Question about Hoover Washing Machines
Washer filling not turnin when on wash turns when goes onto spin
When i put washer on to wash it fills and does not turn when on wash makes a griding noise,when it goes onto spin it turns and bangs does not spin it is if it is not catching plz help thanks jackie
  • 1 more comment
  • jackiemullin Jan 06, 2009
    wiil check when come bk could you tell where i would get a belt from if needed please and thankyou for your help will let you the out come thanks again
    hi ya had a look belt is still on if it is the gearbox would it be worth me getting a new washer thanks jackie
    thank you
    Problem Solver:
  • 10 Answers
It is either the belt is bad or the gearbox is bad look under it from the back side and check the belt
Posted on Jan 06, 2009
  • jeff bronson
    jeff bronson Jan 06, 2009
    most appliance repair stores ....... searsis good but if you look in a phone book for your area a appliance repar shop can look the belt up by make and model of the washer
  • jeff bronson
    probly cheaper to get a new washer but i would check an appliance repair of thrift store can get a used washer from 50 to 75 bucks and some appliance repair shops will take yours as a core charge or knock alittle off the price then repair yours or use it to repair another depending on what is wrong with it
I load washer it starts the wash cycle it goes through wash cycle fine drains water but does not collect water for rinse cycle it just idles. So I turn knob to spin and it spins until done.
If it doesn't fill for the rinse, I would say that the cold inlet valve has failed. Check that the cold tap is turned on and check when the machine fills for the wash cycle and see if it is taking hot or cold water. You will probably find that it is filling only with hot water. A local spares store should have the valve you need.
Sep 17, 2015 | Whirlpool Ultimate Care II LSQ9564J Top...
My washer seems to be stuck on a boil wash i turn the knob to another setting and the time light flashers but will not stay on and the washer start a boil wash
Possibly the water level sensor inside is out of order. So, the program only gives the command for filling with water and heating.
Sep 10, 2017 | Hoover Nextra HNT 2135 Top Load Washer
Somtimes my washer will put too much water in, then when it starts to agitate the water spills over the top of the tub and onto the floor. it happens (but not always) on the initial fill and when filling...
Remove the front panel. Pull the plastic hose off the air bell on the front left side of the tub.
Use a toothpick to clean the residue out of the hole in the air bell. Replace the plastic tube.
Set the washer on SPIN and turn it on. After the spin cycle finishes start the washer normally.
Aug 10, 2011 | GE Washing Machines
Hi,when starting the machine on normal wash the filling of the machine starts and stops with the machine ending up over filling,when i put program onto spin it goes through the motions but does not...
If it's over filled it won't spin.
The fault is most likely either with the water level sensor or with the filling solenoid. Both are cheap parts but note the caveat of "most likely". If you buy and fit the parts with no improvement you cannot return them, but a Bosch repair agent can try them and remove them if they're not the cause. The worst case is a failed pcb, but repairing your machine will still be cheaper than replacing it. Barring occasional faults, Bosch washing machines last longer than average.
Sep 25, 2010 | Bosch Classixx WFO 2866 Front Load Washer
Please help the washer fills up and turns the
Seems like a blockage or maybe pump worn out. Fill machine and take grey outlet pipe on rear of machine. Place this pipe as low as possible into a bowl. If water flows free from this pipe then your pipes are not blocked and most likely you will need to change your pump. Before you try this just put machine onto spin and ensure this will work when machine is almost empty
Mar 12, 2010 | Hotpoint Aquarius WF220 Front Load Washer
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
Washer makes noise, will not fill
turn it on and just makes a hummins noise??? not filling with water??? at very least the machine if powered correcly will fill with water, the humming if happening is hte washer trying to fill check your incoming water supply. try alo changing water temp select from cold/warm/hot.
Dec 03, 2008 | Roper RAS8244KQ Top Load Washer
The washing machine will not fill with water.
this depends on the make of the washer / some whirlpool and kenmore will fill but if the lid switch is bad it will not advance to start washing ,,,, put the dial on spin and with it turned on close the lid and if it dont start spinning then your lid switch is your problem ,,,, can help better if i can have the make, model and serial off your washer.
Larry
Nov 24, 2008 | Washing Machines
Washing Machines Logo
59 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
