Question about SanDisk Sansa e260 MP3 Player
F..ked up Lets see... Im using this sansa for last 5 monthes, and last night i dised to formate it... I press format... on icon which is in my computer when you connect your salsa with pc...  And it said error, error ...... I tray one time more and every think was ok ( on computer ) bat when i looked at my sansa he was working like a flash.... Display allways saying "Disconnecting" and when i press any botten I see many on a secound bat after secound it sad aggen Disconnecting..... I cant turn it off, I cant do anything and I forgot to say that i dissconect it from pc..... sorry becouse my english is not very well...
    Problem Solver:
  • 17 Answers
Try a different USB cable and different USB ports. Lots of times it's the cable.
Try holding the power button "UP" for 15 seconds, wait a few moments, try turning on and off then reconnect to computer. This resets the unit.
Force MSC mode - power button "DOWN" in hold (orange showing), press and hold CENTER button while connecting USB cable (& don't release CENTER button until unit is recognized). You won't be able to transfer DRM-protected content but it might just fix what's ailing you.
Hope this helps.
Posted on Jan 06, 2009
My sansa clip is frozen how do i reset
1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. Next try to switch USB modes 1. Turn the player OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the player to the PC. If none of these things work try and format the player - You will lose all your music - sorry\ For your Clip: 1. From the Main Menu, select Settings > Format. 2. Select Yes. You can also format using media player -> start Media Player If you have Media Player 10 --- Connect the Sansa player to the PC in MTP mode (Previous step USB mode). Click on the Sync tab.( be sure your player shows in the pull down menu, Click the pencil icon on the upper right corner of the window. Click OK to start formatting. Now if you have Media Player 11--- Click the Sync tab. On the left panel, look for the device. It is usually the last device listed. Right-click on the device and select Format Click OK to format.
Jan 24, 2010 | SanDisk Sansa Clip MP3 Player
I have sansa sandisk e 260. last time, after charging it in my computer, i plug it out without having safety mode in the computer. After then i can not open my disk. when i try to turn on pressing on Menu...
1. Download the Sansa firmware.
2. Turn the player off.
3. On the top of the player is a Hold switch located.
Move it to the right so you see "Orange".
4. On the left hand side of the player is a Record button.
Press and hold the record button while connecting the player to the computer.
Continue holding the Record button until you see a new icon under "My Computer": named "16MB FORMAT".
Once you see that icon release the Record button.
5. Drag and drop the download firmware files to your player (16MB FORMAT).
6. Disconnect the player from USB cable.
Several things will be displayed.
When you see Key Lock, System Shutdown, move the Hold switch on the top back to the left.
Otherwise download the Sansa Updater and start follow the points 2-4 and start the Sansa Updater.
After updating the firmware follow point 6.
Jun 08, 2009 | SanDisk Sansa e260 MP3 Player
I cant delete my music from my mp3
May be you need to restart it mostly that is the problem.
Dec 27, 2008 | SanDisk Sansa m240 MP3 Player
Hi, how do I format my sansa?
you connect it to the computer then go to my computer
then find the sansa and right click then press format
Dec 07, 2008 | SanDisk Sansa e250 MP3 Player
MP3 on off on off on off
JUST HIT THE RESET BUTTON, ITS BY WHERE YOU PLUG IN THE EAR PHONES. =)
Nov 20, 2008 | Memorex MMP8565 MP3 Player
Tranfering video to device through video software
The Media Converter software will only recognize certain video types for conversion.
p.20 of manual:
Sansa Media Converter software lets you convert photos and videos as appropriate,
and then transfer them to your Sansa player. Sansa Media Converter offers
features such as cropping, rotating, and resizing before transferring them to your
player as well as the ability to transfer photo and video files to your microSD card.
Refer to the Sansa Media Converter software for file formats supported.
To transfer photos and videos to your Sansa player, follow these steps:
1. Connect the Sansa player to your computer.
2. Select Converter using Sansa Media Converter on initial connection.
3. Click Add Media to select photo or video files to be converted.
4. The Sansa Media Converter will store all converted files in My Album. Click
the Album Name box and type in the name you want.
5. Click to start the conversion process. A status box will appear
showing which file(s) are being converted.
Mar 09, 2008 | SanDisk Sansa e260 MP3 Player
Bad Track
Change the Mode on the device and try to format again.
SETTINGS>MODE or USB MODE.
If that doesnt work. This will;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Nov 19, 2007 | SanDisk Sansa e250 MP3 Player
Not enough space for music db. please free 6mb
http://forums.sandisk.com/sansa/board/message?board.id=e200&message.id=23609&query.id=137762#M23609
PLace the Sansa in Recovery Mode, plug in, and see that the 16MB FORMAT icon appears in Windows Explorer.
Right click in the window, and create a new folder named sansa.fmt
DO NOT ATTEMPT TO FORMAT THE RESERVED PARTITION USING THE WINDOWS FORMAT COMMAND!!
Drag and drop the sansa.fmt folder into the 16MB FORMAT partition. Right-click and select eject.
Unplug, and see if it will automatically format.
Thanks to neutron_bob
Jul 21, 2007 | SanDisk Sansa e260 MP3 Player
I need help with my Sansa Sandisk e250R
To fix it, format your Sansa. I had the exact problem. Plug it in, then in "My Computer" right click its icon and hit format. Do not select quick format. Then it will be fixed.
Apr 27, 2007 | SanDisk Sansa e250 MP3 Player
Sansa Model 360 (4 GB) - Won't start up nor' connect to the PC.
I currently have the same problem after a firm ware update and have passed my problem directly onto sandisk. Will let you know how I get on
Jan 02, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
29 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
