Question about Oreck XL Professional Air Purifier
Oreck air purifier keeps turning on and off
I have completely cleaned and dried the collection cell and even tried another collection cell from a same Oreck and it still does the same thing? When I turn it on it keeps turning on and off? Any help would be greatly appreciated thank you
  •  Bob S
    Bob S Apr 14, 2009
    My Oreck XL Table top Air Purifier also turns off and on by itself with about a 1/2 delay between turning off and turning back on. I noticed this only because I use the nightlight setting and I had my living room lights off when the light went out. I cleaned the cell which helped, for about 2 hours, then the problem started again. I decided to ignore the power blinks but the time between turn-off and turn on gradulally increased to 3 or 4 seconds and then the high speed would come on with both the low and high speed indicator lights on simultaneously. I cleaned the cell again although had had done so a couple of days previously and cleaned the interior of the cabinet. No luck. All of this started happening after the 3rd cleaning of the Truman Cell. I was meticulous in cleaning and even used Oreck's very expensive cleaning spray foam. I contacted Oreck who told me no customer had reported this problem previously. They asked me to return the air cleaner for repair and provided a free shipping label. The replacement worked fine and I have cleaned the Truman cell 3 times and now the replacement just started turning off and on.
  • automatic677 May 16, 2009
    I have the exact same problem that started just a few days ago. I tried everything and cleaned even though the red light didn't say to clean the cells. I went as far as to unplug almost everything (including this computer) and leave only the Oreck plugged, but that didn't help either. It's on and off phase is starting to **** me off.
3 Suggested Answers
  • 3 Answers
SOURCE: Oreck Air Purifier. Need to take it apart to clean the collection
i just used a butter knife wrapped in a Clorox wipe... being careful not to have the metal show so that it will scrape. when the wipe comes out black, rotate the wipe so that it will be able to clean. I used 5 wipes rotating. I could not figure out how to open the thing either so this was my solution.
Posted on Oct 13, 2009
  • 12 Answers
SOURCE: how to remove the air cell
  1. Turn off unit and unplug it
  2. Along the front edge there should be a thumbscrew, loosen until it is free
  3. Lift front cover from left edge
  4. Pull cell from unit
  5. remove screen from cell, it slides out from the top of the cell
  6. remove odor/ozone absorber, it is clipped into the back edge of the cell
You do not need to be afraid to set the unit on it's back or side, just make certain not to drop it.
Posted on Jul 07, 2010
  • 98914 Answers
SOURCE: how to open and clean oreck xl air purifier
You can download teh manual at
http://www.oreck.com/PUG/3323-8889-Rev-K-AIR8.pdf
Posted on May 03, 2011
I need instruction on how to clean my Oreck XL.
Unplug the unit before cleaning. Wipe off the cabinet with a soft cloth and a mild non-abrasive cleanser.
To clean the electronic collector, loosen the front grill retainer screw then press in the lock and remove the grill. Pull out the collector by the tabs on the sides using both hands. Snap off the charcoal filter from the back of the collector. Then slide off the pre-filter. Spray the pre-filter and the collector with the Oreck Assail-a-Cell cleanser and then let stand for a few minutes before rinsing with water. Otherwise, soak the pre-filter and the collector in warm water (bathtub or sink) with mild dish detergent. Soak for 2-3 hours. Rinse well.
Then allow the parts to dry for completely before reassembling the air purifier. Air dry only.
Pictures to go with the Oreck XL Professional Air Purifier cleaning directions are in the manual. It is available here: http://www.oreck.com/PUG/3323-8889-Rev-K-AIR8.pdf . See page 5.
I hope this helps.
Jul 06, 2011 | Oreck XL Professional Air Purifier
How to remove air filter for cleaning
If you are talking about the metal wheel inside, the only way I have been able to clean it completely is to turn it over, unscrew all the screws, carefully lift it apart, and then you can lift the wheel out. But after you clean it, make sure its completely dry . I usually leave it out in the sun so it drys completely. Then while its out, you can either take a can of the air, like you use to clean computers, or if you have a vac that you can blow air from, or just simply use a soft cloth, brush, whatever you have that can clean it. `its a pain to do, because they def don't mention about how dirty it gets inside there, but honestly I love my purifiers so much, even though its a pain to do, I do it anyway! hope this helps you out alittle!!!
Nov 13, 2010 | Oreck XL Professional Air Purifier
How to open and clean oreck xl air purifier
Jul 08, 2010 | Oreck XL Professional Air Purifier
How do I clean the Oreck Air 7
Hi There,
Here's how you can clean the machine, and I have copied the link to the owners manual below for your convenience.
