Question about Motorola Mobility HS850 Consumer Headset
HS850 microphone problem (other party can't hear)
I've been having increasingly frequent problems with the microphone on my headset - and it sounds like this is a fairly common problem based on other problems posted. The person on the other line can barely hear me, if at all. Sometimes the sound is a little garbled, but mostly it sounds as if only 1% of the possible volume is coming through. The problem probably started as long as a year ago, but has only become a real problem in the last two months. I have been using this headset regularly for nearly two years. Unfortunately (?) the problem is intermittent. It will be fine for several days or a week, and then it stops working. Or, it won't be working, and I'll try again, and it does work. I have tested the problem out by using the headset with the voice memo function on my phone; indeed, this was the only way I was eventually convinced that my family and friends' phones weren't POS :) I have tried many different combinations of deleting the profile, re-pairing with the phone (a Motorola e815), power cycling the phone (with and without battery). I also opened up the microphone portion because a user on amazon reported that his problem was fixed by soldiering a loose wire, but mine did not appear loose. There is nothing blocking the hole that leads to the microphone. I gently removed the mic portion from the silicone piece and nothing appears to be physically damaged. I just would like to find out if there is anything else to try before giving up on this headset entirely. When it works, it's great, but the growing unreliability is making me annoyed.
  • halfbrainj Aug 24, 2008
    The only solution I can suggest, is to throw it out! It is **** made in China.
    No wonder we are in a recession!
  • 210 Answers
It sounds like a short in the headset wiring.
I understand you have checked the solder joints. However, the short may still be at any point(s) along the length of the cord. Sadly, shorts will eventually occur in all wires that are moved regularly. The solder joints is typically the first place that happens.
Try using your headset on someone else's compatible phone.
Posted on Feb 24, 2011
Send it back to motorola
Posted on Jun 19, 2007
Logitech speaker feedback
Feedback is a sharp, loud noise that can come through the earphones of a headset unexpectedly---it occurs when the headset is getting sound (feed) from someone else speaking or playing music into a microphone. This sound can create a dangerous situation for someone who is operating expensive equipment or flying a plane at the time since it can disable hearing temporarily.
If you experience feedback often, it could also lead to serious hearing problems.
Mic Too Close to the Speaker or Volume Too High
The main cause of a feedback sound in a headset is proximity to a speaker. If a person holding a microphone on the other end gets too close to a speaker, it creates a loop of re-amplified sound that results in the loud, screeching noise. When the volume on the other party's microphone is too high, it is more vulnerable to picking up unwanted noise and feedback from speakers and sound output devices in the room. So make sure that you ask the other party to turn down the microphone to a normal level and stay far from speakers. b> Two Microphones Gathering Same Sound b> When the other party places two microphones too close to each other, it could cause feedback. When positioned toward the sound source (such as a person speaking) the microphones will both pick up the same audio and compete with each other when creating the output of sound, causing a sharp noise in your headset. This problem, called acoustic phase interference, is resolved by simply ensuring that the other party uses one microphone at a time. Poor-Quality Headset or Microphone b> One common cause of feedback is simply a poor-quality headset or microphone. Most modern headsets and microphones have noise-canceling features that manage and kill feedback before it has a chance to occur. These noise-canceling headsets are essential for pilots and aviation crew members. If you hear sudden feedback that is strong enough to hurt your ears, the headset or microphone is simply not properly equipped to actively cancel that unwanted noise before it hits your ears. Buy a higher-quality noise-canceling headset to manage the feedback noise when you're going about your tasks. Hope this helps.
Dec 23, 2012 | Logitech Z623 Speaker System
I have explorer 240. I paired my device to computers bloutooth. everything was ok. But now the other party can't hear me. I tryed to pair with my cellphone, and there was the same problem... Is there...
It could be that your unit is defective and may need to be replaced but here is some information for you to check out from the user guide:
1) Callers cannot hear me, or I cannot hear caller/dialing tone.
The headset is not turned on or the headset is not connected to mobile phone. Press the call control button for 2 seconds until you hear a beep or see the indicator light glow blue to turn headset on.
Your headset is out of range. Move the headset closer to the phone or Bluetooth device.
Your headset battery is drained. Charge your battery using the AC power adapter supplied.
The listening volume is too low. Press the volume key up (toward the earloop) to increase the sound heard in the headset.
Good luck from Headsets Direct!
Jul 20, 2011 | Plantronics Explorer 240 Bluetooth Headset
Headset failed to transmit
You can mute outgoing voice during a call by tapping on both volume buttons and tap them again to un-mute.happened to me a lot . hs850
Dec 24, 2008 | Motorola Mobility HS850 Consumer Headset
Microphone isn't working on my hs850
You can mute outgoing voice during a call by tapping on both volume buttons and tap them again to un-mute.possible you are experiencing this . i did
Dec 06, 2008 | Motorola Mobility HS850 Consumer Headset
Motorola HS 850 Mic is not working.
perhaps it is in "mute mode" which can be activated on the headset itself by simultaneously pressing both the up and down volume buttons. Also, have you tried deleting the device from the phone you are using before you pair it up again? finally is there any firmware/software update available for the phone? This can be the case frequently with bluetooth problems with Blackberry devices (I know this from painful experience with this same headset). Good luck.
Aug 21, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola HS850 Bluetooth
Whats most likely wrong with your HS850 is the connect button on the front of the headset (the larger oval chrome one with an inlay of a traditional phone handset on it)is stuck down. To repair this you will hold the hand set and pull up on lanyard attach point firmly. (This facia is held on by double sided tape). After pulling the facia you need to purchase or borrow a T-6 Torx bit to remove the screw that holds the headset together. Once you get to the circuit board you will see what the button and spring assembly are (all is is a round piece of foil and the "spring" is a piece of tape using tension to pull the foil up!) Reset the piece of tape so it does not rest on the board and reassemble that headset. Enjoy your HS-850
Jun 28, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola HS850 Bluetooth headset
no u need to take it to phone manufactuer
Microphone doesn't work
unit needs to be replaced with new one go to www.n1wireless.com to get replacement cheap
Apr 08, 2007 | Motorola Mobility HS850 Consumer Headset
Can't Talk
mic connection has a short go to www.n1 wireless.com for new headset cheap
Dec 31, 2006 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility HS850 Consumer Headset Logo
190 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
