Question about Toshiba Satellite M115-S3094 Notebook
Keypad on two different types of keyboards not working
Had a tech woking on PC some time ago. Keypad didn't work, just used keys at top of keyboard. Tech suggested to replace keyboard due to low cost. Finally got around to replacing keyboard with a wireless keyboard. Keypad still doesn't work! Have checked numlock key (light does work) and reinstalling drivers.
  • clark styx valencia
    clark styx valencia May 11, 2010
    please indicate what top keys are working..it could be a problem with the motherboard
How to type @ symbol
I am not familiar with this particular keyboard, but it sounds like you are not finding that symbol (@) on the keyboard. On most keyboards it seems to be the shift of the "2" key (at the top of the keyboard, not on a separate number keypad). I checked keyboards from three manufacturers, and that was the case on all three. However, if that key is not working properly, you could define "(a)" or something similar to be auto-corrected to the "@" symbol. Finally, you could try typing the ASCII character by a keystroke combination such as Alt-0064. In MS Word, when I type that combination (make sure to use the numeric keypad, not the number row keys), I get the "@" symbol. The same works in many programs.
Jan 17, 2014 | Logitech Wireless K400R 79 Key Slim...
''HP Pavilion dv7-1183CL Laptop Keypad Issue'' Keypad/NumberPad/NumPad is randomly slow, stuck, or disabled. The Keypad will not stay enabled. Holding down a number on the Keypad and pressing the Fn Key...
a new keyboard? or maybe the cable end inside is loose?
in ebay type, dv7-1183cl keyboard, see em,?
or read the manual called service, on that pc, at HP.com
see the 100 keyboards for 100 languages? yah.
one is yours, find it write down the P/n for yours
back to ebay and find it.
or ask at HP.com not here, we are not hp.
its that or virus infected.
we boot to a linux or windows PE live disk or stick
if the key works now, then you learned in 5min work
the problem is our unstated OS. is corrupted.
why not have tech, just fix it.?
May 30, 2017 | HP Computers & Internet
My blitz doesnt text
Try this. Touch Keypad simulates a wireless phone keypad on the touch screen to allow you to enter text, numbers, and symbols just as if you were using a wireless phone keypad. Touch Keyboard simulates a 20-key QWERTY (typewriter) keyboard on the touch screen to allow you to enter text, numbers, and symbols similar to the way you would using a QWERTY keyboard. To use Touch Keypad or Touch Keyboard:  In a program, tap the Input Selector arrow, and then tap Touch Keypad or Touch Keyboard. To type lowercase letters, tap the keys on the dial pad or keyboard. To type a single uppercase letter, tap the Shift key and then tap the corresponding key. To type all uppercase letters, tap the Shift key twice. To change back to all lowercase letters, tap again. To enter a space after the word, tap the Space key. To start a new line, tap the Enter key. To backspace and delete a single character in any input mode, press the Back key. To open the Symbol pad, tap the Symbol key. To change the input mode:  Tap the Input mode key to switch to a different input mode: XT9 (predictive), Multitap (abc), or Numeric (123).
Hope this helps, let me know if this works or if I can help you with anything else.
JimmyC
Aug 05, 2009 | UTStarcom Blitz Cell Phone
Keyboard will not work
Try this and see if this works for you. Touch Keypad simulates a wireless phone keypad on the touch screen to allow you to enter text, numbers, and symbols just as if you were using a wireless phone keypad. Touch Keyboard simulates a 20-key QWERTY (typewriter) keyboard on the touch screen to allow you to enter text, numbers, and symbols similar to the way you would using a QWERTY keyboard. To use Touch Keypad or Touch Keyboard:  In a program, tap the Input Selector arrow, and then tap Touch Keypad or Touch Keyboard. To type lowercase letters, tap the keys on the dial pad or keyboard. To type a single uppercase letter, tap the Shift key and then tap the corresponding key. To type all uppercase letters, tap the Shift key twice. To change back to all lowercase letters, tap again. To enter a space after the word, tap the Space key. To start a new line, tap the Enter key. To backspace and delete a single character in any input mode, press the Back key. To open the Symbol pad, tap the Symbol key. To change the input mode:  Tap the Input mode key to switch to a different input mode: XT9 (predictive), Multitap (abc), or Numeric (123).
Let me know if this works for you, if not let me know.
JimmyC
May 07, 2009 | UTStarcom Blitz Cell Phone
Keyboard letters 'm,j,k,l,u,i,o' permanantly locked for numerals. i have no idea how i switched this function on.
NumLock is on. Look for the Fn key in the lower left corner, and lookint in the top right, the NumLock key.
Mar 22, 2009 | HP 2133 Notebook PC
Aspire 5100 Kepad and touchpad not working
have k/b and touch pad been disabled in BIOS?
Oct 30, 2008 | Acer Aspire 5100 Notebook
Main keyboard
The kkkkkkkk problem will be a sticky key, possibly something jamming the contact under the key.
The p* problem is your numlock is on. Laptop keyboards don't have numeric keypads like dsktops do, so when you press numlock on, it uses part of the keyboard to emulate a keypad.
You will probably have to press something like shift+numlock or ctrl+numlock or FN+numlock to release it. There should also be a light at the top of the laptop to indicate it's in numlock mode.
Apr 16, 2008 | Gateway 400SD4 Notebook
Keyboard
The Numeral Lock mode is turned on by pressing the key named "NUM LOCK" which is usually located on the top of the number keypad (on far right side of keyboard).
However, laptop keyboards are different. Most laptops do not have a separate numeral keypad set. Those laptops usually use a blue (or other color-coded) "Fn" key, on the bottom left. You must press that Fn key at the same time as the "Num Lock" key of same colr. Then a light comes on to indicate the mode change, and some alpha-numeric keys on the keyboard now become your numeral keypad. On mine, it is 789, UIO (456), JKL (123) and M (which is zero).
If this is too confusing, you can plug in a cheap full size desktop keyboard, using the USB or PS2 port on your laptop. That is what I prefer, because the funky integrated dual-key deal interferes with all the touch-typing I learned 37 years ago.
Feb 10, 2008 | Compaq Presario 1275 Notebook
Logitech MX 3200 wireless keyboard Numeric (right side) keypad does not work.
maybe it is full of dust on those buttons. Try cleaning it with a duster of mini-brush because it interrupts the function.
Jan 30, 2008 | Logitech MX3000 USB PS/2 Wireless...
19 key Numeric keypad with 2 usb ports
You better consult your hardware manual.
If there is no manual Try checking your regional language selection in control panel. Check your MS word configuration go to: Tools > Options Check your settings for keyboard or input device.
Oct 10, 2007 | Targus USB Ultra Mini Keypad Keyboard...
Toshiba Satellite M115-S3094 Notebook Logo
135 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
