My waste pipe needs replacing but it looks like I have to open up the machine to be able to access the point that the pipe joins the machine. The manual doesn't show how to do this. Do you know if i need to take off the side panel of the machine or am i missing something?
yes. the side panel needs removing to get access to the fill/water matrix. to do this, you need to remove 2 torx 15 sized screws underneath the white seal of the side panel. make sure you have unplugged the dishwasher and disconnected its water supply.
once you have access to the water matrix, place a towel or similar absorbant material underneath where all the pipes connect to the matrix (near the back) to prevent any spillages. the waste pipe is the same colour and texture right up to the connection on the matrix and is (i believe) the furthest from the door of the dishwasher. disconnecting the hose shouldn't be too difficult.
it seems that my dishwasher has decided to make the programs longer ie the auto button would usually...
(More)
it seems that my dishwasher has decided to make the programs longer ie the auto button would usually wash for 125 minutes and thats it done, now it has extended to 200 any ideas what it could be, or what i need to do. I have pressed the 2 buttons together which is supposed to reset it, but just goes to 0 and stays there...HELP!
I need to replace the inlet water valve in siemens didhwasher SE23900 how to dismantle the base??...
(More)
I need to replace the inlet water valve in siemens didhwasher SE23900 how to dismantle the base?? cant find how to to it.
