Question about Epson STYLUS CX3900 All-In-One InkJet Printer
CX 3900 Ink Problem
My black ink ran out recently so I tried to replace it with a new one, but after replacing it, the red no-ink light still blinks to prompt me to replace and won't let me print.. then it says on the screen that no new cartridge is detected or that the ink is ingenuine... so i bought another cartridge and put it in but I still get the same problem?
does anyone have a possible solution to this?
  • 1 more comment
  • Anonymous Jan 14, 2009
    replaced the empty cartridge with new genuine one, but the printer says it isn't genuine....strange...
  • pearlyn_yn Jan 30, 2009
    i don't think the computer or its programs have anything to do with this error, because even when i'm starting from scratch and have disconnected the printer from the computer.. the printer still shows a lack of black ink..
  • Anonymous Feb 03, 2009
    I have the same problem
    President:
  • 8,637 Answers
Normal 0 Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
MY EPSOM CX 5500 WILL NOT PRINT. i HAVE A RED LIGHT PERM ON BY THE INK ICON. i HAVE TAKEN OUT THE CARTRIDGES SEVERAL TIMES AND RESTARTED BUT NOTHING HAPPENS. tHE CARTRIDGES HAVE INK AS FAR AS i...
Hello, This happens with epson as it has a chip on the cartridge, which sometimes shows the cartridge empty even if there is some ink left on it. You can try this steps:- 1. With the printer turned on press the ink replace button, which will bring the print head to ink replacement position, pull out the cartridges one by one and cover the tip of the cartridge with some tape and shake the cartridges and reinsert it on the printer and press the ink replacement button once again, the printer will check the inks cartridges, if the inks is empty it will show the red light again, pressing the button once will bring the printer to ink replacement position with the cartridge to be replaced on the replacement position. you can also check on the printer software on the pc that which ink cartridge is emptied.
Hope this helps.
May 14, 2011 | Epson CX4400/CX5600
Everything was working fine, i ran out of ink in all tanks so i only replaced both black tanks they are in properly, well the light isnt blinking on them anymore it is solid red. but when i close the cover...
Error U072
Causes : * Some ink tanks are not installed in place.
* More than one ink tanks of the same color are installed.
Action : Replace all the ink tanks as they are empty. Confirm that the ink tank are installed in the appropriate positions.
Hope this helps.
Have a good day.
Dec 05, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Power and error botton blinking epson cx 2900
Could be ink cartridge no contact, or it is dirty. Or if you try to print and this printer that flag a message " end of service life......parts." . You should reset it counter using third party software. In kinda connection with ink pad.
Apr 18, 2009 | Epson Office Equipment & Supplies
Horizontal lines
try to clean your Ink cartridge inside you printer.. or try to replace with another Ink Cartridge.. maybe you cartridge was damaged.. ^^
Mar 10, 2009 | Epson STYLUS CX3900 All-In-One InkJet...
Error code E5 / BLACK INK
Do a search for resetting ink cartridges after refilling! Hope this helps - fotobean
Feb 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
I have an Epsom Stylus CX 3900 Series printer and when i switch it on the red light comes on and will not print. I replaced the black ink cartridge but the other three colours are empty. Does this make the...
yes. some printers won't print if they don't have all colors full, even if they dont need them at that time. bad luck ... refill all of them.
I have photo R265 and one color is gist beggining to run out ... I can stand on my head and it won't print anything.
Dec 28, 2008 | Epson STYLUS CX3900 All-In-One InkJet...
HP 932 RED LIGHT STAYS ON
The light you describe is the ink light.
When that light is blinking, try this.
Turn on the printer. Open the front cover and look at the carrier for the ink cartridges. There is a white arrow right above the latch for the color cartridge.
Once the carrier stops moving, the white arrow should be pointing to a symbol which represents the problem (the reason the light is blinking.) Examples are low ink black, low ink color, sick black ( replace ) , sick color ( replace ).
IF you have just replaced your black cartridge, you might need to replace your color cartridge too.
This printer will not work without both ink cartridges installed and full.
You cant print with a full black and an empty color cartridge unfortunately, even if you only want to print black.
Hope this helps!
Aug 27, 2008 | HP DeskJet 932c InkJet Printer
Not printing after color cartridge ran out - new black cartridge installed.
Yes, this printer has fixed printheads and must have ink in each color to prevent damage to the printheads. Even when printing black only each color is spit in the servicing area to keep the printhead unclogged.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jul 18, 2008 | Epson Stylus C60 InkJet Printer
C43sx both lights on
ok...start by removing the drivers from control panel, go to website and get new drivers, install them, try it again.
http://tinyurl.com/6qcpgy
Jun 11, 2008 | Epson Stylus C43SX InkJet Printer
Epson STYLUS CX3900 All-In-One InkJet Printer Logo
123 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