Cleaning
The Cabinet
You can clean the air purifier cabinet with mild, non-abrasive cleanser and a
soft cloth. IMPORTANT: Unplug the unit from its electrical power source.
Do not spray cleansers or furniture polish into the louver or grill areas.
Collector Cell
Indicator light is green under normal operation and flashes red
when the cell requires cleaning. To clean, proceed as follows:
The red "WASH CELL" light will flash or illuminate when it is
time to clean your cell. However, it is recommended that every four to
eight weeks or if snapping sounds become frequent, clean your
electronic air purifier. Your electronic air purifier is still filtering the air
when the red light illuminates. Cleaning your electronic air purifier is a
snap too... and a must for efficient operation.
1. Turn the unit off and unplug it from the electric power source. If wall
mounted, remove unit from wall.
2. Remove front grill by unscrewing the retainer screw under the grill on
the cabinet bottom. (fig. 1)
3. Pull the cell out of the cabinet by using the two small handles on the
front of the cell. (fig. 2)
4. Snap off the charcoal odor absorber from the back of the cell. Change
as necessary for continued odor removal. (fig. 3)
5. Slide off pre-filter. This can be cleaned with the cell and reused. (fig. 4)
NOTE: Handle the electronic cell with care. Damaged metal plates
and/or broken wires will cause the air purifier to malfunction. (Do
not wash charcoal odor absorber; it is disposable.)
Cleaning with Assail-A-Cell® Cell Cleaner:
6. Using Assail-A-Cell® Cleaner, thoroughly saturate the cell and prefilter.
Be sure to spray between each cell plate and cover every
surface. Allow product to soak for a few minutes, not allowing it to dry.
Rinse thoroughly with water. For extremely heavy deposits, repeat the
process.
IMPORTANT: Dry the collection cell thoroughly outside of the
air purifier before reinstalling it into the air purifier. Ensure
that all areas including corners and areas that may trap
water are dry before reinstalling into the air purifier. DO NOT
process.
place a wet or damp collection cell in the air purifier.
Here's the link to the owners manual for your Oreck Air 7:
http://www.oreck.com/includes/customer-service/owners-guides/pdfs/3323-3018-AIR7-Rev-H.pdf
I hope this was helpful to you. If this helped, please be kind and rate the repair, or leave feedback for me. Thank you,
Chris Jones
GoVacuum.com
May 01, 2010 | Oreck Super Air 7 Air Purifier
How can you tell if the oreck tower works.mine used to collect surface dirt on the small horizontal pains at the bottom of cell now it doesnt
Take it into an Oreck dealer, first they'll try to sell you a new one, don't buy it. Then they will happily help you out with whatever parts you may need.
Feb 20, 2010 | Oreck XL Professional Air Purifier
After cleaning red cell light wont go off
This red light goes on when air purifier needs to be cleaned, also check out whether fan is running or fan is stopped if fan is not running and red light is on then the problem is of filter got wet inside.let the filter get dry then check out.if still the same problem the filter needs replacement. to remove the filter for cleaning or replacement Remove the ESP cell by taking hold of the handles and lifting upwards. and then Remove the Oxygen Plus filter from the unit.by lifting it up slightly. its the filter problem either its wet and needs to be dried out or the filter is got clogged by dust and needs replacement.contact the local service center for air purifier and get the replacement filter.------ This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Nov 24, 2009 | Oreck Super Air 7 Air Purifier
Feb 23, 2009 | Oreck XL® Air Purifier
Oreck XL air purifier (Tower Model)
Is this purifier wet at all, or been in any heavy areas of moisture. This purifier is very undependable with moisture. It may just have to dry out. Let me know if this solves your problem or we can explore further options.
Please keep me updated, thanks
Apr 13, 2008 | Oreck XL Professional Air Purifier
X-tended life air purifier
One of the wiring detached chech wiring might lose
Dec 27, 2007 | Oreck (AIRCOM1WOI) Air Purifier
Oreck XL® Professional
clean your cell. Allso check for broken or loose tungsten wires in cell.
Dec 03, 2007 | Oreck (AIRCOM1WOI) Air Purifier
Oreck XL Professional Air Purifier Logo
70 people viewed this question
Top Oreck Air Purifiers Experts
Mike
Michael Youngman
Michael Youngman
Are you an Oreck Air Purifier Expert? Answer questions, earn points and help others
