a defrost cycle, try the following procedure to make the ADC begin the Test Mode.
Second Test Method:
1. Disconnect the refrigerator/freezer from the wall outlet for at least 30 seconds.
2. Turn the thermostat off.
3. Reconnect power to the refrigerator/freezer.
Within 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal close). If the unit fails to go into the defrost mode during this test, the problem may not be with the ADC. A defective bimetal may be the cause of the failure. The ADC will only go into a test mode if the bimetal
is closed. If the ADC senses an open bimetal it will return to the cooling mode within 3 to 8 seconds.
HELPFUL HINT: Upon entering the Test Mode, the relay mounted on the ADC board should turn off the compressor and turn on the defrost heater. Listen for the relay to click.
� If the relay clicks one time when entering the Test Mode, check for continuity in the defrost heater.
� If the relay clicks two times, check for an open bimetal.
Posted on Jan 06, 2009
  • chapli Jan 06, 2009
    Older refrigerators had electric heaters on the edges of the refrigerator cabinet to help prevent moisture from building up, especially in the hot/hazy weather in the summer time. These electric heaters usually had a switch where you could turn them on or off...had words like..."switch here to prevent moisture"...switch here in damp weather".... in the picture it is in the top left of the control assembly.
    Then along came the energy crunch. The manufactures stopped using the electric heaters and started running a pass of the hot condenser tubing on the edges of the cabinet where the electric heaters use to be. This is often called ayoder loop tube SxS version and the yoder loop tube Top freezer version. This has now replaced the electric heaters. If you feel heat/hot around the door opening of your refrigerator you should....
    clean the condenser coils as a dirty condenser can make the tubing hotter than normal
    - check/clean & replace if necessary the condenser cooling fan   ( # F ) motor, if the condenser fan motor is slow or has quit the yoder loop pass will get very warm/hot to the touch
    - If the condenser coils are clean and the condenser fan motor is running ok, check the fresh food and freezer section temperatures...if the refrigerator is not operating well and the temps inside are warming up, you could feel more heat/warmth than normal
    fridge makes a bang noise when it shuts off: Sorry to say most times this is a faulty compressor. A compressor is a electric motor and pump mounted from springs inside the black dome, if one of these springs stretches or breaks the motor and pump hits the outer casing dome and bangs when it shuts off. Other things to check for, tubing touching one another, something fallen behind the fridge, condenser fan motor blade hitting something, defrost condensing pan out of place.
    Three of the most common fridge noise makers are the evaporator fan motor,condenser fan motor and the defrost timer. The evaporator fan motor is in the freezer section. Often when the freezer door is opened, the noise will get louder. The condenser fan motor is at the back bottom of the fridge. The defrost timer can be found in several different spots, at the back of the fridge, inside the fridge or under at the front are some common areas to find the defrost timer. Do not attempt to oil any of these parts, replacing them is the best repair.
IT IS NOT COOLING IN THE FRIDGE SECTION
Check for frost on the back wall of the freezer, which would indicate a defrost failure, this can block the air circulation from the freezer into the fridge. If the damper control door is stuck closed, it will also result in warm fridge temps...
May 26, 2016 | Whirlpool Refrigerators
GE Profile- Freezer/ Fridge at 56 wont go cooler!
HI,
All i can say is you will require a tech to get this fixed.
check freezer for frost build up and if fan is blowing, check condenser, make sure its clean, and fan blowing,
check vents in refrig. make sure no blockage, controls should be in the middle setting,
check make sure compressor is running.For this you will require a tech..
Goodluck.
May 03, 2008 | GE Profile PSW26P Stainless Steel Side by...
Fridge temperature too warm
As you know this is very large fridge and try to find service manual for help and solve problem with using deduction method of step by step trouble shooting and eliminate possibilities
This might be compressor problem or evaporator problem or main controller problem or sensors or etc.
Baumatic TITAN 5 Stainless steel 4 door 607 Litre Frost Free Fridge/Freezer
Technical Details :
* Total gross/net capacity: 607/557 litres
* Gross capacity fridge/freezer: 428/179 litres
* Net capacity fridge/freezer: 397/160 litres
* Energy efficiency class:
Dec 06, 2013 | Refrigerators
My whirlpool frost free fridge freezer's alarm keeps going off, ice-cream doesn't freeze?
Check condenser is clean, fans working, thermostat set correctly, try to check internal temp with digital thermometer
May 17, 2012 | Refrigerators
Whirpool side by side freezer working but fridge not
Hi emmaubiera86,
The issue with the freezer working but the fridge is not is usually the result of a defrost problem. The first thing to check in this case is the freezer area. Look at the back panel inside the freezer. If you notice frost covering the back panel, you have defrost problem. One of the things that happens during this defrost problem is Air cannot circulate from the freezer(where the cold happens basically) to the fresh food section. The coils inside the freezer are the only part inside the whole refrigerator that "get cold". They need to stay free from excess frost build up so that air can pass through the coils and reach the fridge section of your machine.
Hope it helps.
Thank you for using FixYa.
May 07, 2011 | Whirlpool Refrigerators
My freezer is cold but my fridge is room temp?
Most often when you have this condition with a frost free fridge, you have one of two problems.
It could be a defrost problem. Look in back of the freezer. Is there a layer of frost against the back wall? If yes, you are Iced up. That would be either a defrost timer, heater, or termination thermostat.
The other thing it could be is the evaporater fan motor. Do you hear it running? It could be that the sound you heard was the fan blade hitting something. It may be jammed or the motor burned out.
Your fridge needs the air moved by this fan to make it cold. Thats why when you have ice blocking the coil, it makes your fridge warm.
Good luck
Jul 28, 2010 | Whirlpool ED2FHSS Side by Side...
Freezer froze,ice and frost,freezer door froze, warm in fridge
change thermostat sensors in fridge and freezer easy
Feb 04, 2010 | Refrigerators
Whirpool fridge is warm, freezer is working
Check the back wall of the freezer compartment for ice buildup. Sounds like you have a defrost issue.
Feb 22, 2009 | Whirlpool GB2SHDXP Bottom Freezer...
Whirlpool arc7612. Fridge not getting cold. Freezer obviously working as it frosts up despite being 'frost free'. Slight gap in door seal near top of door. Last time we had this happen I unplugged it for a...
You have to replace the door seal. The seal may be a mundane technology and it isn't the only technology making a refrigerator frost-free, but it is the most important one. Warm moist air enters through the gap in the door seal, condenses on cold surfaces and freezes. The frost interferes with airflow and prevents the system from keeping the fridge cold. Turning it off for a day allowed the frost to melt.
Aug 03, 2008 | Whirlpool Refrigerators
Refrigerators Logo
728 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
